92 3vze very sluggish at times
Old Apr 21, 2013 | 08:34 AM
Cpasour's Avatar
I have a 92 pickup ext cab 4x4 with a 3vze and a 5 speed. Has no power at low rpms sometimes. It will be about 2000 rpms and won't go then it will just take off and run fine for a little while and then do it again. This is my first Toyota and don't know to much about them and cannot figure this out. It helpful info would be great
Old Apr 21, 2013 | 04:08 PM
Slowey23's Avatar
try changing your fuel filter for something simple
Old Apr 22, 2013 | 04:04 AM
Cpasour's Avatar
It has about 25,000 since new heads were put on, bout 3,500 miles since new tps, plugs and wires and fuel pump and filter were changed. It just started doing this about 2 weeks ago and I can't figure it out
Old Apr 22, 2013 | 04:06 AM
Cpasour's Avatar
Sometimes it sounds like it is backfiring when u try to take off then it will just quit and run fine for a few minutes and then do it again then it will start running fine
Old Apr 22, 2013 | 08:20 AM
thekeith86's Avatar
might be the egr valve. (engine gas restrictor valve)
Old Apr 22, 2013 | 08:43 AM
Co_94_PU's Avatar
EGR = Exhaust Gas Recirculation (or recirculator valve)That won't cause back/after fire, it causes no fire due to a screwed up air/fuel mixture.Just a guess but maybe your air vane is sticking. You'll want to try and be a little more clear about what is happening, is it or isn't it backfiring, exactly what "quits", what have you tested already..
Old Apr 22, 2013 | 09:19 AM
thekeith86's Avatar
Also my parents had similar issues backfire and sluggish off the line. I looked into it. It ended up being a cracked exhaust manifold. I think they have the 2.7 motor.
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
