Losing power
Old Apr 11, 2013 | 10:29 PM
Jdizzy189's Avatar
Losing power
What's up y'all! I have a 95 4runner 3.0 manual 4x4 and recently I been noticing when I'm doing my normal driving up hills on the road, I been losing power and been having to keep down shifting and still losing powers. My buddy said it could've been spark plugs so I changed them out. They were pretty bad and it did help a bit, but its happening a bit. I think it could be the fuel pump might be going out or the injectors might be dirty. Any advice?
Old Apr 12, 2013 | 02:37 AM
3.slowking's Avatar
There are a few things you can try. One is fuel addatives. Another is taking your throttle body off and give it a good cleaning with carb cleaner and a tooth brush. Worked for me... P.s. The stp injector cleaner will mess your spark plugs up if you use it in mass quantities
Old Apr 14, 2013 | 01:02 PM
Jdizzy189's Avatar
Thanks for the help! Throttle bottle cleaned and seems like she's breathing much better and I'm being able to even ride the gears a bit longer too.
Old Apr 14, 2013 | 01:03 PM
Jdizzy189's Avatar
Throttle body*
Old Apr 16, 2013 | 09:12 AM
3.slowking's Avatar
Ok yesterday I replaced my distributor cap and wires with a borg warner cap and omni spark 5mms. I also switched oils im running straight 30 penzoil and a k&n oil filter. Extreme difference in power. I mean it chirps the tires on take off and its an automatic. Try that and see. 4qts sae30 penzoil-distributor cap-1qt lucas-omnispark wires-k&n filter.... 100 bucks
Liadrin
Apr 25, 2022 02:54 PM
delmert
Sep 30, 2015 04:34 PM
Liadrin
Sep 1, 2015 06:44 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
Sidherish
Aug 2, 2015 01:42 PM
