PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 [260] 261 262 263 264 265 266 267
  1. ? About mounting trail lights
  2. Changing tranny fluid
  3. 1st Gen Rear Seat Shoulder Belts Installed
  4. Squeak in front passenger wheel?
  5. Over Drive Relay
  6. A/C and power steering idle-up plumbing
  7. Headers for low end torque?
  8. 87 22re Base Timing too high, has miss.....
  9. A-arms
  10. Pest Coolant Leak! Temp sensor
  11. I need help picking new hubs.
  12. Motor stalling problems?
  13. 86 steering wheel in 87 pickup?
  14. connecting 2 oem brakelines to accomodate lift
  15. Introducing myself
  16. Should I regear or am I fine?
  17. High idle and gas pedal
  18. Dumb question for the day: timing belt. .
  19. 22re surging at WOT
  20. hauling 1500 lbs in my 1st gen?
  21. Engine Options
  22. Ticking coming from engine?
  23. removed rear heater unit...more room now
  24. Looking for exhaust opinions
  25. Overheats - Calling all experts
  26. 3.0 - 3.5 swap do you notice better gas mileage
  27. Broken valve spring on #6 in a 3.0
  28. 1988 Pickup wont start
  29. Trucks worth more than 4runners?
  30. Best tire/rim/lift combo for the price??
  31. Gear ratio ???
  32. Need help Id'ing this hose!!??
  33. 3.4 exhaust manifolds on 3.0 heads?
  34. How many quarts do you use in 3.0's?
  35. where are the EFI computers?
  36. 2nd gen.CV axle replacment DIY's Weekend Mechanic
  37. 22RE Coolant Blowout - Need Suggestions
  38. anyone had problems removing injectors from harness?
  39. Extended Yoke, Where To Find One For A 94 2wd
  40. seat cover suggestions?
  41. Rear diff blowout?
  42. brake problems
  43. what's that clicking noise i hear when i turn?
  44. Trailmaster lift: shocks?
  45. do MR2 alternators fit into 1st gens?
  46. Electrical gurus. Day time run lights ??
  47. Weird acceleration problem
  48. 1993 22re EFI Cold / Hot Problems
  49. trade coil spacers
  50. Anyone had a problem with an aftermarket fan (bearing) bracket?
  51. Spindle / Bearing Question
  52. 93 Starter Question
  53. poor mpg
  54. Ignition Timming Advancing
  55. torsion bar...need help...plz
  56. Fuel filter will not come off!!!
  57. Pics of 2nd Gen 4runners
  58. Major oil leak on 86 22R truck
  59. rig buildup, gimme opinion
  60. 1st Generation 4runner antenna mast replacement
  61. t-case question
  62. Warm engine idling problem...
  63. Adjustable cam gear help. 22RE
  64. Cruise Control Problem, help!
  65. Clutch alignment tool
  66. Aisin Hub rebuild fun ;-)
  67. will a clock from 85 fit a 92 ?
  68. 4runner Heater Blower Motor...
  69. Engine Swap
  70. Removing oil dip stick tube on 22RE
  71. v6 mechanical oil pressure gauge
  72. A340H differences?
  73. 4 or 5 link rear suspension kit for 94 2wd prerunner project
  74. 90 Runner AT OD Questions
  75. 94 4runner 4WD question
  76. could someone elaborate on these codes a little more?
  77. ok so who has the best cup holder for us?
  78. 89-95 4x4 3vze turbo kit??
  79. Relocated the computer
  80. ergent Power Steering Pump Help
  81. Speedo on 4Runner
  82. Bucket Seats
  83. lug nuts
  84. 90 4Runner Starting Problems(Update)
  85. Stock Radio Removal
  86. Service Manual for 1988 3vze?
  87. it just wont start
  88. Best place to buy headers for my 3vz?
  89. Smell gas when I stop
  90. No power windows, mirrors or locks...???
  91. Does the brake line need extended for HD coils?
  92. reverse question
  93. Downey HD coils
  94. 95 4Runner MT 3rd gear
  95. Suspension 101
  96. AAL...need help and qiuck...
  97. HELP! Overheated and white smoke is everywhere.
  98. '88 Auxiliary Air Valve Spec
  99. my 94 yota is serging.......
  100. options to enlarge manual rear window?
  101. Super Swamper TSL 35x14.50x15 fitment?
  102. What size (LPH) is stock 3VZE fuel pump, turbo project
  103. air box mod???
  104. Alternator/Electrical problem....
  105. Rear Differential Leaking at Pinon Seal
  106. I need some pics of the passenger side plenum
  107. Strange Coolant Leak
  108. any ideas for a code 52??
  109. exhaust leak causing rough idle?
  110. 22re rebuild
  111. Another A340H problem..........
  112. Tech guy help me! Broken cam tooth, is it ok?!
  113. 3.4 5vzfe wiring question
  114. 3.0 water pump replacement
  115. Newbie here!!!
  116. 22re wont start after head gasket
  117. listen to my engine
  118. all stock toyota better?
  119. 3rd Gen Trailer Hitch on 2nd Gen??
  120. universal 02 sensor wiring question
  121. cpe maf conversion
  122. HELP: I took off my plenum and now she runs like crap
  123. 3vz-e water injection pics
  124. what seats fit in a first gen?
  125. 1987 Rear Window issues
  126. New member saying hello. .
  127. Which connector is this?
  128. Engine Degreaser
  129. need help asap! cam distributer gear bolt!!!!
  130. undebody spare tire carrier
  131. JDM motors?
  132. 2 Gen rear lift using 44044 springs?
  133. Torsion Bars
  134. Two dead alternators in a week?
  135. Engine rebuild???
  136. Tranny jumping out of first
  137. Keyless entry opening back window?
  138. MAF Question
  139. 2nd Generation Auto to Manual Tansmission Swap
  140. Testing VAFM
  141. My exhaust stinks...need some karma
  142. power door locks not working
  143. 90 4run 3.0 auto to 95 3.0 manual swap ?'s
  144. Front axle won't come out!!!!
  145. Installation of Roof Rack
  146. Sky manufacturing rear shock hoop
  147. bearings, cv, & axles...Where should i buy these??
  148. Squealing problem (belt?)
  149. 3vze Injector FYI?!?
  150. Timing a 3.0
  151. Rushing water noise?
  152. Will my '94 2WD 5-speed pickup make it to 300K?
  153. O2 senor bung source?
  154. will tires these fit.
  155. which add-a-laef is better???
  156. '89 4Runner intermitent starting problems
  157. wheres a good place to get a rear locker for a 94 2wd?
  158. I have two door handles on one door - wtf?
  159. New rear coils
  160. Rear "window lock" removal
  161. 95 4runner V6 problems, I need to get to work, please help. (pretty long)
  162. 22RE not turnin over?
  163. Gears and other info
  164. boring a 22re lazer block .060" over
  165. Fuel injector’s o rings
  166. Front Diff Does Not Unlock......
  167. tire/wheel questions
  168. 3rd gen wheels on 2nd gen 4runner
  169. Reman power steering pumps and some PS Qs
  170. Help 1988 3.0 Xcab automatic, hard shift problems
  171. body visor
  172. will the lil' 22re pull this?
  173. Bad Valve Bad clutch Is it easier to pull engine?
  174. 22r takin a turn for the worse
  175. Which exhaust sounds good with the 3.0
  176. How to kill the evil buzzer but save the dome light?
  177. Which head?
  178. crank seal leaking after speedy sleeve install
  179. 1 Ton rear 3rd question
  180. MSD 3vze wires, wrong terminators?
  181. .. 1991 2door 4Runner..what do you think its worth??
  182. 85, 86, 87, and 30?????
  183. help diagnose problem w/'91 truck
  184. Body lift for 1989 pickup with auto trans?
  185. Air shocks on front of 2wd truck?
  186. Belt ?'s
  187. A couple of questions re swapping guages and clinometer
  188. 2nd post - clutchless
  189. Shortage somewhere??
  190. Torn CV boot question
  191. t-case rear output bearing
  192. fuel pump
  193. 93 3.0 Head Removal Problem
  194. DOWNEY vs. OME suspension kits.
  195. pic of 1st gen roll cage
  196. 50N Alignment question
  197. 88 rnr lift ???
  198. 32x11.5x15
  199. front end rebuild...please help
  200. 1994 Truck Engine Miss and Code 31 22RE
  201. 1988 V6 HG Recall
  202. Were the 88 v6's covered under the recall?
  203. tire question
  204. pitman arm
  205. Aftermarket Hubs
  206. Trailmaster lift + gears install?
  207. custom air intake for 2nd gen 22re
  208. Liscense Plate Bulbs
  209. tire questions???
  210. driveshaft
  211. When doing 3.0 valve cover gaskets...
  212. compresion questions
  213. Aluminum or Steel Wheels?
  214. Compression Check
  215. Superlift 4" lift--y/n?
  216. Quick question on Headgasket and Timing Chain Cover
  217. More 4runner purchase advice
  218. Help with Procomp MX6's on a 94 2nd Generation
  219. Lack of headers causing all HG problems?
  220. timing belt tensioner
  221. 3vze Knock Sensor Replacement
  222. How many miles on original 3.0's?
  223. body swap question
  224. Looking for JDM Hilux taillights for 2nd gen 4runners
  225. 94 Toyota 4WD - Code 71 / Code 25
  226. check engine light help . . .please
  227. TPS Question
  228. Dual Battery placement
  229. Lost Power--Help
  230. GM rims on Toyota?
  231. $550 to change clutch??
  232. 22R low Oil pressure HELP?
  233. Auto Tranny Won't Downshift properly
  234. 92pickup body lift question
  235. V6 4x4 manual shifting problem
  236. why am i getting really low MPG
  237. 4 inch ifs lift with 31's?
  238. SAS in progress
  239. 94 4Runner Stalls
  240. 33x10.5's on 15x8?
  241. Lcoation of PCV on 3.0
  242. 32x11.5x15 on a stock wheel
  243. Paint Codes
  244. Rear Window Wiper Problems
  245. 1988 4x4 X-cab V6, should I buy it?
  246. need advice quick on runner purchase for 750
  247. Best $800 spent, ever.
  248. bed question
  249. 15x7 on 33x10.50? BS and Tire Bulge?
  250. clutch-less
