How many miles on original 3.0's?
Old Feb 22, 2006 | 08:58 PM
pruney81's Avatar
I'm going on Friday to look at an 88 X-cab 4x4 V6 with 260k on the clock, the headgasket was done in the early 90's due to the recall. I was just curious how many miles you guys have on your 3vze's. Paul
Old Feb 22, 2006 | 09:08 PM
Jeffires's Avatar
There's a thread called "how many miles does everyone have"
https://www.yotatech.com/forums/f123/how-many-miles-does-everyone-have-4255/
Browse through that and you'll get a good idea.
I have a little over 190K, and other than needing my valves shimmed, the engine and drivetrain are excellent. You said the one you are looking at is 5spd- even better.
Best of luck
Old Feb 22, 2006 | 10:11 PM
chugs's Avatar
94 pickup 92,000 miles
Old Feb 22, 2006 | 10:46 PM
hytech_redneck's Avatar
94 runner 120,000 miles works fine after a clutch replacement.
Old Feb 23, 2006 | 04:19 AM
4mydogs's Avatar
'95 4Runner with 145,000 miles.
Old Feb 23, 2006 | 04:38 AM
gohawks's Avatar
1988 4Runner 206,000
Old Feb 23, 2006 | 05:56 AM
regularguy412's Avatar
92 3.0 auto trans 183,000 miles
Old Feb 23, 2006 | 06:13 AM
celica's Avatar
233,000 miles, runs like new, doesn't burn oil, no slck in the driveline. Took it in for a timing belt a year ago & they couldn't find anything else to fix (at a dealer). Yup it is a 3.0 with the 5 spd
Old Feb 23, 2006 | 07:13 AM
RustBucket's Avatar
Had a 3.0 auto 93 with 184k. Zero leaks, burned a little oil, ran well, would do 90+ on the freeway without much hesitation
Old Feb 23, 2006 | 07:53 AM
funjumper's Avatar
~207,000
1994 SR5 5 speed. Head gasket done on recall at about 100,000, timing belts, water pumps replaced, seals, etc, every 60-80K. Mobil1 since the second oil change with a few dino oil changes here and there. Valve adjustments three times, IIRC. Maintenance is cheaper than repairs.
I helped a friend buy it new and ended up with it at about 25,000 miles. Most of the miles are highway miles. Light offroad use now and then, mostly for exploring and back country camping.
Old Feb 23, 2006 | 08:59 AM
Toyofast's Avatar
My '90 has 311K miles total... at 190K did the head gasket. I drive about 60 miles per day too.
Old Feb 23, 2006 | 09:08 AM
snap-on's Avatar
94 truck first motor puked its second HG at 120K i have over 220K on the truck today (diffrent 3vze)
my 92 runner had the HG recall done and had 188K on it when i pulled the motor due to an unrelated problem.
Old Feb 23, 2006 | 10:15 PM
kpaxfaq's Avatar
151,000 miles, runs great, with minor oil leak that hasnt got any worse for the last 40,000 miles
Old Feb 24, 2006 | 10:13 AM
20mako1975's Avatar
1995 4Runner 3.0 V6...........111000 miles.
Old Feb 24, 2006 | 10:43 AM
the_4runnin'_beast's Avatar
89 3.0L 4runner with 450k on it. It has a burnt valve, but other than that, it still runs fine.
Old Feb 25, 2006 | 06:44 AM
V_Runner's Avatar
Banned for stupidity
i got 183,504 on my 89,3.0L...and it has nothing replaced on it... it's going to need a new altinater soon and the water pump just started leaking a liitle during warm up(think it's a gasket)...other than that mines fine...
Old Feb 25, 2006 | 07:20 AM
91_4x4runner's Avatar
1991 with 231,000 on the clock... engine is in pristine condition still... its driven 50 miles a day to and from school (when sister had it) and im going to be doing the same come august
Old Feb 25, 2006 | 09:29 AM
highway74's Avatar
94 SR5 pickup with 102,000.
Old Feb 25, 2006 | 10:15 AM
Montana T4R's Avatar
'92 4Runner with 161,000 miles and just replaced second head gasket
Old Feb 25, 2006 | 10:18 AM
nunsa's Avatar
My old '89 3.0 had 287,000 before the head gasket started to leak, it was amazing, original HG!
Take Care!
