How many miles on original 3.0's?
Old Feb 29, 2008 | 08:58 AM
  #41
drew415's Avatar
1995 4runner 164,000 minor oil leak, but still cruisin !
Old Feb 29, 2008 | 09:02 AM
  #42
Victor's Avatar
94 4Runner with 170000. It all depends on the maintenance. If the oil is changed with good stuff and the air filter is kept clean it can run a really long time.
Old Feb 29, 2008 | 09:07 AM
  #43
rootedtree's Avatar
'91 4runner 4X4, 3.0 -- 192,273 original miles. All regular maitenence and special service campaigns performed. Still runs strong.
Old Feb 29, 2008 | 09:57 AM
  #44
Kiroshu's Avatar
150,000 YESTERDAY!!! YEAH!!!
___________________________________
95 Toyota 4runner SR5 V6 3.0 Automatic
Old Feb 29, 2008 | 10:07 AM
  #45
89RUNNERFFD's Avatar
218,000 on my 89 Ist Gen 4Runner.Just had the timing belt done. Runs great. Dose burn a bit of oil.
Old Feb 29, 2008 | 11:32 AM
  #46
82yota's Avatar
My 92 had 242000 miles on the V6 and it ran fine other than the hg was blown in it. But it has that motor no more. Changed it for the 3.0TD. It has 187000 miles on it and runs very strong. My dads 91 has 151000kms on it and runs perfectly and grandfathers has 289000 kms and runs perfectly. I know my dads had the hg done at 70000kms but nothing since.
Old Feb 29, 2008 | 12:02 PM
  #47
phildelfino's Avatar
Check my sig because I just turned 224,000 miles. Woooot
Old Mar 1, 2008 | 10:31 PM
  #48
stormin94's Avatar
204,000 Miles. Still going strong. Great little motor.
Old Mar 1, 2008 | 11:16 PM
  #49
89XTRA's Avatar
89 Truck 3.0 5 speed 159,000 and counting
Old Mar 2, 2008 | 09:03 AM
  #50
WestCoastMoose's Avatar
90 4Runner V6 Auto 342,000 k or about 214,000 miles .All original Mtr and Trans.Shifts like a dream.
Took her across BC (From Van)to Alberta,back to Kelowna,back to Alberta again(picked up our kids after dropping them off)and back home.Fully loaded,pulling a tent trailer(1500lbs) 3800 KM trip.Did not put any oil or water in at all during the trip.Did some off roading as well.
Mind you 2 days later the drivers rear axle bearing burnt(whew) and a flat tire the same day. Thats luck.
But cannot say enough about how this truck performed through the Rockies.
Old Mar 2, 2008 | 09:07 AM
  #51
Greg_Canada's Avatar
232,000km on my 89'... new clutch at 190,000km....
It's loud but its reliable.
Old Mar 3, 2008 | 02:55 PM
  #52
leiniesred's Avatar
1989 3.0 264,000 miles. Original head gaskets. Engine seems quite tired.
Low oil pressure, low power. Never adjusted the valves. I should really test compression and adjust valves to see if I can get another year out of it.
Old Mar 3, 2008 | 05:29 PM
  #53
Firebb15's Avatar
206K...94 4x4 pickup...all original...bought it off the previous owner and had to do it's first t-belt and water pump asap at 10 yrs and 134K miles. It looked sad. Only replaced a starter, plugs and oil since then. Everything else is original including wires/clutch. No smoke/leaks/knocks, 1 qt between changes
Old Mar 3, 2008 | 05:37 PM
  #54
904_runner's Avatar
246,300 on my 3.0! 240,000 when i bought it! Apparently toyota wouldn't cover the head gasket, so i don't think thats been done! The downside is when i bought it, it caught on fire on the way home! Since we got it running,, its good(knock on wood) I plan on doing a tune up when i get the next paycheck (plugs, rotor, wires, fuel filter, change the oil)!
I advanced the timing 2 degrees from recommended, seems to run better(any one else?) Also at 70mph its at 3000rpms, sound good?
Old Mar 3, 2008 | 06:53 PM
  #55
Alex 400's Avatar
thats about right on the rpms. Mine runs right about there and will hold 70 over anything unless i am towing. over in eastern washington i had it going about about 85 along with everyone else no problem. and got about 22 mpg too. slowed it down on the way back to about 65 and got about 26 mpg on the highway with it. it gets about 13 or 14 in the city.
o and it's got about 155000 on it and runs great
Old Mar 3, 2008 | 07:05 PM
  #56
toytech76's Avatar
We have a customer with a 90 4x4 with over 600K. (honest to god) He has had a couple valve grinds but has the original bottom end
Old Mar 3, 2008 | 07:14 PM
  #57
904_runner's Avatar
on a 3.0? Jeeze! Pray for mine!
Old Mar 3, 2008 | 07:34 PM
  #58
Alindqu1's Avatar
1992 215000
Old Mar 3, 2008 | 07:35 PM
  #59
ozziesironmanoffroad's Avatar
from the way my 22re is running, its well on its way to 600,000, original top and bottom end
Old Mar 4, 2008 | 05:27 AM
  #60
4mydogs's Avatar
Just hit 165,000 last night.
