4 or 5 link rear suspension kit for 94 2wd prerunner project
Old 03-05-2006, 05:08 PM
subliminaltrips's Avatar
anybody know if there are kits avalilable to add a 4 or 5 link rear suspension system to my truck. i have a mig welder so welding isnt a problem. i havent been able to find any on any searches.
Old 03-05-2006, 07:42 PM
odothechangling's Avatar
I'm pretty sure that they only have 3 or four link suspensions for the rear. I haven't heard of a 5 link. Try looking at esbfab www.esbfabrications.com or try Giant motorsports. Here is a direct link to a 4 link setup that might interest you. http://www.giantmotorsports.com/products/yotalink.php
Old 03-06-2006, 08:46 AM
thanks im not looking at speending more than 1000 bux , i heard a budy say do a 5 link rear suspension and i just assumed thast was what the 3 or 4 link was with the rear swing arm.
Old 03-06-2006, 10:03 AM
phorensic's Avatar
ESB Fabrications--$2000
Giant Weld It Yourself--$550
More Giant link systems here: http://giantmotorsports.com/products/index.php
You are going to spend more than $1,000, trust me. So if your budjet is $1,000, throw the project out the window and think of something else....or take some suggestions from the hack-fab over at pirate4x4.com, lol.
Old 03-06-2006, 11:48 AM
Pozi's Avatar
Hack-fab! I love it. I frequent Pirate 4x4 and for the most part they are a bunch of haters.
Old 03-06-2006, 02:07 PM
phorensic's Avatar
There is some good fabrication going on over at the pirate. I emphasize SOME.
Old 03-06-2006, 07:22 PM
there really is no budget im just looking for a "kit" or plans to fab my own i would pay 2000 for that kit but id rather do it myself but if i have to do it that way i will. most setups like that are pretty much interchangable between any truck with similar wheelbase. whats the "hack fab" out of curiosity?
Old 03-07-2006, 10:14 AM
phorensic's Avatar
Hack fab is just dirty, mis-engineered, redneck type fabrication. Booger welds, poor design, not a single triangle anywhere, no gussets, wrong material (like schedule 40 pipe or rebar), etc.
If you don't want to spend the money on a kit that has been engineered for years and proven to work in race conditions, which is why the kits are so expensive, then you will have to do a lot of math and calculating. The tool to help you is this: http://mysite.verizon.net/triaged/fi...arLinkV3.0.zip
It is from this thread: http://www.pirate4x4.com/forum/showthread.php?t=204893
Good luck. You need to know quite a bit about the geometry of 4 links and you also need to know exactly what you want. Things like roll-center, anti-squat, center of gravity, driveshaft plunge, pinion angle change, etc.
If for desert use, I suggest 60-80% anti-squat, 2" or less of driveshaft plunge, very little pinion angle change (could be wrong on that), 16-24" of travel, etiher 3 or 4 link.
If for rock crawling use, go with the same suggestions, except you might want to experiment with over 100% anti-squat. Some rock crawlers seem to praise a rear link system that grows when you get on the gas, supposedly helps in certain situations.
Old 03-07-2006, 03:40 PM
well i guess im a bit of a hack fab but i dont use pvc or rebar. my welds arent the prettiest but they will hold. as for all the engineering ive thought about that and its about worth the price to have it already done and im most likely going to stick with the downey springs and the spring over axel i just did for now and if i decide to go 4 link i may just buy a kit somewhere down the road.
smthwsn357
12-04-2023 02:08 AM
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
ptb12
07-05-2015 01:49 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 4 or 5 link rear suspension kit for 94 2wd prerunner project
