What causes the "brake" light to stay on?
Old Feb 20, 2006 | 01:32 PM
fierohink's Avatar
Question What causes the "brake" light to stay on?
I know it comes on when you pull the parking brake. And it comes on when the fluid gets low. But mine stays on and neither of those are the problem. What else makes it come on?
Old Feb 20, 2006 | 01:43 PM
surf4runner's Avatar
failure of the parking brake switch itself?
have you tried pushing the handle in hard or wigglin it around?
Old Feb 20, 2006 | 01:44 PM
Tacoma Dude's Avatar
https://www.yotatech.com/forums/show...ht=brake+stays
Search is your friend
Old Feb 20, 2006 | 03:23 PM
regularguy412's Avatar
Likely the fluid sensor in the reservoir is sinking cuz it's worn out. Disconnect the wires from the cap and see if it stops.
Mike in AR
I chased that one for a long time.
Old Feb 24, 2006 | 06:12 AM
86SR522REEFI's Avatar
Mike in AR
Or just buy a new one. Check your fluid level in the brake fluid Resevoir and make sure that the park brake is all the way in. Just cutting the wire off of something that could save your life sounds like a real bad idea.
Old Feb 24, 2006 | 07:54 AM
rchavis's Avatar
I just brought one of those caps. They are between $90.00 and $100.00 depending on the dealer. Part number 84460-35050, Switch assy.
Might be able to find a used one, however it is an electrical part. Hope this helps.
Old Feb 24, 2006 | 07:55 AM
93Toyota PU's Avatar
My brake light comes on occassionally...I traced it to the switch behind the parking brake handle. If I jiggle the brake handle the light usually goes out. The switch is not being fully depressed probably due to a weakened spring on the brake cable. There is a spring on the cable near the rear axle. There may be a way to tighten up the slack in the cable which probably would help too.
Old Feb 24, 2006 | 09:40 AM
adjust the rear brakes first then adjust the slack in the cable. lubrication helps too
Old Feb 24, 2006 | 09:44 AM
Jeffires's Avatar
...and even if that doesn't work, wiggle the handle and push it hard when you release the brake. My roommate's Tacoma did this.
Old Feb 24, 2006 | 10:09 AM
20mako1975's Avatar
I had the same problem. My mechanic told/showed me that I needed new rotors and pads. $187.00 later the problem went away.
Mako
Old Feb 24, 2006 | 11:42 AM
I changed out the park brake light switch and it didnt cure the problem, although, it could well be just that. There's no wire cutting involved with the fluid reservoir gauge. The cap that holds the donut has a plug on the end. Just a matter of unplugging it to TEST it and see if it is, in fact, the culprit. If that's the case, then one can choose to replace the cap / gauge.
I've noticed no decrease in any braking effectivness with the float (gauge) unplugged.
Mike in AR
Old Feb 24, 2006 | 06:30 PM
tc's Avatar
tc
Mine did that because of a frozen/locked up caliper.
Old Feb 24, 2006 | 08:36 PM
DudeBud's Avatar
sometimes unpluging the master cylinder cap for a temp fix works
fountain
Dec 31, 2015 06:08 AM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
PopsDad1
Jul 30, 2015 02:21 PM
mluz013
Jul 24, 2015 12:31 PM
