Old Mar 31, 2016, 02:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner 4WD - Four Wheel Drive Guides
Print Wikipost
93 toyota pickup 4wd dash light stays on
Old Jul 27, 2015 | 09:39 PM
ViperTT's Avatar
Well I am back
I got a problem, the dash 4 wheel drive green light stays on even in 2 wheel drive and in neutral!
I have in the past two years pretty much have rebuilt this truck
a new rebuilt v6 motor a new clutch, had to really replace much of the dash
as the previous owner had hacked it to death but I did have to replace the dash panel but I made sure it was the same as the old broken one
so I do not think it is that but I do not remember when my son got this truck if that light was staying on then
down underneath on the pass side on the transfer case by the rear there
is a wire plug, I have disconnected it and the light stays on still !
does anyone know were the 4 wheel drive switch for that light is at??
on a side note we have like I said kind of rebuilt this whole truck
and instead of painting it my son wanted to put that raptor liner on the whole truck thank God he talked me into that it did not have to take
100's of hours of body work and prep
Old Jul 27, 2015 | 11:16 PM
wyoming9's Avatar
Red face
Does this have ADD??
Old Jul 28, 2015 | 09:49 AM
ViperTT's Avatar
ADD? do not know what that is
this is a manual trans with manual 4x4 shifter
but the engine has tons of vacuum lines on the 3vze v6 but none go
down to the tranny or transfer case as I can see
the 4x4 all works just put it in 4 low or 4 hi or 2 wheel drive and it all works
the front axle have free or locked manual hubs
Old Jul 28, 2015 | 01:07 PM
millball's Avatar
If your differential has a switch like this:
http://cimg6.ibsrv.net/gimg/www.yota...bbedf6ba13.jpg
unhook the plug, and the 4WD light should go out.
If your front differential is actually disconnecting, the switch itself is your problem.
This FSM link will help you understand ADD.
http://api.viglink.com/api/click?for...26addcontr.pdf
If your truck has been retrofitted with manual locking hubs, the ADD system may have also been permanently locked in.
This would account for your light always being on.
Old Aug 2, 2015 | 01:30 AM
ViperTT's Avatar
I truly Thank You for your help millball !!
I have been under the front of this truck and I might be wrong
but I do not remember seeing no electric plugs of any type on this front axle
but I think I might be wrong I got Monday off so I will go and look I will post what I find
Like I said the previous owner had hacked and abused this truck then when it was worn out suckered my son in trading his motorcycle for it
now it is almost a new truck except this bug with the 4x4 light and some small stuff
But THANKS for the HELP
Bill
Old Aug 12, 2015 | 10:56 AM
ViperTT's Avatar
dam honey do list they should be banned!!
Got to look under the truck this morning
and there is no switch or sensor on the front axle of this truck
there is not even a place for or were an actuator was or should be
is there a sensor up on the transfer case to turn this light on and off??
this is the only place else I can think of were it should be
but don't want to go digging around and open anther can of worms
Thank Bill
Old Aug 13, 2015 | 02:17 PM
millball's Avatar
Some pics might help.
Pic of front differential area.
You got manual locking hubs or plain drive flanges??
Old Aug 13, 2015 | 08:54 PM
scope103's Avatar
Here?
Old Aug 14, 2015 | 05:27 AM
roadtrekker's Avatar
I am not sure if this model already has an abs sensor.
Aleeex_u
Jun 5, 2016 06:52 PM
Valvoman
Jun 28, 2015 02:45 PM
Taz22R
Jun 21, 2015 04:44 PM
ShaunKris
Jun 17, 2015 04:33 PM
infinityisfive
Jun 16, 2015 06:51 PM
