90 4Runner Starting Problems(Update)
Old Mar 4, 2006 | 08:17 PM
jm47's Avatar
Gentlemen: I posted here several weeks ago.I had my starter replaced Monday.Friday the problem returned.I turned the key and nothing.Silence.Five turns later it turned over.Toyota assured me before I had the work done it was the starter.Now what?Any ideas? Thanks...
Old Mar 5, 2006 | 03:31 AM
leebee's Avatar
get yourself a haynes manual, read the section about re & re the starter. check all your grounds and clean them up, do the positives while you are at it. use the search feature at the top of each forum page and type in 'starter contacts' or 'replacing starter contacts' or similar. you can decide what to do about the dealer problem once you figure out what is wrong.
another option is: www.4crawler.com , look for starter contact repair in his write-ups.
lee
Old Mar 5, 2006 | 09:37 AM
jm47's Avatar
Description of Work Done
Starter Solenoid Recon $148
R+R Starter 66
G/R Starter Motor Pole Piece(2) 45
Total: $259
Old Mar 5, 2006 | 10:00 AM
brick privy's Avatar
my '84 did kinda the same thing. turned out to be the ground wire on the battery. when i went to check the battery and cables, the ground wire pulled right out of end. it just depended how the wire was wiggled wether it would start or not. the lights would work and everything, the wire just didn't have enough contact to run the starter.
duckhead
170
Nov 13, 2017 06:07 AM
Crazychris1871
Jun 27, 2016 10:38 AM
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
bobbybouche
Jun 18, 2015 10:22 AM
