- ngk iridium ix plugs
- 87 runner really bad smell
- Spark Plug Change
- 92 4Runner brake/vacuum issue?
- Brake Problem...
- I can't get my idle right!!!
- Auto to manual swap in 95 runner
- Brake upgrade suggestions requested
- 3vze complete exhaust
- overheating and then some
- 3vz Idle speed
- Replaced shifter seat, is this normal?
- possible ifs suspension solutions?
- Speedometer gone whacko,manuals no help
- Rear bumper on my 94...
- Punched hole in oil pan- how to remove oil pan in vehicle
- 3vz-e fuel leak! help!
- NEW YOTA!! 22re LC Engineering(with pics)
- Idle question.
- truck won't start sometimes
- head gasket time. . . .
- body panel question???
- Need help sanding
- 22re 02 sensor question
- Damaged valves?
- 22R Rebuild
- Failed emissions for the fifth time
- Wheel and tranny questions
- Heat and AC controls have no power
- removing vents
- hard start, low idle on 93 4runner
- Smoke coming out of oil cap
- cracked 22re block?
- Grille saver
- 22ret wont idle
- Help 86 4runner won't start
- Started Installing Bushwacker Flares
- timing belt alignment problem
- Signs of a bad pilot bearing?
- Will this chew up my new oil pump?
- 90 4runner help
- 93 runner grille help
- Steering box splines
- Installing Crankshaft Pulley
- 1986 Drive Shaft on a 1989
- thnking of putting a passenger bank manifold onto the driverside of the 3vze
- 1986 22re engine noise
- 2nd gen 4runner interior into 1st gen
- makin more progress... ass sag fixed!
- Bad battery or bad luck?
- How to remove Door Handle - 86 pickup
- Rear bumper Restoration
- Dash and interior lights quit, charging light on
- Front A.D.D diff electrical plug connection??
- Hi-Steer Alignment Questions
- Low oil pressure when warm
- starter issue?
- Idle has increased ???
- Knock sensor issue..
- Won't engage in 4x4
- replacement stee bedside outer panel
- Rear axle seal leaking, to replace wheel bearing or not.
- Blower Motor Resistor
- coil is always grounded
- Need help with brakes!!
- heads prep work
- Post HG replacement temp gauge doesn't work
- ROCK Piston Rings..help
- good vendor for gears/differentials + advice please!
- Utility 1st Gen 4Runner rear seat install questions
- My 22R died and I need some advice
- E-Locker Purchase Price Advice?
- Installing Windshield
- Finding Reverse
- 90 v6 sputters on highway
- 3rd member swap
- stock gear ratio
- shocks for bj spacers
- A/C Hose
- Lower ball joints for a 95' 4Runner need help
- Swap 2 Cluster w/ Tach...
- Carb rebuilding thoughts - 87 Hilux 4x4
- What the heck 22re
- will my 3vze afm work on my new 22re?
- Fix for Rattling hinged support in tailgate
- FRONT Power window relay location?
- Head Gasket set Identification.. plese look 22re 1986 4wd
- sunk truck changed parts now runs horrible
- Kicking tires on SAS for this winter, couple questions, budget is $2k
- 91 4runner will crank but won't start
- Need help igniter coil
- I need some help!!! 1991 pickup v6
- So I think I'm buying another 4Runner...
- Brake rotor resurfacing questions
- A/C compressor hose mount
- Glowing exhaust
- Weekend Project - Get this thing Road Worthy
- 874runners Engine rebuild with pics galore!
- pulley broke loose
- vacuum lines missing and misrouted
- 1987 SR5 Power windows not working. Power lock works.
- 94 Toyota truck- brake pedal pulsating
- Drop Differential to Pull Engine?
- takes a few seconds to start when cold
- Is it my tranny or t-case?
- Wheres this wire go?...
- Tacoma E-locker on 2nd gen
- Reasonable cost of timing chain replacement on 89 4runner
- Sluggish 4runner
- Truck won't start
- Rough Idle When Warm (3VZE)
- How much for (SAS) front driveline.
- wanted to share some pics of my restoration
- 92 Toyota 4x4 truck rear axle slipping
- Sagging rear coils have to go the cheapest way!!
- 94 pickup lookin for lil power
- Coil Springs
- Wooden Bed
- weird battery issue!!
- '93 pickup 4x4 W56-E transmission / T-case swap into '86 4x4 pickup WITH PICS!!!
- Misfire during Acceleration
- What is this??
- Question on Throttle Body Part
- Post Recall 1995 4Runners - HG problem fixed?
- CV boot torn, replace or drive for 1 more month until SAS??
- No Power...22re electrical
- 3.0 crank pulley problem help plz
- Valve cover leak
- Parts truck
- Trying to locate the circuit opening relay
- Half of my cluster died.
- 1990 22RE 4WD 5 spd trans mount
- 88 4Runner - Needs some work
- Post SAS brake problems
- Truck runs poorly
- What tire psi would you run?
- Driveshaft Squeak?
- 93 bumper problems
- o2 sensor wiring harness melted... What do I do?!
- 2wd motor in 4wd
- Attarco Long block Code 52
- Leaking a/c compressor
- Engine running cool? need input
- 1st Gen Cup holder Idea...
- Convert 1st gen 4runner to a pickup, keeping the hard top
- Replacing t-stat gasket
- 90 truck bed fit on 88?
- can i use a 22re air box with a 22rte motor???
- V6 sputter and missing
- Performance chips???
- 22r does not run well
- Can clogged charcoal canister cause overheating?
- 1992 4runner starter bolts help
- How to check for a leak on the intake?
- Question about lifting the front end
- Bed, fuel pump, power steering pump value
- Need help choosing which shocks.
- leaking oil pump/front seal
- what would be easier long block swap or head gasket?
- Landcruiser coil spring conversion
- Removed 4Runner Top...Now Back Window Wont Go Up...
- engine is good.....tranny tweakin?
- 95 4Runner won't start
- Need a straight answer on cv axles
- Front Fender and Antenna Removal on 86 2wd
- HELP!! Broken down!
- Want to convert to locking hubs
- Idle problems in my 1991
- My CV boot blew up
- winch bumper for '87 4runner
- Need help check engine
- Fuel line fittings
- 4000 RPM max an hot exhaust
- 1991 hilux right hand drive conversion
- courtesy switch not getting power
- Questions about my 94 4x4
- My "New to Me" 92
- 4runner fuel pump replacement
- Best cams for mpg and low end power?
- Identify this wire near the radiator
- Did I overheat or blow a head gasket?
- Help with tranny solenoid (pics and part #)
- 90 runner engine codes
- Should I use some lucas oil stuff?
- CEL code 25 AND 26? rich AND lean??
- 2nd Generation Interior Pictures Needed
- Timing belt with no marks ?? ??
- Old Chevy wheels fit?
- full tank empty tank
- Upgraded trans/transfer case mount?
- I think I messed up my Timing Chain
- Just picked up a 1992 Truck, need advice.
- 2WD rear shackles
- cab swap?
- Torque Specs for bearings
- Ways to get out of mud???
- 3vze #2 idler pulley...what to use to seal?
- where can i get 22re oil pump dowels?
- Ever seen this motor under the hood??
- Bucket seats..factory?
- Rebuilding a 88' 4Runner V6 Rear Differential, need some help.
- To fan or not to fan?
- Any way to fix frame damage??
- 94 A.C. expansion valve location?
- 89 2 door 4runner hood
- Steering Box Worm Gear Bearings...
- Is my Gas consumption normal?
- ProComp Skid Plate Doesen't Fit
- any door lock upgrades out there?
- 3.0L bogs down then normal
- Mystery miss in 88 pickup
- Rear Bumper Ends, where are they?
- Two more thumbs down for Bosch platinum plugs in a 22RE
- RPM? Overdrive and Towing Question
- weird engine temp issue
- Carb help per 87, Calli model, 22R
- starter click after using the headlights.
- Power Antenna & relay Questions
- Source for rebuilt w56Transmission
- Rear Diff Swap What Years
- 86 22re vacuum lines
- 85 2WD Steering Column in a 87 4WD ?
- reversing rear driveshaft
- extending gas filler neck
- Engine studders under acceleration
- So I need a bolt size?
- Filter on the throttle body?
- Electrical questions
- NO start
- Mounting the roll bar
- Simple Turn Signal Question
- FJ muffler/exhaust
- just mounted the 33 x 10.5 mud terrains!!! w/pics
- Cruise control vacuum line...
- How common are the super base 4wds
- Overderive Issue.
- Ebay Idler
- Got my 22re head machined... how smooth should it be?
- time for a change
- limited slip up front?
- anybody retrofit a late-model 5 speed in an 86-88 truck? Pics Appreciated!!!
- Intake Manifold hoses?
- 1" body lift, new body mount bushings and fiberglass front fenders
- Leaking 3VZE Power Steering Pump...rebuild, replace, upgrade?
- 87 - 22r fuel pump sight glass full -- What does this mean ??
- exhaust studs stripped
- suspension
- CT26 swap this weekend !
- Igniter Interchange 22rec ????
- truck got some bad noise
