Question about lifting the front end
Old Sep 20, 2009 | 05:10 PM
joevanvliet's Avatar
When i lift up the front end 2" by raising the t-bars, am i going to need new shocks?
Old Sep 20, 2009 | 05:28 PM
anyone?
Old Sep 20, 2009 | 05:34 PM
myyota's Avatar
The best way to raise the front of your truck is with ball joint spacers, if you crank the torsion bars up, your truck ride like a brick and you will be very unhappy with the hard ride that you will have.
Old Sep 20, 2009 | 06:42 PM
Booosted Supra's Avatar
To answer your question though, you will not need longer shocks, the distance between the arms stays the same. You would only need new shocks if you added BJ spacers or drop brackets, but like stated above, it will ride hard
Old Sep 20, 2009 | 07:27 PM
peow130's Avatar
2" is quite a bit for a Tbar crank, i'd only go to 3/4" or 1" to remain a somewhat-soft ride.
I only raised mine to get rid of the rake i had after i installed AAL's
Old Sep 20, 2009 | 08:12 PM
Ive researched it a little more im gonna go with the 1 1/2" BJ spacers and maybe 1" on the T-Bars
Old Sep 20, 2009 | 10:25 PM
Matt16's Avatar
bad idea because:
you will eat CV boots unless you have manual hubs
you will wear out CVs fast off road
you will have shoddy flex
your ride will suck
you will wear out steering expensive components at a surprising rate
your truck will most likely be difficult to align
Leave the IFS at stock height... its just better that way. I bought BJ spacers, then negated the lift by lowering the ride back down to stock. It flexes better now and I don't wear out steering stuff.
Jun 1, 2021 01:51 PM
Daneums
Aug 20, 2015 05:36 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
