PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 [201] 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 1 peice factory rear CV shaft???
  2. Did I test my o2 sensor right?
  3. wanting glass to break up in glasspack...
  4. Vinyl Film instead of paint job
  5. IFS CV, to clearance or not?????
  6. Marlin HD Clutch?
  7. 3vze engine banging, need help!!!!!!!!!!!
  8. Having trouble locating pressure regulator
  9. Just another fun day in paradise.. or not..
  10. uninstall 4" lift
  11. Help had a major brain fart
  12. steering box
  13. Timing chain tensioner
  14. 22RE Block Drain Plug...coolant
  15. Motor Mount Issues
  16. Tranny question
  17. Formal Introductions
  18. 87 Toyota Pickup, won't start
  19. 22re- wierd problem
  20. My new truck- joined the darkside...
  21. Would a 96 hood fit a 95?
  22. I need help locating a tailgate
  23. Grille swap?
  24. Emissions system help, please. (pictures)
  25. question for a 3.0
  26. only 9 pages of 86-95 forum?!
  27. another "sputtering" thread
  28. axle question
  29. 87 22r coolant in oil
  30. Transmission Bolt sizes
  31. Hitch/body lift?
  32. a/c not working, tried a search
  33. HELP Diagnose What happend!
  34. '90 4 runner 22re.....
  35. Radiator Stop Leak
  36. Why does barke fluid come out my caliper pistons
  37. 88 4runner engine swap
  38. Pulled the shifter off...
  39. got my 1st 4runner!!!!!!!
  40. Intake Removal ?'s
  41. U-Joint?
  42. truck died today!!! HELP!!!
  43. No 4WD
  44. Don't you hate that?
  45. SDORI front tow hook
  46. Changing Idle
  47. Trans Cooler Question
  48. Clutch Assembly
  49. 94 Runner 3.0 stumbles, misfire and does not idle
  50. Hello from AUS tall ratio 8 in diffs
  51. Truck Died Today, but came back to life
  52. Driveline clunking sound?
  53. Finished Repainting my rims!
  54. 22re Fuel filter relocation
  55. Parts Question/Oil Leak Question
  56. New Tires and Suspension Questions
  57. 22re timing chain guides torque specs??
  58. Another Tire Choice Thread...
  59. Chevy Spring Swap
  60. 89 22 re
  61. Help with Brakes!
  62. Lift and tires done (pics inside)
  63. Trick to removing decals on a 1st Gen
  64. aftermarket cruise control
  65. another front bumper thread
  66. Tranny won't shift to 3rd
  67. Damged Ring... Options
  68. anyone need anything hauled
  69. symptoms of a failing headgasket?
  70. O2 sensor ?'s
  71. new problems with my 3vze/ low idle when warm and bad accelleration
  72. Intake manifold gasket replaced, now check engine?
  73. How many Litres/Quarts coolant 22RE?
  74. 1989 toyota sr5 no rear speakers
  75. Toyota newb OEM body lift?
  76. Manual Tranny help please
  77. 91 4-Runner driveability ??
  78. 90 P/U needs a 22re rebuild writeup
  79. vac leak?
  80. how can i find out what year my engine is? does it matter?
  81. Hard braking or left turn then POP!
  82. Wrist Pin Assembly
  83. Engine Lag? at high speed/ hills
  84. Hayes Super brute clutch
  85. Rear diff removal?
  86. where is knock sensor located ????
  87. Question about A/C Idle Up
  88. My new trucks.
  89. good buy? part enterchanable??
  90. Problem with torsion bar bolt
  91. best transfercase?
  92. Throttle body water bypass. Where does it go?
  93. Very strange happenings with a 22re
  94. 4runner Computers
  95. Headlight woes
  96. '86 and 31's???????
  97. Put in a new 22R, have some leftover ground wires...
  98. Goin to look at this saturday
  99. Wheel Backspacing & 31x10.5 help
  100. safari rack mounted on camper shell (need pics)
  101. 22re thermostat
  102. 22re Piston Rings
  103. Coolant leak
  104. New Clutch
  105. window price?
  106. Help diagnose 22RE oil leak
  107. Cleaning block surfaces
  108. got my marlin rear bumper on
  109. egr problems
  110. HowTo change 4Runner reverse light location?
  111. Which Headers for 2nd Gen 4Runner?
  112. new wobble
  113. Should I Fix It?
  114. 87 cab and bed swap to 82 frame????
  115. Running Boards!
  116. I need to retard ign timing? Proper way?
  117. 22RE Stock Exhaust
  118. engine bogging
  119. Florida hot spots
  120. sorry if its a n00b question
  121. rear sliding window compatibility
  122. 22re engine running cold
  123. It has happened...
  124. When a blown tire is a good thing
  125. Steering stop.
  126. Urgent alternator(?) problem
  127. 63 chevies ready to go but a quick question
  128. 93 4WD Pickup Front Bumper Compatibility
  129. best bulbs for our trucks??
  130. Loud Ticking driving me NUTS!!
  131. Input on my propsed 4Runner modification Plz
  132. i need a frame
  133. Air Flow Under Hood 89 DLX LB 22R
  134. I apologize for the dumb questions, last one, I promise
  135. gotta a big problem need advice
  136. W56 grinding like crazy (Need rebuild?)
  137. brown smoke??
  138. need a template
  139. New front Brakes info?
  140. noob-mounting bracket/water pump/t-belt/e-fan install
  141. Knock sensor signal ?????
  142. 86 turbo build
  143. what colour shold i paint my 90 4runner
  144. V6 headers to seal (to engine)
  145. Rancho 5000 Steering Stablizer
  146. Where can I find this seal
  147. Lots o ignition timing!
  148. Selling my '93 x-cab, whats a fair asking price?
  149. replacement starter recommendations?
  150. 33 inch tires... .What gears?
  151. Timing question
  152. Split Ring Needed
  153. Damn Cv Boot!!
  154. 22re swap to 22r converting to efi...greatly need advice/input
  155. UGLY chrome mirrors
  156. Ride Quality (I want new parts)
  157. TDC please!
  158. Need New Radiator, Oem Or Aftermarket Replacment
  159. this danged gear shifter...
  160. 22re idle surgeing
  161. Brakes R Dead
  162. power steering/ oil leak
  163. New 22RE stainless Header!!!!
  164. Need door parts? I got'em
  165. Running rich?
  166. I need some help.
  167. which tire size for 3.4L auto w/ 4.88s
  168. weird electrical problem...
  169. axle code question...please
  170. 93 v6 runner knock sensor
  171. 88 4runner Removable Top has RUST! (Need Advice)
  172. Whats It Worth?
  173. dads truck losing coolant somewhere
  174. 94 4runner good cond. bad motor. Price?
  175. 93 runner knock sensor
  176. tie rod ends too much play?
  177. Fuel pump pressure question.
  178. Are these stock rear leaf spring packs?
  179. 22r ...worth converting to injection ?
  180. new BFGs
  181. Auto or Manual? it is my question
  182. Brake Line HELP!!!!!!!!!!!!!!!!!!!!
  183. Diagnostic codes??
  184. 1988 4runner need help replacing Headgasket
  185. Wheeling your 4cyl automatic?
  186. Will a small Oil Leak cause low Pressure.
  187. My 94 4runner is slower than my Pops 91 Previa WHY?
  188. Need help Diagnosing brake Caliper
  189. Topping up my brake resevoir
  190. 86 yota
  191. leaky transfercase
  192. '86 Toyota Ext Cab 4x4
  193. o2 sensor
  194. Injectors Bad?
  195. Need new battery, What to get?
  196. May the Toyota gods have mercy on me! rough idle
  197. Thank you YOTATECH!!!! Idle problem solved.
  198. Should I buy another Headache? 22RE w/bad HG
  199. help!! 22re running lean
  200. oil check procedure- warm/cold levels
  201. 5 speed parts list, missing anything?
  202. New SR5 truck interior door panels - PICS
  203. 22re, tuning stock efi
  204. 89 22re 4runner died and started
  205. Best Ball Joints?
  206. Adding a Roof Rack
  207. Power steering hose question....
  208. Building light wheeler / Daily Driver / Desert Runner
  209. 89 rod bearing
  210. what do you do with old removable top? security of a soft top?
  211. clutch slave cylinder ??
  212. most important issue in buying a "new 2nd gen"
  213. I finally found someone to weld...
  214. 3.0 rpm jumping at idle
  215. OME Length Question
  216. Newbie here with a question on a 93 4-Runner
  217. Run Away RPM
  218. 1993 4-nonrunner...... Fixed!!!!
  219. Speedometer troubles
  220. SR5 Gauge Needle
  221. Deep Fried Clutch
  222. transmission noise ? doesn't seem to be input bearing
  223. Wheel Question
  224. Signing off....:(
  225. manual transmission life
  226. Re-jet a stock 22R carb with aftermarket Headers
  227. No Crank condition: 95 4runner 3.0
  228. IAC valve check?
  229. Hopping 4Runner
  230. Dash-pot question?
  231. great day working with deathcougar+question
  232. New rear main seal...What else?
  233. Pics of wheel setups with low backspacing
  234. iridium spark plugs
  235. Cant Stand the waiting
  236. cams
  237. Factory boards and deflectors for sale 90+ vehicles only...ENDS APRIL 7TH
  238. May be getting another yota
  239. OME suspension stuff for Trucks
  240. Crazy timing 28deg...runs good
  241. New Paint!!!
  242. i have a 1991 4runner with a 3.0vze in it
  243. New High Lift-mounted on tailgate
  244. England
  245. Valve Cover help and opinions
  246. painting rims?
  247. Rear Spring Replacement- OK?
  248. bumper plans
  249. Harsh 3rd Gear Engagement Question
  250. More leaks...so frustrated
