22re Piston Rings
Old Apr 3, 2008 | 03:58 PM
DanStew's Avatar
22re Piston Rings
I got all my parts today from Enginebuilder. I am all ready to start the rebuilod and get the yota up and going this weekend. My only issue is i cannot find a piston ring spreader wrench. Are the rings very weak or will i be able to open them up a bit with my hands to get them on the pistons?
Old Apr 3, 2008 | 04:10 PM
SEAIRESCUE's Avatar
I think Autozone or Advance has a simple spreader for around $5. I use an old flat faced snap ring pliers from Sears. You can walk them on with fingers, if you're careful, but they will likely cut you good.
Old Apr 3, 2008 | 04:15 PM
DanStew's Avatar
Unofruntately i went to ALL the local store and none had them. I have a set of snap ring plyers with flat sides, so i could spread them with those. Just want to make sure they are not real brittle for me to break em in half
Old Apr 3, 2008 | 04:41 PM
misterzee's Avatar
i'd recommend you look till you find a set of ring pliers, they're cheap, and you need the control for properly installing the rings, or, you might break one, or scratch the piston.
Old Apr 3, 2008 | 07:46 PM
thook's Avatar
I put'em on by hand no problem. Just take your time.
Old Apr 4, 2008 | 04:00 AM
Flash319's Avatar
Wow use your hands man. You got girly hands or something?
bigjstang
Jun 2, 2025 03:56 PM
dumpster84
Apr 30, 2016 06:03 AM
Iceman4193
Aug 28, 2015 08:43 PM
Dennisx2
Aug 10, 2015 06:48 AM
