PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 [228] 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. MarlinCrawler Shifter Seat
  2. Torsion Bar adjustment, Not cranking... Rotating
  3. Clown mechanic messed up truck:need advice
  4. Problems with EGR system
  5. air regulator, arb locker question?
  6. gas smell from exhaust and poor idle when its hot outside.. HELP
  7. Swaybar End Links
  8. 3vze Regrounded Crankshaft, Rod and Main Bearing Sizes?
  9. Need help with a cross threaded bolt
  10. All Pro Off Road Full Spool Lockers
  11. Best place to buy Rancho's?
  12. Tranny Swap...old to new
  13. High Idle - Throttle Body?
  14. 22re head?
  15. Bumper Interchangable?
  16. AC Condensation drip line under rig ?
  17. tail light guards
  18. full synthetic oil, and why??
  19. torsion bars 94 pickup
  20. Help!!! Need To Find A High Amp Alternator...
  21. Heavy Duty Rear Leaf Springs For 1989 4runner
  22. Clicking in 4WD
  23. So I took my doors off...
  24. 4runner seat covers.
  25. Poor performance after replacing VAFM
  26. couple questions. mileage and SAS
  27. HELP!! rough idle and sputters
  28. Overdrive Off ?
  29. "Boomerang" shackles
  30. 1995 4runner - Auto to 5speed swap
  31. kayline top
  32. 1992 2wd sr5 26,000 miles for sale
  33. truck idles at 1600 and surges when the brakes are applied.
  34. Toy truck compatibility
  35. steering slop
  36. It's alive...with 6 codes!
  37. Anyone used FREEZE 12 instead of R12?
  38. Where did you mount your winch solenoid box?
  39. quick question....Alternator ground?
  40. started my half doors today
  41. 93 4 runner odometer stopped working???
  42. cleaned tb and now the idle goes up and down.
  43. Click bump click
  44. ISR Mod Q's
  45. 2 door runner?
  46. seafoam in brake booster line?
  47. Keep Blowing Power Steering Pumps
  48. O2 Sensor Replaced for Free?
  49. northwest off road used to offer a diamond plate rocker panel for 4runner
  50. 22re rough idle, TPS already replaced?
  51. 3.0 fuel economy "oh oh what a feeling"
  52. wacky Air Filter idea....
  53. Fuel Mileage. Stock 22RE trucks
  54. Help ID these seats!!
  55. 3.0 is dead. What now?
  56. Rear Shock Suggestions
  57. 95 4Runner steering wheel removal
  58. No 4LO
  59. Good truck for my next project?
  60. Automatic to Manual Hubs Question
  61. Where to buy new engine from??
  62. Snorkel help!!!
  63. Took the top off today
  64. Need help, 22RE Turbo Rebuild
  65. 1992 22RE engine will not turn over?
  66. 2 injectors blocked after top end rebuild ,can i do this?
  67. IP Gauges Fail, Signals Fail, Battery not charging
  68. white smoke coming out of the exhaust
  69. Replacing Ring and Pinion
  70. goin with the flow, drop it off a cliff?
  71. HELP! truck wont idle
  72. Question(s) of conversions?
  73. Dream come true !!!
  74. clutch or tranny problem?
  75. worn stop or CV or uni joints?
  76. Air Cleaner Adapter?
  77. Tortion Bar lift: rough ride
  78. fan locks up too much?
  79. Weird idoling problem(seem weird to me)
  80. Code 7-1, what does it mean?
  81. 3.0 cold air intake NOT K&N sealed air box!!!
  82. I hate theifs
  83. Running Lucas oil...
  84. a.d.d. to non a.d.d. need help
  85. money to blow on runner. what to get???
  86. broken close button on 92 4runner NEED HELP ASAP!
  87. auxiliary lights diagrams
  88. flywheel resurface
  89. line-x, herculiner, or flat black
  90. cam shaft pulley removal 3vz-e
  91. Dad's getting a Cam and I have a few ?'s
  92. 22RE Problems
  93. Frame rot repair
  94. HELP! Crank bolt fell off.
  95. Alternator issue after engine wash
  96. tailgate half open.
  97. Help finding information about adjusting valves
  98. stoping that nasty turning sound
  99. Removing interior Door Handle
  100. Roof care
  101. Seafoam through the Intake
  102. O2 sensor nuts
  103. So, who has replaced the front universal joint?
  104. 1st Gen 2wd 5spd Pickup - Will only shift 1st & 2nd!
  105. old toy diesel in 2nd gen runner
  106. 90 3.0 tries to die at idle. help!
  107. Auto shift lags at 40
  108. Charge & brake lights flash
  109. Need advice on buying a new head or not???
  110. problems after swap
  111. Good Idea? Smoothing out the sharp edges in the intake & exhaust ports - 3VZ-E Heads
  112. Getting Boned By The Shop
  113. Another leaf spring install question...
  114. Wanna see 46" tire on IFS?
  115. HG repair update
  116. will 87 4runner sunroof fit 86 pickup?
  117. New tires, help me decide
  118. Zerk on U-joint?
  119. timing chain rattle
  120. Getting a 4runner!
  121. Brake Light Question
  122. Fan clutch rebuild?
  123. how much lift to clear 32x11.50 on 89 4x4
  124. roof rack on a p/u
  125. Rookie Question: New 22R Too Noisy?
  126. *nebbie* my truck
  127. Rebuilding 86 22R-TE
  128. finished my 90 sas(pics)
  129. Help - Motor won't run
  130. 4 low problems/a340h
  131. My "new" 4Runner
  132. 95 4runner blown head gasket and possible engine swap questions
  133. K&N FIPK w/ISR MOD noise issue
  134. truck wont brake smoothly.
  135. oil pressure guage constantly reading maximum
  136. YES, I'm new to Yotas
  137. Sliders - Welded or Bolted? Why
  138. battery dying
  139. looking at a 89 3.0 5spd with 273K mi.
  140. 94 3.0 running hot.... sometimes
  141. Ball Joint spacers.
  142. w56 rebuild questions
  143. Weasy2k cams installed!
  144. steering question
  145. 1993 T4r Part-out!!!
  146. Auto Tranny Trouble
  147. TRD Brake pads
  148. Dumb ride height question...
  149. Low Oil Level Symptoms
  150. Aftermath of my heinous 22RE destruction
  151. truck sliders
  152. Front Diff seal replacement while in truck?
  153. Cleaning EGR Valve?
  154. 3rd swap question
  155. 3VZ-E Valve Job, Any problems with grinding the valve tip rather than buying shims?
  156. Do you think i got taken or is $60 worth it
  157. What would you do?
  158. 22re Knock sensor vs 3.0 knock sensor
  159. Manual Transmission Rebuild Kit!?!?!?!?!
  160. Best brake pads for drilled/slotted rotors?
  161. ? Downey truss w/budbuilt skids
  162. Rear Axle Swap 99 taco
  163. Motor smothering down
  164. A good place to order tires online?
  165. New Engine Idle Issues
  166. Bad Radiator symptoms...?
  167. dash clicking with short video
  168. snorkel Top
  169. Fender trim
  170. I cant lock my truck???
  171. Clogged Catalytic Converter?
  172. double locking
  173. more power
  174. power-washing question.
  175. Fuel Issues Please Help!!!
  176. running like crap after warm start
  177. plz help with timming issue ,im gonna die...
  178. Opinions: Shiney Windshield Wiper blades
  179. Whats this on my frame??
  180. All sorts of trouble codes Please Help!
  181. Failed Emissions/Smog!
  182. how much would you pay for
  183. Clanking in engine while cruising
  184. 86 4runner shackle dimensions?
  185. Truck trying to start all by itself!!!
  186. Truck is stalling out
  187. No Compression!!!!????!!!
  188. 1jz supra truck
  189. Base of shifter gets really hot
  190. 88 Reg Cab Seats
  191. Turn signals popping fuses like candy
  192. paint design?
  193. I think I slightly overfilled my tranny.
  194. wheres my fuel filter
  195. CV/Halveshaft Uhoh....
  196. Water proofing!
  197. Air Conditioning - How cold should the AC blow?
  198. toyota off road parts.com
  199. air leak at the injector! What do I do?
  200. 88 3.0 to 22r motor swap help
  201. 22re installation help......quickly please !!
  202. Driveshaft diffrent..
  203. Vibration... umm help
  204. Air/fuel ratio lean. CODE 25
  205. Clock and dome light question!!!!! PLEASE HELP!!!!
  206. Which is the best deal?
  207. front brakes
  208. Puff of smoke at start up?
  209. Sealing up leaky the 3.0
  210. Dexron III or Dexron II
  211. SP BBQ in Folsom, CA (56k NO)
  212. ATF or gear oil for a transfer?
  213. hg blown
  214. Manual hub stuck in (free) position
  215. Fixed my squatting problem.... and....
  216. 82 4spd on an 86 22r...will it work?
  217. Fuel Pump
  218. will a 83 22r fit in 86 runner
  219. A/C Issues, won't engage (get cold)
  220. EGR Fake
  221. CEL on 1991 Truck
  222. tail gate
  223. um think something is wrong
  224. Alignment after lower ball joint replacement.
  225. Half Doors in California
  226. flex fan worth it?
  227. Can Front Leaf springs be used in the rear of IFS?
  228. Hubs
  229. New Meats and Bucket Seats
  230. Clunking on wheel lockout...
  231. Pictures in the park!! photoshoot!
  232. should i buy new fuel injectors
  233. My 90 runner won't track well on the hwy. It's all over the road. Fix?
  234. Brake Question: Can you lock 'em up on pavement?
  235. Installed my new tube doors
  236. 22R oxygen sensor check connector
  237. 90 lift
  238. Slushbox rebuild
  239. Sell The Swampthing?
  240. Starter Problem
  241. Funy Idle from my 87 22re runner
  242. Used 3.0 Headers on eBay Item #170114266230
  243. 4 runner top
  244. pulling timing belt gear off crank? 3VZE
  245. "TESTING" cv joints
  246. What's the best way to get rust/crud out of a 3VZ block?
  247. i think ive got it
  248. axle
  249. Need some lift help! will this fix itself ?
  250. Rocker noise
