Starter Problem
Old May 25, 2007 | 06:35 PM
GaryBee's Avatar
Starter Problem
Before I replaced starter on my 92 5 speed v6 4 runner I would have to click the key several times before the starter motor turned. As it was getting rapidly worse I decided to replace the starter.
Now that I've replaced the starter I can't get the starter motor to turn at all. When I turn the key I can hear a click which I believe is the solenoid, so I'd then expect the motor to engage. I've seen some discussion about the clutch switch but if that were the problem then I wouldn't expect the solenoid to work.
Does anyone have any experience with this problem?
Old May 25, 2007 | 06:39 PM
reyna12's Avatar
battery charged? cables in good condition? no corrosion?
Old May 25, 2007 | 07:26 PM
KevinInSac's Avatar
I'll be able to tell you tomorrow morning. Same scenario: Sporatic starting, Sometimes it fires right up, other times it takes a few turns and then she goes. Putting the new one in tomorrow.
Old May 25, 2007 | 08:55 PM
mtnfreak's Avatar
May not be the starter - see the info at the bottom of this page:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml.
GaryBee's Avatar
Friend came over tonight and we were looking at it and he thinks it is the starter relay that is clicking
Old May 25, 2007 | 09:40 PM
gametom's Avatar
clean your positive battery connection take it apart and clean thuroly
Old May 26, 2007 | 11:58 AM
GaryBee's Avatar
Well after checking out the wiring diagrams I decided to remove the starter and it turns out the solenoid connector was loose and thats all it took
Old May 26, 2007 | 04:17 PM
KevinInSac's Avatar
Nice. Mine went in today no problem, maybe an hours top. I spent more time washing up then installing it I think.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
