air leak at the injector! What do I do?
Old 05-28-2007, 05:43 PM
Lifelongtoy's Avatar
Exclamation air leak at the injector! What do I do?
What the hell do I do? I tried pushing it further in, but nothing changed. It took me weeks to find the leak only to find out this. Can I get a new seal or somethin'?
New injectors are way too much.
Old 05-28-2007, 07:30 PM
TNRabbit's Avatar
There are four different seals on an injector.
Old 05-28-2007, 07:50 PM
Staff
DeathCougar's Avatar
4? should only be 3....which is the 4th?
Old 05-28-2007, 08:13 PM
can I replace the seal, because the injectors are at least 10 yrs but they work fine? Or maybe I'v gotten use to them, whatever. I'v told myself in the past that if I replace one, I'll do them all. I just ow it to the old red man.
Old 05-28-2007, 08:26 PM
Staff
Depends on if the injector itself is leaking, or just the seals around it.
if its just the seals around it, replace all 3 seals per injector. And buy them from Toyota. Some aftermarket suppliers wont even have a clue what you mean, and will ARGUE with you and try to say they only have 1 or 2 seals.
Old 05-29-2007, 12:02 AM
TNRabbit's Avatar
4 Seals:
1. O ring at the very top of the injector (where it goes into fuel rail)
2. Seat directly below that
3. O ring at the bottom of the injector
4. O ring on the outside of the injector seat (bakelite surround around the injector)
Old 05-29-2007, 06:34 AM
All right, I guess I'll replace those seals. Thanks
Old 05-29-2007, 07:22 AM
CILO's Avatar
Dumb question,
How do you find a leak in an injector?
Old 05-29-2007, 07:38 AM
The leak is reeeaaallllyy loud. So using a little home made listening device, I was able too locate the leak.
Old 05-29-2007, 11:43 AM
Where could I get new injectors. Good ones
Doug4320
03-24-2018 10:11 PM
raptor510
02-17-2017 07:11 AM
HookahRoo
07-20-2015 07:06 PM
Avenged
07-09-2015 07:55 AM
karbin
07-05-2015 11:37 PM
Quick Reply: air leak at the injector! What do I do?
