cam shaft pulley removal 3vz-e
Old Jun 2, 2007 | 02:52 PM
madvibes's Avatar
I have recently began to rebuild my motor. I am stuck!! I cannot get the
17mm bolts that are connected to the cam off. I have broke 3 rachetts so far as well 2 sockets. Am I an idiot? Wjy wont they come off? I am following the lefty lossey righty tighty. Is the bolt reverse threaded? I asked a toyota dealership and they said that they were normally threaded. please help.. a newb out.... The 17mm bolts hold on the timing pulleys... Incase I was not clear!
Old Jun 2, 2007 | 03:12 PM
rebult junk's Avatar
impact gun
Old Jun 2, 2007 | 03:15 PM
MudHippy's Avatar
Hot wrench (torch) is out of the question there, too bad cause it's my favorite. Penetrants only get ya so far. Got cold chisel? Or...
Stubborn nuts, say your prayers. Called nut splitters.
WOOOOHOOOOO!!!!!!!!!!!!!!!!
1000th post
Old Jun 2, 2007 | 03:38 PM
GSGALLANT's Avatar
Sorry, this was a double post, and I couldn't figure out how to delete it.
Old Jun 2, 2007 | 03:40 PM
GSGALLANT's Avatar
1000th post
Those don't help on bolt heads. The bolts go into a threaded hole in the cam shafts... There are no nuts to split in this case.
Madvibes, get yourself a good 1/2" drive 17mm impact socket and long breaker bar (If you don't have access to a large impact gun). To hold the pulley from turning, you can either use a strap wrench, or do what I do... There are bolt heads behind the pulley that you can see through the openings in the pulley (I think they're 10mm heads). Take a 10mm socket and long extension (6"). Put the socket and extension on the bolt head, and rotate the cam pulley until it's up against the extension. Have somebody hold that while you crank down on the pulley bolts.
Old Jun 2, 2007 | 04:54 PM
justinking060310's Avatar
OK, just did this today -- You all make things harder than they have to be -- Take a long extension or breaker bar with a 10mm socket on the end of it and attach it to the bolt behind the sprocket- it is okay if the sprocket turns - (long enough to rest it on the hood support above the radiator. Next take the biggest ratchet/torque wrench(i use my 30 inch long torque wrench) - or you can use a pipe on a ratchet - and turn the cam sprocket bolt off
I am a 5 foot 10 inch hundred and forty pound woman and I can get it off - You cant tell me that my arms are stronger than yours.
Katie
Old Jun 2, 2007 | 06:26 PM
madvibes's Avatar
thanks
I was able to get it off. I tried to impact guns.. no luck. I then grabbed a snap on breaker bar type 1/2 drive torque thinga ma jig. I broke one more 17mm snap on socket and was able to get it off with a 17mm impact socket. Great it took about 400lbs of arm force plus whatever the length of the cheater bar gained probably around 1600 lbs at the bolt. Thanks for the advice.. Brute force wins again!
Old Jun 2, 2007 | 06:40 PM
MudHippy's Avatar
So the nut splitter wouldn't work huh?(Nice one MudHippy)
How did you NOT twist the head of that bolt off. Broke 3 regular sockets and didn't even strip it. MAN!!!!! YOU GOOD!!!!!!
Old Jun 2, 2007 | 07:15 PM
Lol - I sometimes forget about air tools and their 1000 ft/lb capability
Blamalam
Mar 12, 2022 07:34 AM
Colington
Mar 8, 2020 09:51 AM
TJWilly
Jul 31, 2015 02:05 PM
yoterr
Jul 24, 2015 04:29 AM
dinks07
Jul 15, 2015 05:34 PM
