Ball Joint spacers.
Ball Joint spacers.
I know they are cheap but I have a machinist buddy who will make them for me for free.Anyone have a detailed drawing of the spacers? Also, all I ever see are the upper BJ done.I would think this changes the upper/lower arms so they are no longer parallel? Would it not be better to space the lower down the same amount?
There's a web site www.tkoffroad.com that has a drawing of a spacer. All you need is a ball joint and use that as a template. Thats what I did.
The spacer goes on the upper arm since that is where the torsion bar connects.
- http://www.4crawler.com/4x4/ForSale/...ml#Description
If you put a spacer on the lower ball joint, all you would do is spread the control arms farther apart with no benefit.
Putting a spacer on the bottom would do nothing but drop your control arm closer to the ground.
The spacer goes under the top because thats the only way for it to "lift" the front end up.
then someone put my truck together wrong....
EDIT: yeah i know its dirty but i went through the desert a few times last week and havent hosed it off yet.
kawazx636
Oct 6, 2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
Aug 23, 2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
time to get durty!! woo
