Ball Joint spacers.
Old May 31, 2007 | 03:37 AM
chopitrakeit's Avatar
Ball Joint spacers.
I know they are cheap but I have a machinist buddy who will make them for me for free.Anyone have a detailed drawing of the spacers? Also, all I ever see are the upper BJ done.I would think this changes the upper/lower arms so they are no longer parallel? Would it not be better to space the lower down the same amount?
Old May 31, 2007 | 04:53 AM
Ricer-X's Avatar
I dont think so, i believe the reason they only make the uper ones is bc the point of the bj spacer is to gain suspension down travel
Old May 31, 2007 | 05:49 AM
tc's Avatar
tc
I think it's just easier to do it on the top - all you're really doing is spreading the outside end of the control arms apart, so it doesn't matter if the spacer is on the top or bottom...
Old May 31, 2007 | 07:26 AM
treknwil's Avatar
There's a web site www.tkoffroad.com that has a drawing of a spacer. All you need is a ball joint and use that as a template. Thats what I did.
Old May 31, 2007 | 07:47 AM
4Crawler's Avatar
The spacer goes on the upper arm since that is where the torsion bar connects.
- http://www.4crawler.com/4x4/ForSale/...ml#Description
If you put a spacer on the lower ball joint, all you would do is spread the control arms farther apart with no benefit.
Old May 31, 2007 | 05:55 PM
Robert m's Avatar
then what about the 2wd's? the torsions attach to the lower arm but the spacers still go on the upper ball joint.
Old May 31, 2007 | 06:52 PM
Jay351's Avatar
Putting a spacer on the bottom would do nothing but drop your control arm closer to the ground.
The spacer goes under the top because thats the only way for it to "lift" the front end up.
Old May 31, 2007 | 07:45 PM
treknwil's Avatar
Putting on the bottom mite lower the front, by pushing the spindle up?
Old May 31, 2007 | 08:17 PM
Jay351's Avatar
Perhaps on a 2wd, but on a 4wd it would do nothing.
Old May 31, 2007 | 08:35 PM
4Crawler's Avatar
I'm pretty sure the 2WDs have the torsion bar attached to the upper a-arm as well.
Old Jun 1, 2007 | 02:03 AM
rocket's Avatar
Originally Posted by treknwil
...mite...
Old Jun 1, 2007 | 04:21 AM
Robert m's Avatar
then someone put my truck together wrong....
EDIT: yeah i know its dirty but i went through the desert a few times last week and havent hosed it off yet.
Old Jun 1, 2007 | 10:08 AM
dijlop's Avatar
lol. very nice. thats probally worse than mine. but it rained 2day. finally... time to get durty!! woo
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
