Clunking on wheel lockout...
Old May 25, 2007 | 11:44 PM
Turd Ferguson's Avatar
Did a search, here's the deal and I searched!
Noticed in the past few months that when I turn all the way to either side and am moving (slow speed, full lockout), I get a clunking sound from the left front. I replaced the bad outer wheel bearing Thursday, repacked with grease, and hit the zerk on the top of the A-arm that can sometimes cause some rubbing sounds.
Still no good. Anyone want to guess? I had the steering arm recall done a year ago. BTW, this occurred before and after I switched to manual hubs.
Old May 25, 2007 | 11:51 PM
2WDoffroadx's Avatar
Are you sure its just not the steering stop that is on the bottom control arm that just prevents your tires from "over steering?"
Two metal objects will collide, if you make and movement with them, you will hear a horrible shreak or possibly "clunking."
Old May 26, 2007 | 08:30 AM
budddavid's Avatar
bump, i am having the same problem
Old May 26, 2007 | 08:16 PM
Makes perfect sense to me, tomorrow I'll put it at full lockout and take a look to see what's possibly rubbing.
Old May 27, 2007 | 10:54 AM
Alex 400's Avatar
I had that same problem, just put a bit of grease on the the metal bumpstops on the a-arms and it will pretty much go away if that is truly the problem.
Old May 27, 2007 | 06:07 PM
KevinInSac's Avatar
Often time PS pumps seem tp whine at full lockout too. I haven't experienced it in my truck as I try to avoid full lock out. I go a little before full to play it safe.
Old May 27, 2007 | 06:37 PM
dijlop's Avatar
mines turns just fine at full with pressure on it and everything. of course when i go over a bump or anything at full turn, regardless of speed, my suspension creaks like crazy. lol. leaf springs are rubbing or something. sounds nasty. however, full turn no problems for me. i think turnin it full and checkin it out is gonna be ur best bet. if u dont see anything maybe leave it in nuetral and just rock it a little, get it too move and check if ur rotation changes any.
Old May 27, 2007 | 06:44 PM
Brendan's Avatar
i'd bet the bank that it's the steering stops. you can get plastic caps from the dealer but they are very overpriced. greasing the stops every month or so will yield the same result/
Old May 27, 2007 | 06:55 PM
yotasavg's Avatar
X whatever on the steering stops. it happens to the best of our trucks.
Old May 27, 2007 | 07:36 PM
Is that the zerk thats on the top of the A-arm or another I'm not seeing? Thanks.
Old May 28, 2007 | 05:19 PM
Brendan's Avatar
Old May 28, 2007 | 05:21 PM
Jay351's Avatar
And don't forget there is 4 of them, two on the front and two on the rear. I only did the fronts and it still made noise.. *doh*
Old May 29, 2007 | 12:24 PM
tombothetominator's Avatar
i just grease em every time i do an oil change. otherwise i get a mixture of popping and squealing when i turn the wheels all the way.
Old May 30, 2007 | 05:42 AM
You rule.
Thanks. Commencing greasing tomorrow when I change my oil! 167K strong...
greyheadedguy
Aug 18, 2015 10:40 AM
Up&Down
Aug 5, 2015 06:20 AM
gillesdetrail
Aug 3, 2015 04:43 PM
ripp96
Jul 25, 2015 02:32 PM
skoti89
Jul 6, 2015 07:45 PM
