PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 [185] 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Help with my 22re engine please?? details inside.
  2. does a sas ride bad?
  3. cb radio power
  4. Noisy Tranny, 5 spd 4x4
  5. Interesting finding about knock sensor
  6. Check engine light
  7. wire trouble...EFI fuse blowing
  8. well though i had it but it still broke!!
  9. vacuum sound
  10. 91 4runner: does steering intermediate shaft slide back?
  11. axleshafts/Birfs/etc
  12. Hard starting when warm
  13. LPSV Load Sensor Shackle Help Needed
  14. What did I break now?
  15. Stupid emissions crap
  16. 94 4x4 not engaging...please help...
  17. need hep to find shifter
  18. checking for vacuum/exhaust leaks techniques
  19. 3.0 head gasket
  20. throttle jurk
  21. Another super-sweet issue...
  22. Auto to Manual swap.. i blew auto tranny
  23. Finishing head gasket job, missing fuel hose from plenum
  24. What is this part?
  25. Coolant temp help needed! *Pics included*
  26. The surge is back...back again!
  27. 22re thermostat
  28. variable cam timming gears for 3vze
  29. SAS down the drain
  30. Question About Ignitors ?.
  31. identifying intake manifold type
  32. Starter contact help needed!
  33. t100 SAS
  34. How much time do I have??
  35. Intermittant Idle Stumble in Traffic
  36. 1986 Pickup Problem
  37. "Stock" 2nd gen runner owners - can you take some measurements for me?
  38. 94 rack and pinion replacement
  39. Shocks for Stock 4Runner?
  40. 1991 4runner build ??'s
  41. where are you mounting your gauges?
  42. Where can I find a speedo cable...
  43. Anyone who has ARB snorkel install...
  44. 20$ Onboard Air!
  45. engine light comes on and the motor acts up
  46. Can-Back exhaust??
  47. 4.0 as a swap for 3.0???
  48. Taco Axle Swap??????
  49. TPS settings/ problem
  50. Truck ticking / timing Chain
  51. Ignition problem no start
  52. Door rubbing
  53. 3vze miss issues
  54. Mods that make others go hmmm...
  55. 22re cam...
  56. 22re wont fire...low compression?
  57. 22re help !
  58. 1990 4runner Tranny problem help ASAP please
  59. this wiring
  60. Aftermarket Spark Plug Wires
  61. Low idle
  62. putting my non-sr5 speedo back in, what are some good places for aftermarket gauges?
  63. Disc brake is dragging.
  64. so you think these are bad? *pics and video*
  65. Wheel Bearings making noise
  66. ifs hub, disc, spindle
  67. adjusting rear brakes for new front brake pads
  68. Sas Swap
  69. Coiled Toy ala ZUK.
  70. Senior Picture w/ the money pit
  71. Where to buy A/C suction and discharge hoses?
  72. 22RE AFMs interchangable?
  73. What Motor???
  74. 5 series gears and 33's.
  75. Bent IFS 4x4 LCA mounts?
  76. One Last Time
  77. cadilladic converter noise
  78. help with engine light
  79. *PICS* How Does This Thing Come Off???
  80. FREE BEER round #2 and I'll pay you...
  81. Whats the best Slider out there?
  82. Re-gearing diffs
  83. shaking is driving me crazy!!
  84. free beer (for intermittent wiper help)
  85. Replica Ivan Stewart 1st Gen 4runner
  86. Headlights won't turn on????
  87. possible HUGE problem with front diff
  88. FSM question
  89. from 268 to 261?
  90. another exhaust question.
  91. Local machine shop near allentown/kutztown
  92. HELP!!! problems with locking hubs
  93. fair price for selling running boards and flywheel
  94. Please help!!! I Wanna lift my truck.
  95. just got another rig
  96. Weird cooling problems
  97. Pics of newly mounted 33X10.5
  98. 91 4runner finally parked for rebuild
  99. Gear RPM Difference?
  100. Help: Idle and Power Problem
  101. Need help finding hoses on Toyota V6 Engine
  102. 90 3.0v6 manual/diagram
  103. Gears!!!
  104. Starts then sputters dead
  105. Spark Plug Socket Size 22RE
  106. Limp Mode
  107. which shoulder bolts
  108. Cruise Control Not Working-1995 4Runner
  109. 4-runner removable top on 89 pu
  110. 3" rear lift and cranking torsion bars ??
  111. Has anyone ever try this stuff?
  112. valve adjustment
  113. 33's come tomorrow
  114. Oil Pressure Gauge??
  115. 1991 V6 water outlet bolts.....help!
  116. Mystery Gasket INSIDE Rad???
  117. 1987 4runner help needed ASAP
  118. Scuba's 500ff Install.
  119. Random Intake and TB Question...
  120. Knock sensor wire missing in action
  121. Tear Down Of The A340H Chain Drive T-Case
  122. how many warning lights on dash?
  123. Drilling out rivets and repairing the holes
  124. 85 4runner in Oregon $1000
  125. Detroit Truetrac LSD facts and Information
  126. Replacing worn out leaf springs
  127. 90 Sr5 Rebuild Paint Everything! PICS
  128. Just about had it (sputtering issue)
  129. brake warning light on
  130. buddie has a question
  131. 88 Runner Heater Warm only when driving?
  132. Weird electrical issues...
  133. Big THANKS to ABECEDARIAN!!!
  134. 4runner roof rack on truck?
  135. body lift completed
  136. In-fender snorkel
  137. Brand spankin new California SMOG legal exhaust - $482
  138. Power Steering Leak 3VZE Auto
  139. temp gauge question
  140. nerf bars or nothing?
  141. What a find.
  142. rtv type
  143. please help me guys and girls!!
  144. 95 4runner with blown headgaskets
  145. Help with TPS...
  146. High Idle 22R
  147. Question about Aisin hubs...
  148. Water In Cab
  149. Heated Oxygen Sensor help needed
  150. Need Help!!!!!
  151. hold back in 4lo
  152. $300ish...
  153. Upgrading fuel injectors
  154. Rain + Snorkel = ?
  155. for the first time in 3 years, my rig overheated!
  156. What transmision?
  157. Newbie! Need lift suggestions
  158. 89 4runner 3.0 to 20R swap.
  159. question about ECU's
  160. Is this a factory LSD???
  161. cold start sensor
  162. Snorkel?
  163. How many Sensors are on a 4runner, can you name them
  164. body lift issue
  165. Fender glue?
  166. What controls the Oil Sending (idiot light?) For the 4runner
  167. Buying a new engine, help.
  168. Clearing up some sway bar questions
  169. who do you trust with injectors?
  170. Help Building A Toyhatsu
  171. Gaskets
  172. Broken 2nd gen rear folding seat pull tab
  173. woo woo shes flooding
  174. Finished applying POR15 to floor
  175. Hey what parts do i need?
  176. Larry Kitahara - Yodaman ? DIRTSPORTS - Flatbed
  177. need help please
  178. Sas Help!!!!!
  179. parking brake locked up 1991 pickup
  180. Looking for some verification
  181. Wiring a brake controller in an '89 4Runner
  182. rings
  183. Rough Running '86 22RE
  184. I'd like to know what cam you got....
  185. getting BAD gas mileage
  186. Tools need to reach cylinder head on 3vz V6
  187. 1994 4 Runner With Oil Problems
  188. truck jerks to the left or right..cant figure out
  189. Loose gear auto gear shifter
  190. transmission
  191. strong exhaust smell?
  192. Front End Noise - 95 4Runner
  193. fullsize spare on my 4runner - need advice!
  194. Changing an inner CV boot
  195. Oh snap! No start!
  196. 22re puffs white smoke new engine!
  197. Lets play a game, where do these wires go?
  198. Problems please help!!!!!
  199. How the *$%# do I repair this??
  200. IFS & 35's!
  201. another 4Runner fiberglass build ..
  202. Pics of Downey IFS Front Truss anyone?
  203. auto trans sucks balls
  204. replaced my universal joint today
  205. Need rim setup info for the lift I have
  206. rust on top of piston
  207. Radiator won't quite work with shroud/5 speed swap question
  208. Lumpy Tires
  209. How to ID transmissions and t-cases
  210. Suggestion on a 91 pick up
  211. Warn rock crawler front bumper
  212. removed K&N, thoughts on back to stock
  213. Those having trouble with there trucks not starting.
  214. 86 Carburated Pickup Power Adders?
  215. Mud on my truck
  216. New Color, Flat Black!
  217. ok im a idiot.....
  218. sas swap for RHD?
  219. crashed my truck last night, help?
  220. Searched, NG. Rear Axle seal replacement?
  221. Are truetrac LSD's worth a S%*$?
  222. 87 Runner brake problems
  223. "Bo-bo" question of the year?
  224. Ebrake Issues
  225. Engine Head Gasket Dilemma!
  226. Idle cut off solenoid bolt? Weber 32/36
  227. Dream has came true.....
  228. 22RE Ticking Noise
  229. coolant spitting out of radiator
  230. poor idle, what cold start sensor haha
  231. 2 broken runners.. need help focusing and trouble shooting.
  232. 1st gen to 2gen 4runner ?'s
  233. 80 series coils.. which one goes where?
  234. Where to buy Prerunner bumpers?
  235. My 92 4runner and summer fun ride!
  236. passenger seat help "cable managment "
  237. chunks in my trans fluid... oh joy...
  238. Clutch not entirely disengaging.
  239. T100 Axle in my Runner ?'s...
  240. intake air temp sensor
  241. turning brake rotors?
  242. is it ligit?
  243. The search begins!!
  244. Broken Door Locks
  245. offenhauser intake question
  246. auto to manual swap questions
  247. Towing advice for '89 4Runner w/ 22RE
  248. oh god here comes another huge expense
  249. Tire size ?
  250. Rear end suspension help!
