Drilling out rivets and repairing the holes
Old Oct 8, 2008 | 02:42 PM
Monochrome's Avatar
Hello again, I am asking for some advice regarding body work. The previous owner of my truck installed diamond plating along the lower body. It is a six inch strip that spans the entire side of the truck -- front quarterpanel, door, bed and rear quarterpanel. It is attached by very small rivets every six inches or so, each rivet head is smaller than a pencil eraser. There will be approximately 15 very small holes on each side of the truck when I remove the rivets, so about 30 small holes total.
My question is about the repair procedure for filling these holes. From what I understand, the best way to repair the holes would be to weld a small amount of metal and grind it down, then apply a small amount of matching paint, then buff and wax. I don't have access to a welding machine and do not want to pay to have this procedure done. What other options do I have for repairing the holes and preventing rust? I have heard that applying a small dab of JBWeld would work, but I am inquiring here to seek your advice.
Old Oct 9, 2008 | 08:06 AM
annoyingrob's Avatar
Are the holes rusting at all?
If not, a little fiberglass in the hole, sanded smooth, and you're good.
Old Oct 9, 2008 | 08:31 AM
littlecommando's Avatar
BONDO!
it sounds like there small enough to fill with bondo, smooth and paint over it
Old Oct 9, 2008 | 09:35 AM
Monochrome's Avatar
Thanks guys, I'm going to try this out later and I will definitely post the results.
Lons81
Nov 23, 2015 09:25 AM
TransAmBandit
Sep 20, 2015 06:08 PM
Kytowboater
Sep 17, 2015 11:17 AM
mdh
Sep 15, 2015 12:12 AM
