valve adjustment
Old Oct 9, 2008 | 12:56 AM
joshuapc's Avatar
valve adjustment
Im planning to cure the damn valve tap coming from my 22re engine. i was just wondering how difficult this is and would i have to change the gasket?
thanks
Old Oct 9, 2008 | 03:20 AM
jason191918's Avatar
For what it's worth, change the gasket. I have never done this before, but I know that adjusting the valves on a 22re is A LOT easier than doing it on a 3vze.
http://www.ncttora.com/fsm/1993/engine/7cylinder.pdf
page 35
Old Oct 9, 2008 | 06:01 AM
rusche's Avatar
Piece of cake
All you need is a feeler gauge, flathead screwdriver, and a 12mm.
Use your FSM, you can do it in half an hour.
Old Oct 9, 2008 | 09:40 AM
muddpigg's Avatar
If you do it hot like FSM recommend wear mechanic gloves. I've at times replaced gasket and other times not. Inspect it change as needed.
Old Oct 9, 2008 | 10:14 AM
INFINITY's Avatar
that is one thing i hate about the toyota 20/22r motors, having to do the valve clearances hot. i wish they were like honda, and you did it cold
working over a hot engine sucks.
but yea it is easy
Old Oct 9, 2008 | 10:46 AM
Matt16's Avatar
I personally to it bare handed, gives you better feel for what your doing when sticking in the feeler gauge. But yes, it sucks burning yourself on the hot bits. I love the smell of hot engine oil though. Its a real sensory experience.
Old Oct 9, 2008 | 11:47 AM
MMA_Alex's Avatar
oh its not that hot!
on a 22re its easy, do a search there a ton of threads with tips.
Old Oct 9, 2008 | 12:19 PM
Matt16's Avatar
No, to burn yourself, you'd have to rest your arm on the head for a second or two, ample time to pull away if necessary.
Old Oct 9, 2008 | 04:04 PM
abecedarian's Avatar
and depending on your engine mileage, the only way to get the valves' adjustment set to a truly accurate warm measurement is with a new set of rocker shafts, or at least rocker arm inserts/bushings
you may be able to get the valves adjusted properly, but with high-mileage slack in the rockers and shafts, it's still going to tap-tap-tap forever... just like some volvo 240's I've run across.
have fun.
Old Oct 9, 2008 | 09:54 PM
joshuapc's Avatar
well i guess ill just change the gasket since ill be in there. hopefully i dont find any other problems!! so how hot would i have to run my engine in order to do the adjustment properly?
Old Oct 12, 2008 | 08:28 PM
joshuapc's Avatar
how long should i run it to get it hot?
Old Oct 12, 2008 | 08:34 PM
til it's hot
Old Oct 13, 2008 | 12:16 PM
blackspyder's Avatar
approx 180-190 deg. F (running temp). Let it run till the Fan cuts on then you're good to start working. It took me 10 min to do mine (but I've had too much practice). You're gonna have to replace the Valve Cover Gasket, I had just put one on mine a month prior to doing the valve set and it had already stretched too much to reuse. Cursed thing was $15 at AAP with the Gromets
Old Oct 13, 2008 | 01:15 PM
joshuapc's Avatar
damn it must be pretty hot are to work with! well thanks everyone!!
Old Mar 8, 2009 | 03:09 PM
joshuapc's Avatar
well i did the adjustment and it went away a little but the tapping still happens. im wondering if its my timing chain? any body found their tapping to come from the timing chain????
Old Mar 8, 2009 | 03:56 PM
toyota4x4907's Avatar
Like Abe said, you pretty much cannot get rid of the valve tap without new rocker arms or bushings. Just live with it. Its what makes out 22res unique Mine was horribly loud, even after adjusting them 4 or 5 times last summer.
Well, if you think its your chain, take the VC back off and make sure you still have timing chain guides. How many miles does your t-chain have on it? Its supposed to be replaced every 130-150K miles regardless of whether it has metal guides or not.
Old Mar 8, 2009 | 04:51 PM
arizonaguy's Avatar
valve adjustment
who says they have to be hot that isnt true at all
Old Mar 8, 2009 | 05:06 PM
raydouble's Avatar
Did you look down the chain case when you had the valve cover off?
Old Mar 8, 2009 | 07:36 PM
874runnersr5's Avatar
if it looks like this, time for new guides
Old Mar 8, 2009 | 07:48 PM
Most everything "official" I have read says you have to do it warm. and it makes sense. Think:
Metal expands when its warm. If you put the valve lash into spec when its cold, say .012 for intake and .008 with exhaust, then warm it up, the difference between the rockers and valves with be less. Of course you could do it when its cold, but I would take into consideration the amount everything will expand when it warms up.
