- New 22RE
- Who can guess what happened here?
- Tps swap gone awire pleez help
- power windows?
- Downey truss install problem.
- need help with hubs
- Write up, how to remove your 3rd member with pics!
- 93 4runner lift?
- Wheel offset and backspace
- Question for the ROLL ON PAINT experts (if expert is the word)
- 22RE headache, won't rev
- Need your help if I should buy this 95 4runner w/no head gasket campaign
- valve clearance with dif cam?
- Blue Loctite Performance on Wheel Spacers?
- water pump hole
- removing injector rails on 3.0
- muffler system
- Spotlights
- wooohoo
- Toyota Pickup Vs. 4Runner
- 4.88 gears for $500 bucks is that a good price???
- Oil leak
- my 4runners on tilt!
- AntiTheft devices
- 3rd gen pickup canopy question
- Best deal on remanufactured engine
- TPS got me stumped.
- Wheel Spacers: Good or Bad?
- Best deal on OME leaf springs?
- 22re lost timing?
- More work on the 4runner.....
- code 21, 88 pickup help!!!
- Pics of 22re cruise control throttle linkage?
- 1990 4runner 3vze
- Sunroof replacement
- stumbling during acceleration
- Solid Rear Benchseat in my '87
- wheel fitment
- Factory paint isn't supposed to crack...
- any way to make the center bore on rim bigger?
- Speedometer is Way Off
- 4Runner w/ 22RE - temperature sensitive - low power, stuttering, surging, bad idle
- aux fuel tank 1st gen runner
- Charcoal Cannister Fuel Leak
- power steering/ timeing?
- Massiva oil leak from valve cover.
- 1994 truck 4X4 V6, oil leak ????
- Taurus E-fan idea.
- Will 2002 4runner seats bolt into '87?
- 22re idle speed?
- SR 5 instrument cluster swap... adjusting the tach
- 4runner top
- need help with my new 92 4runner sr5
- hard time idling when i come to a stop
- official color of toyota
- Goodbye engine.
- bleeding the power steering system??
- Free time and paint
- leaking headliner
- Paint Prep on 1st Gen 4Runner removable top
- my truck isnt running right. boggs down
- still need timing help on 3vze!!!
- 22re idle screw
- 22re sputtering only when accelerator is held steady.
- seat swap?
- #3 cylinder makes no difference, HELP!
- not sure if i have lockers
- 22RE Not running Right?
- What much $ is my runner worth, 4 insurance purposes
- gearing / 3rd replacement question and tire size help
- Overheating Auto Tranny
- got the old girl some goodies...
- Headlight conversion complete
- selling camper shell?
- No power to fuel pump after blowing fuses
- 22re throttle stickin
- 22re valve cover grommets
- Transmission Mount Bad?
- coil overs on stock a arms?
- 94 4runner Won't Ignite...
- Making my 4x4 a 2wd?
- nice TRD! Good Buy?
- Bumper Vote Please
- Wheel bearing shot?
- Driveline Vibration driving me crazy!!!
- oil pump help needed asap
- what do i need for a 3.4 swap?
- Rear axle swap question
- Looking for bumper!
- 87 motor in an 85?
- 89 4runner oil leak !!
- 22RE warm idle issue (yes, again!)
- 94 4runner with broken elocker ?
- Sourcing a parking brake cable
- Transmission Problem
- no fuel in filter???
- 90 PU body swap to 84-86 body
- Cruise control acting up
- Front Drive Shaft
- Drive shaft solution?
- What's is with these hubs?
- Head gasket blown, what to do next. Need Advice
- Timing cover with the head off
- stupid arguement, "Is a Detroit Soft Locker" really a locker?
- thanks to the forum
- Panhard drop and roll centre (calling TC)
- A/C compressor not working
- my enblew up 3vze v6 engine..i need to fine a nother one
- 88 toyota pickup problems need some help
- 93 4 runner
- Vacuum lines, EGR, can I remove this valve?
- cv axel not coming off
- blower resistor?
- overheating and revving problem
- towing a load
- tps and timing on a 3.0
- 35's/37's on IFS?
- Misfire at about 2500+RPMs
- Stiff gas pedal?
- 3.0 air intake
- Questions after i swapped my 3.0 3vze
- ball joint spacers is this really a good idea
- "G" Series and "B" series axle codes
- Rolled my truck. Fix it or swap parts?
- sub box
- turbo'd truck issues! fuel cut or just not enough?
- Rough time starting my truck! help!
- semi permanent adhesive?
- What carburetor kit?
- gear ratio for 86 4runner
- Oil pan baffle plate bendage
- well ok, I'm confused... AC Idle-Up VCV
- new radio, factory amp
- New Pics of 4runner with MC Bumper, Fender Flares and CB radio
- What size are the rear speakers in an 88 4runner?
- 91 4x4 pickup 22re won't pass aircare??
- Got my straight axle today
- fast cold idle
- This 92 look brand new I am not kidding.
- '91 Pickup tailgate replacement
- timing on 22ret
- 33/12.50 v6 5spd 5.29?
- 86 22RE-poor mpg and CEL...help
- help with can of worms project
- Bad Ect???
- steering/brake help!
- Its happening..
- cv shaft replace or not
- 89 4runner seats...
- Question
- Reliability - 1,000 mile road trip?
- electrical/starter problems
- 22RE Throttle Position Sensor worn out. what now?
- guess what, anopther 22re running bad!
- 1988 Toyota Pickup ECU Question
- what the heck?
- 93' 4runr
- Body Lift.
- Starter fix
- Removing Overloads from OME springs
- 22RE running rough.
- Goofy thud or clunk.
- 95 4runner problem
- Cooling and the 3VZE
- gear brand
- Overdrive Grumble.
- all ideas welcome
- 3VZE Yosemite Wish I had More Power pics
- 22re head is too tall????!!!!
- any advice
- 3.0 lagging
- took the truck to the mountains...not good
- rebuild questions
- Transmission electric plug
- Sounds like backfiring amongst other issues...?
- Dry and wet compression test results, need some insight from the experienced
- headlight wiring following 4crawlers diagram question
- Ifs 7.5"???
- Not getting any power to blower motor
- Shock lenghts info needed
- My 4Crawler 1" body lift installed w/ pics!!!
- excesively high idle. Help PLEASE cant figure it out
- I cant remove the rotor from the wheel hub.
- Retrofitting a OEM roof rack?
- NBC Story on Toyota Recall
- Fibreglass Box..
- 22re Rough Warm Start
- 88 4Runner leaf springs
- speedometer stopped
- Self made BeadLocks?
- is it just me or do yotas have pretty wide steering radius/
- A/C Idle Up VSV works, when jumpered! Little help please...
- tranny questions please help?
- front LSD?
- damaged sun roof
- putting in electric windows and locks
- What ECU to use?
- What Else to Do When replacing the Front Main Seal/Oil Seal
- Sunpro Super Tach II Installed! (With Pictures)
- Is it worth it?
- moon roof not working need tool?idk what tho
- Solutions for Rusty Bed
- backfiring/hesitation/cuttin out
- 87 pu auto transmission not shifting to low at stop
- axle question
- No Idle up when under load
- time for new hubs (87 4runner)
- AFM to MAF
- head gasket holes
- shock help please!
- cold starts getting worse
- Ignition referance signal?
- Anyone know of a shop capable of rebuilding a 3rd in my area?
- throttle cable or throttle body?
- 4x4 manual 5 speed oil capasity
- How To Check Fuel Pressure
- 22RE High Idle Question/problem (need help please)
- Is this a sign of a BENT valve or just a stuck one.
- Dieseling 22R
- My 22re vid
- strange noise coming from clutch
- Fluctuating Timing
- Donations to paint my truck pink!
- Radiator fan blew up????
- Possible Transmission Issues - Let's play online diagnosis!
- Poor mileage and uphill driving
- 22re, back pressure/spewing oil
- 93 toyota pickup tranny swap
- 95 runner IFS rebuild kit?
- Painting my Canopy???
- what the heck is that creeking noise?
- Drive Shaft Problem, clunk clunk (Video)
- hoses to intake?
- check engine code 71
- w56 to r151f swap?
- 90 3vz to a 95 3vz
- Trimming for tire fitment on '92 Runner
- troubles removing the freewheel hub. 94 4runner
- How long did your tranny whine/hum until it died?
- 2nd Gen 4Runner w/ 22r -- which heads don't fit, which ones do?
- need help re;testing fuel pump at harness
- Truck Jumps when I take the foot off of the gas
- 87 22r exhaust manifold bolt/stud size?
- Slightly squeaky belt
- Downey Load Leaf replacement
- Keeping it clean
- built 3.4
- 3vze, gassy oil?
- Tap tap tap tap !!!!
