PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 [222] 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Another paint (pics)
  2. new to this forum but wanted to ask some stuff.
  3. por-15 vs tremclad (or whatever) as a rust paint
  4. a recall?
  5. New pics
  6. Aww come on!! New HG - help please
  7. need to know quick please help!
  8. Pics Of My Baby!!!!
  9. Question for SAS'd 2nd gen 4Runners
  10. Flopped my rig now it wont start!
  11. Starter frustration
  12. A/C squeals when turned on, but works good
  13. asap help air conditioning hose???
  14. Slammed Tranny X Member off curb, now have bad vibrations
  15. Can I use these belts? They have teeth
  16. 60/40 seat covers
  17. Swaybars and 4runners
  18. getting new alt, what else?
  19. Custom temp sensor/gauge location on 3vze
  20. wrecked rolled totalled.
  21. rear end play
  22. Cargo Rack Basket
  23. Completed my Truck
  24. pinch weld, sawzall or BFH??
  25. Strange AFM noise. Is this right.
  26. Smoothest ride on gravel / lift kit? Tires?
  27. good deal?
  28. good buy???
  29. Sorry newb question BL stuff
  30. Exhaust!!!!
  31. body parts source
  32. Best 22RE Intake!
  33. Rear Axel Sheared apart!!
  34. Better MPG
  35. Pics of subs in 3rd gen ext.cab trucks
  36. 95 4runner blower not working properly??
  37. Truck won't go into 4WD
  38. Heeeelp!! My 92 V6 just started running terrible
  39. Bolt below camshaft sprocket?
  40. will a 2nd gen trailer hitch fit a 87?
  41. Need a Dyno in Cali?
  42. Machine shop recommendation
  43. bj spacer install q's
  44. 1994 4X4 Toyota Rear End Differential Problems
  45. 33/12.5/15 Cooper Discoverer tires installed on two door 2nd gen
  46. limited budget options
  47. Buying advice...
  48. Can an Old IFS Runner Still Wheel??
  49. Where can I buy vacuum lines?
  50. emissions trouble
  51. ECT power
  52. AC clutch?
  53. Help with mysterious plugs in dash!!!
  54. alternator help please!
  55. Finally got my truck one color!
  56. 2nd Gen 4Runner Wheels:Hub or Lug Centric?
  57. new truck...carbed and slow. any help?
  58. 22RET Bolt On Applications
  59. mystery sqweak from my tranny/transfer case
  60. What is this connector?
  61. Looking for cowl induction hoods...86 pickup
  62. Some pics with 4" and 33s
  63. Water in the box next to air filter
  64. new front bumper with brushguard
  65. Am I capable?
  66. "Hands down the best 3.0 headers on the market"
  67. Question about high output Alternators.
  68. First time startup
  69. front end trouble
  70. Help, no power after tuneup
  71. power window and lock swap questions
  72. mystery plug in????
  73. Marlin seat and socket
  74. whats left for sale
  75. o2 sensor voltage
  76. Light mounts... But off bumper/roof
  77. lift deals
  78. I need a center consel....86 EXT pickup
  79. Line x whole truck?
  80. 94 Pu Sas
  81. Who wants 3vz-e performance? :)
  82. 22re wont start after bj spacers
  83. Katie's Project RedRunner!(very, very, very long)
  84. motor swaping question
  85. New C.B. antenna
  86. old man emu, downey or sway a way torsion bars?
  87. Another lesson I need to learn.. getting hose clamps off
  88. input shaft bearing or throwout bearing?
  89. Pls teach me - Getting the crankshaft and camshafts seals off
  90. emissions tests:bang:
  91. seats in pickup bed
  92. Best IFS lift
  93. New VAFM to cure TC-24. Can VAFM affect timing?
  94. Budbuilt questions
  95. budbuilt skid dimensions
  96. Transfer Shift Bushing
  97. SAS pictures
  98. Clutch Help !!!!
  99. component identification help
  100. got a quick cv axle question
  101. Pics of new lift!
  102. potential power problem???
  103. in need of your feedback: Remanufactured Cardone CV Drive Axle from Kragen
  104. pickup lift
  105. gears for 33 X 12.5s
  106. Exact size tap required for chasing threads for new HG?
  107. Looking for Lug Nuts
  108. Swap a 22RTE for a 22RE
  109. Keep your button, not your buzzer!
  110. w56 tranny with a chevy 350 motor
  111. Rear Leaf Compatability
  112. cylinder clean up
  113. 32 X 11.50s
  114. Small EGR leak on 22RE
  115. Towing Capacity??
  116. Grr lift frustrations
  117. body lifts suck
  118. A/C Problems (unable to charge)...possible bad TXV?
  119. how hard is a 3" lift to install myself?
  120. v6 Aussie locker?
  121. coolant spewing
  122. compression test results ?
  123. flashing o/d light
  124. Post your pics of Rack mounting to Canback tops
  125. Old parts, toss them?
  126. 2 inch lift shackles?
  127. IFS "skidplate" removed?
  128. My Custom Bed
  129. Timing Advance on 3vze
  130. Need parts plz help!!!
  131. No power on hi RPM (3-3.5K and up) on a newly rebuilt 1988 3L V6
  132. Roof rack for 95 4runner
  133. 1986 sr5 turbo
  134. Would you spend $4400. on a 94 4Runner
  135. Camshaft Swap Question.
  136. turbo question
  137. No 2WD high, no 4WD high...Solenoids?
  138. Power Steering Pump and Pulley
  139. rear window troble
  140. Pro Comp shock replacement
  141. 3.0 to 22re swap
  142. speedo cables
  143. water leaking from side of the head
  144. leveling the rear
  145. got new tires!
  146. air compressor recharge $?
  147. "Make sure you use High-Tac on that HG..."??
  148. Understeer / Oversteer issue getting worse
  149. What to buy at 4Wheel parts with $200
  150. Fuel Inj help
  151. 4WD needs lube?? Water ingress??? Help !
  152. Requested Pics of my 4runner
  153. Bouncing 4runner
  154. Performance Products For '01 3.4L Supercharged
  155. Usable Center Console Mod
  156. Got some sliders on
  157. It was time for a new paint job (56k Beware)
  158. Must See!! Amazing Vid Of Why Toyotas Rule!
  159. creek coming from my truck
  160. Just bought a 1990 xcab v6 pickup (questions)
  161. 150,000 Miles Never Looked So Good
  162. If it were your truck...
  163. Transmission help
  164. shock help
  165. Airbox mod for 22RE
  166. Deal on a 2nd gen In DC
  167. Ideas please??????
  168. BJ spacer hold up
  169. Where To Find New Box ?
  170. clicking sound on hi 4 and lo 4...
  171. do i need wheel spacers? [pics]
  172. Gibson headers (I've searched)
  173. Engine swap question
  174. WabFab Bikini top finally installed!!
  175. Fuel Issue on 92 Pickup
  176. 3vze Timing Belt Job
  177. Replace my own alternator?
  178. recomended driveline shop in Portland/Vancouver area
  179. the mysterious disappearing coolant
  180. for 2nd gen. will the tire spare bay(undercarriage) fit a 31" or even 32"
  181. Oil Pan Gasket
  182. NEED a Hood
  183. My Wife Popped Her Muddin' Cherry....
  184. Cracked block or am I missing something?
  185. Central doorlocking- Locks when engieen starts..
  186. lspv problems?brake bleeding trouble
  187. Urgent: My yota Back fires
  188. Torsion Bar adjustment with AAL
  189. Post BJ Spacer driveway alignment troubles...
  190. Rear window light on in First gen, Window won't go up
  191. this bar seems as if it's in my way of wheeling...
  192. marlin vs. downey rear bumper
  193. Water vs Trans Temp Guages
  194. Buying a 1st Gen Runner Need Advice
  195. do i want bigger tires?
  196. anybody can recommend a decent alignment shop in Los Angele area?
  197. So how is everyone's Herculined Panels holding up?
  198. A/C stopped working on my '93 4Runner...
  199. Oh No! My poor baby! Part Deux [2]
  200. Aftermarket temp gauge sensor location 22re?
  201. Lockright is installed in the front
  202. Battery problem
  203. Aftermarket Bumpers
  204. clear lights
  205. just a few questions
  206. Check out this ebay find
  207. Park Brake Wont Engage
  208. can someone tell me how to rebulid my 91 3vze
  209. MAF sensor location on 3VZ-E
  210. My 22re Rebuild
  211. Major Drivability Problem
  212. one final question before install
  213. Painting soon, any quick avdice
  214. Parking break snapped on 92 PUP
  215. Charging troubles
  216. bigger valves and now a Q
  217. 91 tow package on a 87
  218. Reset ECM - Code 24 only one came back Where is the intake air sensor??
  219. custom grilles...
  220. Tacoma bumper on a 89 ?
  221. Ran great for two days...
  222. 3.0 no spark? help
  223. Does anyone know the sizes and threads on the fuel line fittings?
  224. 89 4runner shift boot
  225. 86 4runner fuel pump question?
  226. surf 1995 dead autobox
  227. A/C stopped working on my '93 4Runner...
  228. what 200k miles does to an o2 sensor
  229. need to find load sensing proportioning and bypass valve
  230. Overheating after engine rebuild, Please help!
  231. Taillights eating fuses
  232. compatible beds
  233. Front Output Seal...
  234. 4runner coloring book?
  235. Just bought a 1987 4Runner Need Some Help
  236. 2-door 4runner
  237. CV boot puncture,( need your opinion)
  238. Does this look busted?
  239. swapping alternater help!
  240. 1989 runner
  241. Yota Technican
  242. Brake Fluid level drop and have to pump
  243. CV W/ ABS different from CV w/o ABS
  244. 3vze pwr loss after head gasket change
  245. Chassis Swap - Progress Thread *56k warning
  246. engine will turn but wont start 3.0 V6 1992 4runner
  247. not so Good Vibrations.....
  248. On call again
  249. Suggestions on a front bumper for a 94 4runner?
  250. Do all timing belts have timing marks?
