Reset ECM - Code 24 only one came back Where is the intake air sensor??
One more time...
Reset ECM codes. Only code 24 returned. Can't seem to find the intake air sensor.Running but just seems doggy.
Have looked over the FSM but can't seem to find what I'm looking for.
Safety & blue skies,
DJ
DJ
Yeah, there's a little probe down inside the VAF meter. You can see it through the flapper if you open it up. That's the intake air sensor. When testing the VAF meter, that's the little bugger you're testing against fluctuating temperatures (in the FSM). If it's not working right, you won't get the specified ohm readings. Meaning, well..you know.
zd92655
Mar 6, 2022 12:58 PM
bigblue82
10
Jul 6, 2015 08:27 AM
