Does this look busted?
Old Aug 11, 2007 | 02:53 PM
GA95Runner's Avatar
Exclamation Does this look busted?
does this look busted? kinda does to me...
Old Aug 11, 2007 | 03:16 PM
881stGenRunner's Avatar
looks fine to me. it's just drooped out. Does it make any noises or anything going down the road?
Old Aug 11, 2007 | 03:20 PM
carljwnc's Avatar
Das Boot??? Not yet, no grease spatter everywhere, but will probably be soon. I just did this job a short while ago, might as well be ready to do wheel bearings, and possibly brake rotors/pads as well (both sides, and both boots). Kill as many birds with one stone as possible.
Old Aug 11, 2007 | 06:36 PM
GA95Runner's Avatar
It (something) clicks when i hit bumps on the trail, but not speedbumps, its weird.
Old Aug 11, 2007 | 07:08 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Our '91 PU does the same clicking noise offroad not on speed bumps. I like to know what it is so I could fix it.
Old Aug 11, 2007 | 07:11 PM
drew303's Avatar
I've had that click come from the shock.. my drivers side lower shock hoop skirted off the rubber bushing and is a bit lose and not something you can tighten without just shuving the hoop back on the rubber bushing..anyway it rattles a bit, click click.....bump click hehe
that CV halfshaft looks fine. If it were broke the boot would be torn.
Old Aug 11, 2007 | 07:12 PM
drew303's Avatar
oh and the shafts arent suppost to appear to go directly into the housings.. they spin offcenter a bit, dont ask me why its just how they're designed.
Old Aug 11, 2007 | 07:27 PM
GA95Runner's Avatar
well i do have the original shocks on the beast. i may finally be time to switch em out, and see if that resolves the off road click clack.
Old Aug 12, 2007 | 03:01 PM
scrid's Avatar
bump noise
A friend that had the same noise on a 94' pickup occasionally.
Found out the lower shock bolt was the culprit.
We had to remove the nut to see the damage though.
Old Aug 16, 2007 | 02:13 PM
GA95Runner's Avatar
im on the road for work right now, but when i get home, i will check that out, thanks for the info!
HotNotch
Oct 8, 2015 06:51 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
PBRaddict#1
Sep 22, 2015 07:50 AM
Obmi
Sep 16, 2015 02:13 PM
altydog
Aug 28, 2015 07:01 AM
