Exterior Rearview Mirror Removal
Old Aug 28, 2015 | 03:29 AM
altydog's Avatar
Do you know how to remove the plastic covers over the base of the door rearview mirrors? Mine are not powered. I see a seam between the two halves. Just don't want to bust the plastic. The FSM doesn't explain this.
Old Aug 28, 2015 | 03:37 AM
wyoming9's Avatar
Red face
They just pry off but get really brittle with age and break real easy
Old Aug 28, 2015 | 03:44 AM
AKHeathen's Avatar
what year? 89-95 there is a trim piece on the inside you have to pop off to unbolt it, older, i don't recall, but i see an exposed screw on the front and a skinny cover that slides back to expose the rear screw on my 86.... hope this helps. if you are searching, they are called side view mirrors.
Old Aug 28, 2015 | 07:01 AM
scope103's Avatar
Originally Posted by altydog
... Just don't want to bust the plastic. ...
park it in the sun for a while. Just warming it up to about 80° or so will make it just flexible enough to safely pop loose.
Works the same for old rubber hoses, but I usually end up using a heat gun for that.
Jun 1, 2021 01:51 PM
rusty904
Mar 27, 2017 05:20 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
58rennur4
Aug 4, 2015 08:49 AM
