87 22re fresh rebuild
Old Aug 26, 2015 | 12:41 PM
Ninjoel's Avatar
So, start up the motor and run it at a fast idle to break in the cam. Starts right up and runs smooth. After about 5-8 min, once the motor warms up it dies. Won't start again until it cools down. Can anyone help with this issue?
Old Aug 26, 2015 | 02:03 PM
imhousing's Avatar
I would start with your ignition coil, also check your fuel filter
Old Aug 26, 2015 | 04:50 PM
Ninjoel's Avatar
I checked to see if I was getting spark from my coil an sure enough, it was dead. Replaced the coil and fired her up. Ran longer this time than it ever has. Did eventually do the same thing. I've check every that every play is connected. Is it one of the sensors in the cooling system?
Old Aug 27, 2015 | 12:37 PM
imhousing's Avatar
next i'd go with your distributor. examine for burnt up spinny thing (i forget its name)
Old Aug 27, 2015 | 06:33 PM
Ninjoel's Avatar
Word! Got her going good. Purrs like a kitten. I took it out in the highway and it did have a weird hiccup. It seem that after I was giving her some throttle to get up to speed the engine got stuck at a very high idle for a bit. About 3000 rpm. It settled down eventually. The throttle wasn't stuck. It seemed to be a symptom that occurred after a period of heavy throttle. Any thoughts?
Old Aug 28, 2015 | 02:41 AM
AKHeathen's Avatar
it's called a reluctor ring. egr sticky or bad diaphragm? sticky vafm plate?
Old Aug 28, 2015 | 08:12 AM
imhousing's Avatar
yea you're getting out of my area of expertise (i don't have none of that fancy FI knowledge).
when checking your throttle linkage let it out REAAAALLY slow to see if it sticks
Old Aug 28, 2015 | 09:02 AM
Ninjoel's Avatar
Hmmm. That's a good possibility. I did have to relocate the egr diaphragm. Now instead of sitting horizontal it is sitting vertical. I can imagine how that would cause the diaphragm to stick.
jasonty
41
Dec 23, 2018 01:00 PM
dumpster84
Apr 30, 2016 06:03 AM
coleypull15
Nov 3, 2015 07:41 AM
shisha1999
Sep 21, 2015 08:22 PM
shadowbirdie
Jul 21, 2015 10:38 PM
