PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Need some clutch advice
  2. Rear wiper switch help!
  3. Just got my steering relay rod and bonuses!
  4. 89 3.0l no power under load after warm
  5. ZUK mod users, have you had any sag yet?
  6. Fuel tank part name.
  7. 1987 22RE - I can't find the problem! Help!
  8. EGR plate still leaking
  9. Shifter or clutch problem
  10. stripped head bolt.... reuse gasket?
  11. Dash lights stuck on
  12. 22r vs 21r-u
  13. 94 yota runs terrible
  14. Rhino clutch kit
  15. help please yota bros! A link or form! 95 4runner brake rotor
  16. Rebuilit engine, what should I know before install
  17. Ignition Timing Reading.
  18. 2nd Gen 4runne(1991)
  19. Oil smoke on deceleration
  20. Random Questions and Musings About My '94 (w/ Pictures)
  21. Engine Noise
  22. My new (to me) fender flares arrived!
  23. Power specs on 89 22re
  24. 1st Gen 4runner Cupholder Mod
  25. bore is it worth it ?
  26. 22re 91 toyota WONT START
  27. Replacing tranny tailshaft seal, how hard?
  28. 91 tranny problems
  29. No Btm-end Power
  30. Best way to properly install 22RE Exhaust Manifold Studs?
  31. 90 3.0 not running need help PLEASE!!! ASAP
  32. failed IM test, high carbonmonoxide levels/ new 22re engine
  33. 22re CEL 25 HELP!!!
  34. Sliders with a "drop" step.
  35. timing issue-88 V6
  36. Cooling fan explosion
  37. Clutch cylinders or clutch itself?
  38. 90 Pickup starting running bad over the weekend
  39. 1994 22RE Won't Start. Need Help.
  40. 1987 vaccum and smog removals
  41. problem getting 3vze rebuild to run.
  42. please save my truck :(
  43. Help with torquing Crankshaft Pulley Bolt in SLC
  44. Help! Coolant leak at rear of head or block
  45. Removing rear heater?
  46. 89 4x4 manual trans wiring ?
  47. #2 Spark Plug Won't Seat
  48. Portion of Block behind Tcover....is gone... what to do?
  49. Engine Surges after turning on Heater
  50. Opinions sought on spark plug condition
  51. Cleaned TB Idle surges w/brake pushed
  52. How do you you compensate wear from big tires on sus and steering parts?
  53. new speed sensor = speedometer REALLY doesn't work now
  54. BJ OEM or Aftermarket?
  55. running rich
  56. My first head gasket repair
  57. speedometer drive gear help.
  58. 93 4runner dont know whats wrong
  59. Pulling my motor. Any advice?
  60. E-brake cable - replace or repair
  61. Automotive paint (spray) vs boat paint (roll on)
  62. rough idle after changing timing gears set
  63. ?what type of cruise control this is?
  64. New header....now vibrations.
  65. 3vze code 12?
  66. Fan motor fuse?
  67. "Normal" valve chatter? 22r
  68. Camber off badly after ball joint replacement.
  69. Solid Copper HG
  70. New trail gear rear disco
  71. 90-95 (auto) speedo gears all interchangeable?
  72. BJ Spacers and NO travel??
  73. 4.56 and spool or 5.29's
  74. Swapping back from a Weber to the stock carb
  75. motor locked up
  76. Twisted's GM alternator swap
  77. Pinion replacement
  78. 5th gear whine & Marvel Mystery Oil
  79. Summit Hot Shot or DIY starter button (89 22re)
  80. First gen 4runner rear window rail / track
  81. 1988 Truck, Herculined my cab
  82. w50 and w56 same bellhousing?
  83. Did the 82' Supra AFM swap but truck idles a bit rough.
  84. Are all 3VZ-E's the same?
  85. 22r head bolt order?
  86. 86 4Runner, engine trashed, what years best for swap?
  87. AFM Question
  88. The little tube that sticks out of my skidplate...
  89. Mysterious starter problems
  90. 86' 22RE randomly runs on 3 cylinders. HELP
  91. softopper color
  92. Whistling soudn from brakes
  93. Vacuum hoses and solenoids???
  94. Black Power Side Mirrors For Pickups With Wing Windows?
  95. 1990 oil pressure gauge
  96. Bent frame
  97. Slider Pictures
  98. need help on new mirrors
  99. HELP!!! 4 link problems
  100. 4Crawler idler brass bushings installed, steering sticks?
  101. Just added Bedliner - 88 4runner
  102. 89 4Runner - 3.0 HG blown (fix or replace)?
  103. 3VZ Low Oil Pressure
  104. 89 22re refuses to start, need help!
  105. motor help plzzz
  106. 88 Pickup wont start when damp
  107. Is it possible to set ignition timing while cold?
  108. Main Ground Fell Off, Blue VSV, and AFM questions
  109. Which brand of parts? Best reputation?
  110. help...im scared!! Motor clacking, shaking, and losing power on inclines.
  111. Can I get away with stock shocks with LC Coils/BJ lift?
  112. a/c compressor 3vze...
  113. 94 runner, what to do....
  114. timing chain replacement foul up
  115. knocking sound??
  116. lime green yotas
  117. w-56 transmission swap gone bad.
  118. Installing Wolo 120 Persuader horns on my 2nd Gen 4Runner
  119. Drivetrain Noise.
  120. Won't idle
  121. 4wd manual std cab swap to 2wd auto ext cab
  122. 39.5x13.5x15 iroks...
  123. compression at high altitude
  124. No water leaking from AC. Should I be worried?
  125. Downey aux gas tank
  126. *1988 4x4 ECU
  127. Head qasket problems
  128. Oil Pickup Tube
  129. Engine Pinging. Summer Gas to Blame?
  130. When shut down engine ... coolant start to boiling!
  131. First camping trip
  132. idler arm noise!
  133. Storm damage?
  134. just picked up a 94 truck with a knock
  135. 92 Pickup Engine Swap 3VZE
  136. 91 Pickup Ran Good not not Now So im making IT =0
  137. First Off Road trip
  138. Axle SST
  139. 87 vs 89 parking brake
  140. worst rebuild ever~! Need t chain recommendations now
  141. Front diff removal...again
  142. NO converter lockup.
  143. finally blew it up, time for a new heart!
  144. Trans swap?
  145. Front Differential Issue
  146. Question Re: My (Now) Dead Truck
  147. Front wheel whumping after drive axle replacement?
  148. 94 22re 5spd, surgy idle after warm?
  149. 4:88 differential
  150. Transmission trouble after Head Gasket job.
  151. Can i use this complete 95 pu 22re in my 87 4runner????
  152. Drop hitch did its job!!
  153. Header fitments.
  154. Throttle Position Sensor
  155. Engine gets hot
  156. Pacesetter headers - Anyone have one?
  157. convert a fuel injected engine to a carbureted engine
  158. transmission options??
  159. Drivetrain vibrations killing my ujoints!
  160. Front differential wont turn
  161. '90 4runner a/c problem
  162. headlight help
  163. 4" bracket lift need measurements
  164. Disclaimer: 2nd Gen fuel line leak due to making contact with access panel edge
  165. Pic Request! ATX or AR Mojave on 1st Gen 4Runner - Pics Inside!
  166. 88 22re NO Injector Pulse
  167. New Radiator is not Identical
  168. W56 output shaft in an R150f...possible?
  169. facelift time!!
  170. Electrical System goes crazy when heater fan is on
  171. Any Techniques on Bleeding PS with RWAB?
  172. Pickup Sliding Rear Window Weather Strip
  173. HILUX SURF ln130 2.4 litre turbo diesel part number thread
  174. Electrical Glitches when turn on and off general switches. What could it be.
  175. NEw to the board.
  176. Help me pick out a color scheme
  177. ratchiting locker in front diff?
  178. higher rpm 22re raspy rattle
  179. CV Boot Replacement but autolocking hub cover stuck!!
  180. Odd noise
  181. Engine Break-in
  182. '89 4Runner - Why the Nasty Engine Noise? See video...
  183. My LPSV mod
  184. Transfer case part?
  185. mls with oem bolts ???
  186. Freeing the Load Proportioning Valve
  187. Putting a 22re in a race truck
  188. Newbie introduction with 1990 Pickup
  189. 88 toy. pikup. back left brakes grinding metal to metal what to do
  190. LPSV bleeds but no fluid is making it to the drums
  191. 5vz into an '89 3.0 manual 4-Runner
  192. 86 SR5 get me 4running...
  193. 94 4runner 3vze idle issues..
  194. Where to put seafoam?
  195. Will an 85 22re drop right in a 92 ex cab that had a 22re?
  196. Steering box bolts measurement
  197. 22r-e from 4wd pickup into 2wd pickup
  198. Quick ISR Hose Question
  199. Steering column electrical issue
  200. Lift the rear or drop the front??? Need option???
  201. My daughters new Yota
  202. coolant leak on backside of engine
  203. A very frustrating rear window
  204. weird cold start injector voltage
  205. 22re throttle position sensor problem?
  206. Headlights won't hit brights?
  207. chevy axles
  208. 88 pick-up glassworks bedside build
  209. 3vze power comes and goes.
  210. Install BJ spacers....UCA rubbing on tires....HELP!
  211. Different Rear Shocks?
  212. Sunroof
  213. Front end shaking at most speeds.
  214. Bucking Violently, Won’t Accelerate
  215. Rear Axle Seal R & R
  216. Unusual transmission leak 94 4Runner
  217. Smittybilt front tube bumper
  218. 3.0 surging/bucking 1994 runner
  219. Idler pulley Question
  220. 22re hates water
  221. First Toyota
  222. Added LC Coils and BJ spacers, what about the sway bars??
  223. What are the most commoin 1st gen 4runner brake upgrades?
  224. 22re ac retrofit problem
  225. Nissondenso parts interchange?
  226. K746 Weber w/ Air Conditioning?
  227. Catalytic Converter
  228. Windshield Rust
  229. 87 4Runner 22re hard fuel line replacement
  230. 80s landcruiser axes on a 86 pickup
  231. battery light comes off and on
  232. I need help with my '86 horn!
  233. 1988 4runner uneven idle question
  234. body mount question
  235. 4x4 rocker panels on 2wd Pickup?
  236. 87 1st gen Toyota help
  237. 22re vacuum line ?
  238. Pin Side Mirror Kit???
  239. 92 4Runner, it starts fine, idles fine, has no power to push the truck
  240. New here. Got a quick question.
  241. 95 pickup cant rev above 3000rpm cold HELP!!
  242. Where to get new diff plug gaskets?
  243. HELP..ANYONE...LOST 1,3,5 all dead , no fuel to right bank at all
  244. gas tank drain plug
  245. Good seat covers?
  246. My Gasket's Giving Me Gas! (pics/vids)
  247. Can't read timing marks
  248. Ignitor problem
  249. Code 14
  250. Oil leak then stops
