22re ac retrofit problem
Old Apr 24, 2011 | 04:37 PM
whitebullet3's Avatar
Haven't ran my ac since last summer. Was missing the bracket for the idler pulley. got the pulley installed and went to turn the ac on and compressor would not kick on. Checked to make sure it hadnt locked up. Pushed in on one of the valves on the compressor and there was no pressure. So i figured it had leaked out somewhere. I changed the fittings on the compressor and tried to recharge the system. It only took a couple oz's and the gauge shot up to red, and the compressor kicked off. Now the ac gets some what cold but the compressor will only kick on when its idled up or im driving, and it will not take any more freon. Is this bc I didnt pull a vaccum on the system? Clog in the system somewhere? Ive also heard the valves in the compressor have to be changed when you change it to 134? What do ya'll think ?
Old Apr 25, 2011 | 04:16 AM
coryc85's Avatar
There is an ac amplifier adjustment up under the glovebox on passenger side. I can't remember if you have to remove the glovebox to get to it or not, but it's a little knob you can turn to basically adjust when the AC compressor will kick on.
Old Apr 25, 2011 | 06:05 AM
mldave's Avatar
This might be helpfull..http://img5.pirate4x4.com/forum/show...php?p=12808621
Old Apr 25, 2011 | 08:55 PM
ok but why do you think it wont take any freon? and as soon as i put the gauge on it, it goes to red.
Old Apr 26, 2011 | 09:33 AM
razed's Avatar
guage is connected wrong.
Old Apr 26, 2011 | 09:37 AM
razed's Avatar
are you a certified technician?
Low pressure connection is at the a/c compressor inlet (or somewhere nearby)
High pressure connection is near the a/c accumulator / condenser (or somewhat nearby).
Discharge from your containers so tap is up- container is down.
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
Sandman
Jul 14, 2015 12:36 PM
ryerye13
Jul 14, 2015 08:27 AM
