Please help! Running rich
Old Apr 20, 2011 | 06:01 PM
kzink's Avatar
Maybe one day my runner won't have any problems but today's not that day. Leaving camping on sunday I start my truck and it dies instantly does this a few times then I start it and give it gas get it warmed and it idles low(500) and seems to bounce up a few hundred rpms I have black smoke coming from the exhaust with a horrible smell. When I drive it it feels like it has no power and wants to buck at low rpms. Replaced the air filter, didn't help but thought I should try since there was tons of dust while driving around where I was at and my filter was really dirty. Any ideas before I decided to buy something new
Old Apr 21, 2011 | 07:06 PM
kzink's Avatar
Anyone
Old Apr 21, 2011 | 07:11 PM
cyborg-64's Avatar
catalytic converter
yours is toast. go to a muffler shop and get a new one.
Old Apr 21, 2011 | 07:19 PM
kzink's Avatar
Would gutting it until I can get a new one help
Old Apr 21, 2011 | 07:29 PM
cyborg-64's Avatar
yes
that will help. pound on it with your fist hard and listen for loose material bouncing around in there. pull it out and gut it. then put it back on and forget about it. exhaust will be louder, but who cares? run it hard.
Old Apr 21, 2011 | 08:26 PM
gofar22r's Avatar
hate to say but my wife has the same truck color and every thing. Look toward the afm and tps b4 ya put a 60 plus labor cat on it they are nutten but a heating element to burn off stuff a good worken motor will
Old Apr 21, 2011 | 08:28 PM
gofar22r's Avatar
ohm meter is always better then xhaust work
Old Apr 21, 2011 | 09:36 PM
kzink's Avatar
Well gutting the cat didn't fix it hmm
Old Apr 21, 2011 | 09:41 PM
gofar22r's Avatar
well now you have a 4walker and i dont think g lucas is looken for any one :]
Old Apr 21, 2011 | 09:45 PM
gofar22r's Avatar
3.0 is like a fatty that got skinny got work for it if ya want it good wait ok motor when it works but if ya can get all the chipmuks to work together it is a good tar car motor
Old Apr 22, 2011 | 01:39 PM
kzink's Avatar
Is it possible this is caused by a bad vafm
Old Apr 25, 2011 | 07:06 AM
cyborg-64's Avatar
are all your plugs seated? you hitting on all cylinders? check all the simple stuff. if you drove it in there and it was working fine, maybe you just jarred something loose... i dont know.
Old Apr 25, 2011 | 06:38 PM
kzink's Avatar
Yea I keep checking everything today i unplugged the egr it drove better but still black smoke but the bucking has gone away and I still have a low idle I've also noticed if I remove the brake booster hose my idle goes up to where it should be. Nothing is adding up
Old May 4, 2011 | 07:09 PM
kzink's Avatar
New symptoms I replaced the o2 sensor still no fix thinking maybe it was my vfam so I drove it to my friends a block away and halfway there it started running real bad no power when I hit the gas it was like nothing happened then it started backfiring got to his house put his vfam on and started it it idled high about 1200 but sounded a lot better not like it did before no loping sound then after about 45 seconds it would drop down and die. So I'm thinking it could be the vfam as well as something else? Any ideas
Old May 4, 2011 | 07:10 PM
kzink's Avatar
Oh and when I put his vfam on Im pretty sure black smoke went away
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
