Won't idle
Old May 2, 2011 | 03:34 PM
Joeseph's Avatar
Won't idle
Rebuilt our 22ret in January, and over the last few weeks its been idleing rougher and rougher and coughing pretty hard anytime you try to get up on it. You can keep the thing running but only if you hold the engine over 2k anything lower and it stalls out, I also noticed the turbo sounds like it may be going out when its being spooled. would the turbo giving out cause it to stall out completely when stopped?
Old May 2, 2011 | 03:58 PM
justin_4runner's Avatar
it could. have u checked your timing? or spark plugs or anything?
Old May 2, 2011 | 04:18 PM
drmix's Avatar
Could it be a really bad vacuum leak or a leak in your intake after the air flow sensor?
Old May 2, 2011 | 04:47 PM
Joeseph's Avatar
The plugs are fine, I don't see how the timing would've changed either? We just replaced the set and adjusted all of that in Jan and its been getting worse gradually. I sprayed the thing with ether and found no leaks what so ever however when I attempted to pull the PCV to check I am unable to do so being as it won't for the love of god come out. I had planned on doing a compression test but my compression tester is broke so I am waiting on a buddies.
Old May 4, 2011 | 07:22 PM
Joeseph's Avatar
checked the compression today and it tested 130 across all 4 cylinders, tried to get the PCV out and managed to break the valve cover so that was a waste of time and money.
Blamalam
Mar 12, 2022 07:34 AM
bighaydn
Aug 4, 2015 07:17 PM
87toyy
Aug 4, 2015 04:51 PM
94yotaky
Jul 23, 2015 07:50 AM
kyletbert
Jul 17, 2015 11:39 AM
