Headlights won't hit brights?
Old Apr 25, 2011 | 06:41 PM
phinsbama2413's Avatar
All right guys. My headlights work on low beams but not high! I push forward and they go out. However, if I hold it back they work correctly. Switch? Relay? What say you?
CS
Old Apr 25, 2011 | 07:04 PM
BigSwole's Avatar
Sub to this as mine do the same thing!
I did read one thread about a relay you can clean up and it will fix it.
Old Apr 25, 2011 | 07:28 PM
MID SIZED BOSS's Avatar
Any memory of the thread title, I had a prob like this but it solved itself after a trip to the mountains. I figured it was all the bumpy roads lol.
Old Apr 25, 2011 | 07:34 PM
BigSwole's Avatar
No memory of it at all. I seen it not to long ago but honestly I don't remember the thread title.
It was a relay that gets “burned out“ over the years the fix was to clean the connections I think.
I'm on my bb so when I get to a pc ill try and search it up. Search headlight relay. Bound to come up with something
Old Apr 25, 2011 | 07:38 PM
markfagus's Avatar
I will be watching this one too as I have the same issue
Old Apr 25, 2011 | 07:43 PM
87topless's Avatar
I had the same problem. Used the air compressor and blew out lots of dog hair and dirt from the steering column, and no more problem.
Hopefully the fix is that easy for you.
Old Apr 26, 2011 | 07:44 AM
fdp101452's Avatar
its the combo switch in the collum. search combo switch and i think it will bring up some threads on taking it apart and cleaning the contacts...
Old Apr 26, 2011 | 07:50 AM
xxxtreme22r's Avatar
if you hit the combo switch on the column and you hear a click n the engine compartment then it's not the switch. but...... here is that info about cleaning the switch. http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old Apr 26, 2011 | 02:37 PM
Thanks a lot guys. It's been a very busy week. I will let you know the condition and repair when I get to it hopefully in a couple of days.
Old Apr 28, 2011 | 10:13 AM
Bigal87's Avatar
I had the very same problem, thanks to the 4crawler write up i was able to fix it
sniper34639
Aug 31, 2015 07:56 AM
bvleonov
Aug 22, 2015 11:39 PM
izzmee
Aug 17, 2015 10:20 AM
landes94
Aug 16, 2015 12:20 PM
TDonkey
Jul 26, 2015 10:14 AM
