body mount question
Old Apr 23, 2011 | 08:42 PM
dmaxxx21's Avatar
body mount question
I Just removed a 3 inch body lift and was wondering what goes between the cab and and where the body mounts to the frame because the only thing I seen was just a thin rubber and was wondering if there is a thicker bushing that sits between cab and mount, because I got it all mounted up and it rides really rough.
Old Apr 24, 2011 | 05:27 AM
dmaxxx21's Avatar
Also forgot to ask if the washer between the cab and mount are missing would that cause it to ride rough.
Old Apr 24, 2011 | 06:09 AM
waskillywabbit's Avatar
All you needed to do was remove the body lift spacers and then bolt it back together.
You might look into getting an Energy Suspension body mount bushing replacement kit.
:wabbit2:
Old Apr 24, 2011 | 09:23 AM
dmaxxx21's Avatar
That's what I did and now I believe the stiff ride is just the way it is but I have vibration pretty much at all speeds and I think it could be u joint does any one know how to check them
Old Apr 11, 2012 | 02:48 PM
bbrideau's Avatar
wiggle the drive shaft. if there is play in the u joint. replace it.
Old Apr 11, 2012 | 02:51 PM
BMcEL's Avatar
Late much?
Old Apr 11, 2012 | 03:02 PM
bbrideau's Avatar
LOL did not look at the date on that post. FML
coleypull15
Nov 3, 2015 07:41 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Avenged
Jul 9, 2015 07:55 AM
