- 92 pick up 4wd not working???
- Only starts when it wants to...
- tube flat bed
- running cold
- Tightening torsion bars
- IFS VS. Straight axle
- oil pressure too high, sparked on test
- yay fer my 292k miles 22re!
- 3vze camshaft bearing cap torque issues
- some weird vibration...
- Cold low RPM hesitation
- Tested the coils today
- Advice on sky's transfer case e-brake kit
- Front end noise
- Stiff Suspension - Recommendations? (with pics)
- water in oil
- tundra long bed
- Truck's seen better days =(
- Can't Find A Single Wire 02 Sensor Extension
- First Rig 88 4runner
- melted alternator plug
- need factory rebuild guide/ manuel for the turbo 22rtec 86 sr5 2wd xtra cab
- need throttle body boot that goes to turbo pipe . for 86 sr5 22rtec.
- Poor milage and lack of power
- Driver Window Switch
- IFS Skidplate
- remove oil pan?
- Straight Axle price
- Oil everywhere!
- am I crazy...selling 4runners for a suzuki
- 1986 22r
- Hit a mailbox, broken headlight.
- speakers
- coolant leak...im stumped
- Need 4 Runner Console
- No oil in the filter.
- 1st Oil Change.
- need quick help, truck wont start
- Heat not working
- More Lift
- losing coolant through hoses
- Would this 22re require premium/efi upgrades
- idle s up and down update!
- tailgate lock switchout
- squeeky clutch
- will this transmission fit?
- Auto Tranny Shifting only with lights off?!?!
- Intermittent Startup Knock
- What Backspace?
- lowering T-bars
- help ID this noise/problem plz
- My 4runner died :(
- DASH POT/tps SETTING QUESTION
- Just shI
- BJ spacer install
- sunroof loose. 88 4x4
- Catalytic Converter question.
- Where to start ?
- Engine Flood Update
- uh oh...diff job
- vibrations...
- Aussies on ice
- early vs late idler arms?
- Only 2 Years on a WaterPump?!?!
- slack in rear end
- Anyone near me want to give a hand? Near Victorville, CA
- Crank pulley bolt!
- '90 22RE 'Runner: Simple Brake Upgrades? Yeah, I Searched...
- 3VZE top dead center thread? Help!
- are IFS frames interchangeable?
- Supra motor Swap Questions.
- Cruise control light flashes intermittently
- wont start in the cold 3VZE 89'
- Alternator Upgrade
- Hazard lights
- Exhaust flood...
- Driveshaft swap
- Gas leaking and hard to start
- 84-88 all clear tail light lenses
- thermostat test from an 87 4runner
- rear main seal
- Installed my aussie yesterday
- New grille... which emblem?
- 1988 Yota Fuel Injection Problem?
- 89 gutless runner
- Started my new rear bumper/tire carrier
- 92 4Runner headlight bulbs
- 92 4Runner Clutch options
- Driveshaft Broke Off (pics to clarify)
- surging idle/steaming radiator?
- Tailgate Window problem
- Where is this water coming from?
- BJ spacer help
- DOH !! T-bar help...
- Something got wet, now wont start
- OK this may OR may not be my transmission what do you think
- Bolt size for engine stand
- I may have ruined my throttle body?
- cab question
- 22re conversion
- 5 speed tranny for V6
- Old Man Emu stabilzer....you like??
- Mileage conversion???
- Periodic problem, now coolant blew out the front of the engine
- need to know how many bell housing bolts to remove
- changing crank seal
- 4runner wrecked
- trail gear bumper
- about the 94 4runner (very newbie here)
- 2nd gen body on a 1st gen frame?
- What could cause an ECU to fail?
- Igniter or Signal Generator
- all-pro HID's?
- 87 4runner, bought it and got it stuck in the same day!
- 87 pre-runner/sand rail build
- total chaos long travel install!!!!
- 22re Rebuild with low compression
- Groove in timing cover
- Door Exchange
- what's wrong with my engine? ---22re---
- a few nuts and bolts......
- Can the cold affect the clutch?
- buddie needs help with 86 PU
- wont start when its cold
- snow pictures
- 89 toyota 4 inch lift brake lines
- 3VZ-E owners with PS need your help
- Cold acceleration problem (more info)
- Nerf bars..
- Bumper bolts
- ATF Evaporating?
- cleaning a maf...
- What Can i Do To My 95 4runner???
- Dual O2???
- irradic advanced timing=not good for new block.
- 22RE LC Engineering shortblock & ENGNBLDR head review after 4,000 miles
- anyone seen backorders on m/ts the last month?
- 86 Toyota w/ 22r Charging problem
- Can you remove a fixed antenna?
- MY Runner is Haunted :(
- would you trade (titleless motocyle offers)for my 86 4x4 extra cab
- Custom Hard Tops Anyone?
- Another locker question
- Where to find a mini spool
- 1992 4Runner 'shift on the fly'?
- noisy whirrly clutch sounds
- 3.0 Swap- fuel injector question
- 1990 4runner, some issues I haven't been able to tackle yet..
- feels like my 4runner is flooding out when started durning cold weather
- 94 4x4 Pickup parts
- Losing oil on 86 Toyo 4x4
- It finally happened...
- antifreeze leak near thermostat- NEED HELP!!!
- n00bie questions
- portable OBA
- 95 3zve valve covers
- Ignition cylinder
- # of grease points
- Hey guys! Here is my new runner.
- 94 runner wont start PLEASE HELP
- Lockers!
- injectors?
- helicoil help please?
- cigarette lighter help
- help with a e-locker
- rear main seal question (3.0 v6)
- 86 4 Runner ingaging issues with T/C
- R&R IFS axle ?'s
- Help- Mechanic is stumped - idle(?) issue
- Checking Vacuum Leaks - should i Use Carb Cleaner of WD40
- Headgasket done, rocker arms noisy?
- wont start
- Rear Leaf Springs
- Toyota Christmas
- Need Help Chasing A Gremlin...
- crazy noise after tahuya, mahalo for help
- 1st gen Sunroof
- Online manuals for download. Check it out
- Seattle area SNOW TRAIN...(YODA style)
- Rear Sliding Window Latch
- 91 3vze timing question
- Stuck in 4-low
- keyless entry
- Best spark plugs for 3.0vze 1989 4 Runner
- Source to order manifold gasket 3.0vz for 1st gen 4runner?
- hose on 95 v6 pickup
- Is there just 1 pcv valves in the 4runner - Dumb Q?
- 94 Runner 3.0 - vibration at 50 - 60 MPH
- is my fuel pump going out? some kind of sensor?
- Does the insulation go between the clutch bracket and the firewall?
- Transfer Case Not Shifting Into 4Low Until Warm?
- How on earth does coolant get here !!?
- i got some lights!
- Help Low Oil Pressure
- frozen block
- What would you do first...
- My new Truck... thats really old
- Gasoline in Oil
- 3vze oil pan gasket, Cork or silicone?
- Finally finished my head gasket job!
- Replacing rotor on a 4WD '95 4runner
- my trucks vibrating, a lot.
- hahahahahahaha
- good 'yota story....
- Help ! Knock sensor wire has broken plug
- Drivers side Timing guide
- 87 22r rebuild HLEP!!!!
- LC Engineering Turbo motor...disappointment??
- Rear wheel/hub moves in and out? normal or bad?
- Steering Column Axial Play
- Wheel Resistance in 4WD
- metal on the drain plug
- Isr Mod - Brass Fitting Question??
- dodge d50 bed?
- lift tires and gears
- 92 Toyota P/U won't disengage from 4H, won't go in gear!!
- Manual Aisin Hub Rebuild?
- temp gauge install
- swaping 86 22re for an 88 22re
- pickup bed for sale
- Idle Air Control Valve
- 22r trying to stall after deceleration
- Engine Stand Bolts
- stealership parts
- brush guard
- Dirty valve cover
- IFS Differential, how much play is OK?
- New owner (again). Have a few questions though.
- DIY fender flares
- Does anybody know how to unclog a heater core
- battery/alternator problem
- 3VZE vs. 3VZ-FE
- Clutch Slave Cylinder - And stiff shifting.
- Random no start... What worked for you?
- transmission Fluid???
- help with a fuel line
- Dammit..Couple issues
- What are my choices??
- 88 Yoda front end chirp
- CV questions.
- EFI Throttle body
- Stock Thermostat Temperature?
- 86-95 Toyota crash-worthiness ?
- My very own time machine
- still have code 25
- upside down
- Departure of the driveshaft
- Rotors
- The Feel Good Thread: What have you done to your rig recently?
- So I know...
