remove oil pan?
Old Dec 27, 2008 | 09:58 PM
EviL inside's Avatar
remove oil pan?
94 4runner, 4WD, ADD, 22RE. is it possible to remove the oil pan with the motor in the truck, without dropping the IFS? i would like to do the rod bearings with the motor in the truck, if it's not feasible, i'll just wait for this motor to eat itself and find another to rebuild and just swap it out. anyone done this?
Old Dec 27, 2008 | 10:01 PM
91Toyota's Avatar
No. Either remove the engine or drop the diff. Not that hard. Looks harder than it actually it is. Life sucks huh?
Old Dec 27, 2008 | 10:05 PM
4runnermt's Avatar
I replaced my oilpan gasket in the truck by removing the motor mounts and jacking up the engine/tranny. Don't know if that would give you room for bottom end work though. Its a possibility!
Old Dec 27, 2008 | 10:28 PM
sa51's Avatar
i remember someone saying they didnt have to drop the diff, but when i changed my oil pan gasket and timing chain, i dropped it
Old Dec 27, 2008 | 10:32 PM
4runnermt's Avatar
For timing chain and gasket, the diff doesn't need to move. Trust me, I didn't move mine and all is well 20k later. Just unbolt the motor mounts, and maybe there is a crossmember mount for the tranny as well. Then jack it up. I didn't want or have to mess with the diff.
Old Dec 27, 2008 | 10:49 PM
874runnersr5's Avatar
Droping the diff takes around 3 bolts for the diff its self, and 4 for the driveshaft..
its pretty easy
Old Dec 27, 2008 | 11:01 PM
Matt16's Avatar
its pretty easy
But its ***k*** heavy. It took my dad (225lbs), myself (180lbs) and a floor jack to put in position and it wasn't easy. The only place to hold it with the jack (the diff itself) isn't the centre of gravity.
With a bracket lift you don't have to drop the diff.
Where do you place the jack when you unbolt the motor mounts and lift the engine? Do you use a engine hoist? You can't exactly jack the engine up from below if you're removing the oil pan.
Old Dec 27, 2008 | 11:07 PM
yeah true matt, it was pretty much a pita to get out and back into place, but the extra room i had was pretty good.
Old Dec 27, 2008 | 11:27 PM
Matt16's Avatar
Having the truck on a hoist would make a huge difference. You could get a better grip on the diff, and have room for two people lifting and one bolting it in place.
Old Dec 27, 2008 | 11:28 PM
yeah, i just used both of my floor jacks and a crowbar to get it in place
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
ryerye13
Jul 14, 2015 08:27 AM
HRDC0R19
Jul 5, 2015 06:43 PM
