Isr Mod - Brass Fitting Question??
Old Dec 20, 2008 | 11:59 AM
simpsons721's Avatar
Red face Isr Mod - Brass Fitting Question??
First off i know my brass fittings i work at fastenal we have them in stock
My question is where did you find a nut for the fitting this is my problem
A 1/2 in brass fitting is a pipe fitting it doesn't have a bolt pitch
the pitch on the fitting is a 6
and for the 7/16 fitting i dont know but lets solve the 1/2 in first
need more info reply back
Old Dec 20, 2008 | 12:05 PM
thook's Avatar
Sorry....couldn't make sense of that. I tried, though.
Old Dec 20, 2008 | 12:34 PM
TacoNut's Avatar
I read this Mod and thought the same thing! You could make a nut from a coupler, one of the ones with the wrench lands in the middle. I'm wondering if the 7/16" fitting is actually a 1/4 NPT which would be about 7/16" on the outside of the threads. Just my thoughts.
Old Dec 20, 2008 | 12:37 PM
abecedarian's Avatar
7/16 is a non-standard pipe size so maybe you're referencing the size of the tubing? In which case the threaded part of fitting is likely 1/2 or 3/8.
1/2" pipe thread is 14 tpi, 3/8 pipe thread is 18 tpi.
Old Dec 20, 2008 | 04:02 PM
boosteda9's Avatar
what is a isr mod??
Old Dec 20, 2008 | 04:09 PM
intake silencer removal
search is your friend.
Old Dec 20, 2008 | 04:21 PM
boosteda9's Avatar
haha yeah i just searched its only for 3rd gens tho right??
Old Dec 20, 2008 | 04:28 PM
most is applicable to any 3vze as well
Old Dec 21, 2008 | 01:48 PM
ok the coupler will probably be the best bet to rig up a nut
But i would like a reply from someone that has done this and see what they used
I thought all you True Yota fans already did the ISR mod and i need to catch up
Old Dec 21, 2008 | 01:55 PM
space-junk's Avatar
i was under the impression that most if not all of the people who do that dont put a nut on the inside for fear of it falling off and getting sucked into the intake...
Old Dec 21, 2008 | 02:01 PM
well how will the fitting stay air tight without a nut
Old Dec 21, 2008 | 02:31 PM
JonnyBoy's Avatar
I happened to get ahold of a 1/2" tap. Drill the hole a lil smaller and tap, then I installed it with teflon tape. As for the 1/2" tap, you may need to hit up a plumbing specialty store as you were saying, the thread's different for fittings and bolts. My pipe was stainless, btw, so it works in metal or pvc, whichever you're working with.
Old Dec 21, 2008 | 03:14 PM
ok im gonna check that route and go to plumbers supply
see what kind of taps will work
why was this problem never talked about in the write up
it seems like a common question
Old Dec 21, 2008 | 04:32 PM
Tubbyfatty's Avatar
This is why i gave up on finding all the fittings and crap, i just went to autozone, bought the "spectra intake" with the 45* bend and like 3 other pieces. It was $40 and it worked just fine, but i did need a longer coupler, so i got a 3x3'' lowes coupler.
Old Dec 21, 2008 | 04:47 PM
N.P.T. pipe threads, like what's on the brass fittings, are tapered, being smaller at the end and wider nearer the fitting. They tend to be self-sealing since the threads are tapered. Teflon tape or 'pipe dope' is a decent addition to ensure the fitting does not leak.
One could go with PVC, CPVC or other plastic fittings and use pipe glue to seal the plastic fitting into the pipe as well. Be careful with the glue though, and only apply it on the last few threads that engage the pipe you're tapping into, otherwise you may glue it together too soon.
Additionally, if the pipe fitting is 1/2" (the threaded part), a lock-nut from a 1/2" electrical conduit coupler should fit as well as should a 3/8" electrical lock-nut fit onto 3/8" brass fittings.
Old Dec 21, 2008 | 07:41 PM
idanity's Avatar
i wish there was a "search pix" link
i remember reading a ton of info and pix on a thread here, but cannot locate it yet.
glowz825
Jan 25, 2022 09:28 AM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 11, 2015 07:21 AM
Cplmike
Jul 8, 2015 08:47 PM
Nickdigg
Jul 7, 2015 06:04 AM
