How on earth does coolant get here !!?
Old Dec 21, 2008 | 12:55 PM
scuba's Avatar
so i get under today to check tranny oil...
And I see this...Now, I know Ive been losing coolant, But i could never see a leak, and Its not coming out in steam form from the tail pipe...
And no coolant in the oil...
So...Dublya Tee Eff ?
For refrence you can see the drain plug right there...
More towards the front...
hmmm, What do you guys think is up ?
Old Dec 21, 2008 | 12:59 PM
thook's Avatar
Heater hoses to the heater core. Maybe even the inlet/outlet tubes on the core. My best guess.
Old Dec 21, 2008 | 01:03 PM
scuba's Avatar
I've had the on inside the cab spit up on me once or twice...Could that have something to do with it...?
I rarely ever use the heater...SoCal...Duh..
ummm, but idk, this is just weirding me out
Old Dec 21, 2008 | 01:06 PM
scuba's Avatar
Umm, Stupid FSM doesnt show the heater hoses in the heater diagram...LAME !
Old Dec 21, 2008 | 01:59 PM
space-junk's Avatar
inside or outiside heater hoses? they should go right into the firewall in the middle top of it... maybe your heater is clogged and its building up pressure?
Old Dec 21, 2008 | 02:02 PM
Itoyota's Avatar
you know I had a problem exactly like yours. For some time I could not Find the coolant leak that was developing droplets just like yours near the bell housing. If you have a 22re like mine, I had the head serviced and the gasket that came in the head set for the rear backing plate, on the very back of the head just below the rear half moon oil seal under the valve cover, sucked and started leaking immediately.
If you lay down on the ground and look up past the clutch slave cyllinder and get an angle so you can see through the engine bay with the hood opened, you should be able to make out a small formed plate abou the size of your palm on the back of the head. It is bolted on with like 5 bolts and is the only thing attached to the back of the head. See if that's your leak.
good hunting.
Old Dec 21, 2008 | 02:07 PM
scuba's Avatar
good hunting.
hah
Would it be hard to get to that gasket if that is it...?
Im guessing the tranny would need to be removed...
Old Dec 21, 2008 | 02:12 PM
thook's Avatar
No. You should be able to get to it from the pass side of the motor by pulling the EGR valve off and the other stuff in that area. It's still not terribly easy to get to it, but it's not that bad.
Good tip, Itoyota.
Old Dec 21, 2008 | 02:19 PM
scuba's Avatar
Checking FSM for said werid gasket...
then Ill run outside and take a look...
Old Dec 21, 2008 | 02:23 PM
corax's Avatar
Originally Posted by scuba
hah
find someone with small hands . . .
Old Dec 21, 2008 | 02:25 PM
scuba's Avatar
Ok...real quick...Itoyota..Are you talking about the gasket thats in front of the "rear plate" thats at the back of the head in this diagram...? Page 1
http://personal.utulsa.edu/~nathan-b.../7cylinder.pdf
Old Dec 21, 2008 | 02:27 PM
scuba's Avatar
Just read your post again, I think im correct...Brb...
Old Dec 21, 2008 | 02:50 PM
scuba's Avatar
Ok, So, I couldnt really see much through the mess of wires and mud and gunk...But, When I got out there, there was Coolant dripping right on top of the slave cylinder/fork (or w/e its called)
Ill guess ill let my dad know this is my suspicion...
Old Dec 22, 2008 | 06:58 AM
83's Avatar
83
That plate you mention does carry coolant, that could be it. There is also coolant going in to the intake, I had a leak there, but I wouldn't think it would make it that far back on your engine. When I had coolant coming from where yours is, it was a coolant hose going to the heater core, like someone else mentioned. It just goes right into the firewall above your engine, two hoses, one for coolant in, one for coolant out. If your actual heater core is leaking you'll have coolant in the cab. I wouldn't think it'd get out onto the tranny. If they heater core's all plugged up, it could cause those hoses to leak possibly, by building up pressure.
But I'd say other than the backing plate on your head, the heater core hoses are the only things far enough back to be getting coolant way back there.
Old Dec 22, 2008 | 07:00 AM
scuba's Avatar
Sounds good, I guess thatll be a project these next couple weeks...
Heater core flush, And get to that backing plate, it does seem like the most viable solution though...
ladybugRC
458
Aug 21, 2020 10:41 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
wberry85
May 17, 2016 05:45 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
