PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 [189] 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. factory clutch life??
  2. need exhaust manifold torq specs please
  3. Bad idea!!!
  4. Please Help Will Not Idle When Between Hot And Cold
  5. sounds like i am dragging a chain under the truck
  6. John Bull difficulty?
  7. New (to me) truck tips?
  8. Tacoma rear axle on 1st 4runner?
  9. This evenings quick project
  10. Reman'ed Starters: Napa vs. Autozone
  11. Aggrevated With My Toyota, Any Input?
  12. Had to make my Yota bleed
  13. 1st time toyota owner..need help!!
  14. Please help! tach troubles?
  15. Speakers under back seat of 4runner?
  16. elec fire in 90 v6 4x4 HELP!
  17. timing belt job. who's got PN's?
  18. Damn! I have to sell my Yota!! This sucks!!!!
  19. My 88 4runner needs parts.
  20. BIG T's 91 turbo diesel hilux surf
  21. Symptoms of faulty TPS?
  22. woohoo, a project for me!
  23. Installing a few gauges..questions
  24. Truck Cancer! Whats A Man To Do?!
  25. Help me with my clutch, it is gone!!
  26. 84 parts on an 86?
  27. ignition timing and gas mileage
  28. shifter lights on a 93 4runner automatic 3.0
  29. 86 4X4 22R Clutch Job
  30. Air tank placement
  31. '91 3.0 decided not to start for 10 minutes
  32. radiator leak
  33. WTF? Why are my headgaskets ovaled?
  34. 3rd member
  35. Crankcase pressure, How much is too much? 22RE
  36. need rear leaf springs for 88 pickup
  37. Msd
  38. water leak
  39. 4x4 issues
  40. removing cruise control
  41. Creaking noise while turning steering wheel
  42. help no high range!
  43. How to tell suspension is worn out?
  44. I'm learning...
  45. is it time to part out my 4runner?
  46. Removing Alternator Bracket
  47. V6 vs 4cly 7.5 IFS Front Diff
  48. 22r/22RE hybrid engine questions
  49. main fuse keeps blowing and i cant figure out why! help?
  50. Idle issues
  51. New Cam, how about new rockers?
  52. Tranny question
  53. Need help with 22re, studdering and dieing
  54. i need some info on A340E transmission.
  55. Clunking noise
  56. Oil in intake
  57. 3rd gen seats in a 2nd 4runner help asap
  58. harmonic balancer??
  59. Cab Corner and Rocker Repair
  60. Bronco style soft top?
  61. water in 88 v6 automatic trans
  62. engine swap
  63. bushwacker flare idea?
  64. questions on installing a kayline soft top
  65. Dual T-case install?
  66. !!help!! a friend in need of a complete wire harness for a 3.0 auto..thanks
  67. Another 3.0 Overheating issue, but a little different
  68. Quick question
  69. My cruise control is on crack.
  70. 89 to 92 swap
  71. This is not suposed to be bent...plz help
  72. Rebuild? New Engine?
  73. Transfercase Shifter Question
  74. ECU Power Supply
  75. 22r efi conversion
  76. Retrofitting Variable Valve Timing?
  77. Another Problem!!!
  78. ive got a pretty serious fuse prob
  79. Can that silver thing leak oil?
  80. Seat Swap possibilities
  81. Speedo needle bouces on startup.....
  82. black smoke?
  83. AC not working...again
  84. 22RE Intake Upgrade/Swap
  85. Wanted Shifters!
  86. Does anyone know where I can find the fuel "inertia" switch?
  87. Help!!
  88. torsion bars
  89. Loose front passenger's side axle flange
  90. brake in for a 3.0
  91. Driveline Bind in Reverse
  92. Rusty tailgate
  93. air box battery swap done, thanks folks
  94. Rear R&P
  95. speedometer issue approaching?
  96. Starter problem.
  97. Pickup vs 4Runner frt. sway bar
  98. Pickup vs 4Runner frt. sway bar
  99. 94 4Runner Headlight Question
  100. Exhaust flex coupler?
  101. 1987 4runner front power windows
  102. bed 2wd vs 4wd?
  103. Hydraulic tensioner timing belt
  104. Need longer brake lines
  105. HOW BIG of tires on stock suspension.w/o rubbing?
  106. Gear install source?
  107. knock sensor torque specs?
  108. 2" coil spacers
  109. No Start after compression test
  110. pullin a pop up with the 22re
  111. Sold 2nd gen- what now?
  112. Something is up with my front axle!!!
  113. aloha, valve lash specs on da 22 re?
  114. improving my 92 P/U
  115. First time off the pavement in the 4RNR
  116. front wheels locking up
  117. I think I killed 'er
  118. bad maual steering box
  119. strange whirring noise
  120. Ignition problems
  121. Any performance parts for a 3.slow
  122. I really hate when I do something stupid!
  123. Need Photo
  124. water in the fuel tank
  125. BullFrog Rust Kit
  126. New guy looking for advice.
  127. truck died
  128. New Carpet
  129. Spontaneous Truck Fire!
  130. Lower control arm (LCA) bushing replacement
  131. power steering pump
  132. why can't people drive...
  133. Head Gasket
  134. What WILL Break?
  135. Pics of my 91 Toyota
  136. serious 22r problem
  137. A little help with a melting fuse please
  138. new guy/ different build strategy
  139. ignition cylinder interchangeability ??
  140. LSPV lift bracket
  141. I'm goin' in! - 3.0 Head Gasket -tips/tricks welcome
  142. Power Loss
  143. Painting Advice
  144. Reassembly
  145. York air compressor, 22RE
  146. skidplate transfer
  147. New truck couple questions
  148. what spark plugs should i use..?
  149. Buying a LockRight
  150. shocks for BJ Spacers/ Cruiser Coils
  151. What in the world made my spark plugs....
  152. came across these guys..check it out
  153. plz someone help
  154. Certifit and Parts train
  155. Help! window problems and its gunna be a rainy week!
  156. Preventative maintenence for throttle cable
  157. 80 amp "Glow" fuse?
  158. How much more until my idler pulley locks up?
  159. steering adjusty thingy
  160. Wheel bearing seals, backwards?
  161. More questions for y'all '86-'95 crowd:4runner and pick up body parts swap.
  162. TJM-17 wing
  163. intake-exhaust formula?
  164. cruiser coils
  165. Problems associated with Tropical Storm.
  166. Powder coated bumpers (black hammer tone)
  167. exhaust manifold torque specs.
  168. Tires
  169. brake question.....
  170. Looking for a carb insulator
  171. Driveline "whirr" - PLEASE HELP
  172. Good deal???
  173. Anyone know a reputable place to get a 3VZE rebuild done in Portland OR?
  174. Transfer case output seal????
  175. lift
  176. passenger side leak !help!
  177. Drive axles won't come out??
  178. Thinking of getting a 89~96 ex-cab 5spd 4x4 truck
  179. Isuzu aluminum rims on pick ups?
  180. anyone have a starter
  181. Torsion bar adjustment prob ?????
  182. what MPG are you geting in a stock 22RE\auto\4wd
  183. Wheel spacer/Ball joint spacer/ alignment help?
  184. Fuel Pump Access
  185. More body damage
  186. A 3.4 swap is in the near future....
  187. Ignition is sticking....keyless option?
  188. 88 pickup feels like its going to stall when idling
  189. locked and loaded.....
  190. tranny problems
  191. 4runner to pickup engine swap
  192. Spankfest 08
  193. Rust?
  194. Steering Gearbox
  195. 4.0 backspacing rims
  196. Wheeling woes
  197. 1st gen 4Runner bed panels
  198. fuel/air no start mystery help
  199. Knock sensor and Throttle position sensor .
  200. 261C/Crawler with factory efi??
  201. Oil Pressure Problem
  202. 4x4 dash light quit working
  203. Check before I rebuild the carb
  204. Axle removal question
  205. Oil Cooler gaskets???
  206. Need help finding a seat!
  207. 94 upgrade.. lots of new stuff, before and after pics
  208. 94 upgrade.. lots of new stuff, before and after pics
  209. Body Lift Shifter Woes
  210. I Switched my Battery and Air Box Locations
  211. Would I be safe towing this?
  212. Summer build/work
  213. Help with measurements for Demello Sliders
  214. noise when releasing the clutch
  215. a/t temp light coming on???
  216. G58 shifter seat part #
  217. Reccomend Muffler and Clutch ...
  218. 2" Lift Help.....
  219. Pictures of 33X10.5 tires??
  220. 88 v6 fuel issues.
  221. HOw TO discharge Air Conditioning
  222. is this strong enough?
  223. Power steering pump surgery question(s)...
  224. Wheeling done, review and question
  225. dome /radio/clock fuse keeps blowing
  226. Looking for pics of those with 3 inch SAS setup.
  227. $15k in mods at once
  228. Inspect my Steering linkage with my NEW High Detail you tube VIds
  229. Update on New Engine - :(
  230. New ported head or new camshaft?
  231. Where does this wire go??
  232. Driveline Howl When Letting Off The Clutch??
  233. Any advice for a noob?
  234. Finaly new meats
  235. Help Identify Headers?
  236. 2 things: Lift plans... and in need of pictures
  237. Shock Length for Chevy 63s
  238. How would you run dual Exhaust?
  239. So After a HG and TC.....
  240. 1988 truck: stumbling/idle problem
  241. Will V6 cluster work with 22RE?
  242. does this look funky???
  243. Cigarette Lighter 1994 3VZ 3.0
  244. 4runner trim piece behind doors
  245. My truck is possessed.
  246. 93 SR5 and Factory Fender Flares ?
  247. new shocks??
  248. Any 1st gen 4runner's with custom sub boxes?
  249. Panels
  250. 94' brake question
