1st time toyota owner..need help!!
Old Aug 27, 2008 | 05:56 PM
9five_4runner's Avatar
i just recently bought a 95 4runner with warped heads for $700, which i didnt think was a bad at all ...so i went out and bought a long block for it from houston and did an engine swap ..well that wasnt so hard but now the problem is i cant figure out where the vacume hoses connect on the left side of the intake (passenger side) along with the hoses from the power steering pump.....cause the guy who had it b4 me already had took the top half of the engine apart ..so if ne one could help me out with sum pics it would help alot... its a 3vz v6 4x4 95 4runner
thanx
Old Aug 27, 2008 | 06:01 PM
Bigblock's Avatar
A lot of info should be on the hood sticker as far as vacuum lines go.A pic might be helpful.
Bigblock
Old Aug 27, 2008 | 06:02 PM
dropzone's Avatar
Fossilized
Welcome to YT, here is a link to some online Toyota Factory service Manuals:
http://www.ncttora.com/fsm/index.html
there are 5 or 6 different manuals, you should be able to find the Vacuum diagrams you need. Post up some pictures of your project sometime...
YT has a very good atmosphere (better than some forums) but a lot of questions may be been answered before, be sure to try the search function...if you don't find what you are looking for to avoid getting flamed be sure to post in the Newbie Tech Folder: https://www.yotatech.com/forums/f120/
Good luck!
Old Aug 27, 2008 | 06:49 PM
Kiroshu's Avatar
Get a haynes manual for it and you will be good to go.
________________________________________________
1988 Toyota 4runner SR5 V6 3.0 5-Speed
Old Aug 27, 2008 | 08:39 PM
zlathim's Avatar
Don'tknow how much help they will be, but here are a couple of pictures:
Old Aug 28, 2008 | 01:35 PM
thanx alot man..that help plenty...ill let u no if i run into ne more problems
Old Aug 28, 2008 | 02:34 PM
Cyberman's Avatar
Just make sure you put the fuel return hose on the correct tube. You can find it pretty quickly by blowing air into the regulator side (driver side).
Old Aug 28, 2008 | 05:07 PM
i just got done wit all the 8 mile of hose that thing has all i need now is the radiator ,fan ,a couple of pullys and the air box and its componets ... but the only problem i have now is sum of the bolts to a few of the brackets are missing ,so ill probly go to the fastners shop and pick up wut i need.......But two questions i do have are..1. does n e one happen to no the size and dimesions on the bolts for the rear drive shaft that bolt it down to the differential cause the vehicle didnt come with them when i got it ( ps, the 4runer is 4 wheel drive if it makes n e differance)??? ...and 2. Wut would the break in method on the 3.0 b??? n e info would help..thanx
Old Aug 29, 2008 | 09:33 AM
zlathim's Avatar
Dude, I don't mind helping you out, but I can't really understand your last post. Paragraphs, punctuation and spelling help tremendously.
Old Aug 29, 2008 | 12:46 PM
thook's Avatar
Gotcha on this one zlathim.........
Surch da 4m 4 da brak in procjures uzng doze keewurds.
Pul 1 bolt frum da frunt DS 2 match 1 ^ at da parts stor.
Old Aug 29, 2008 | 01:36 PM
yea...i never thought of that ..thanx sry bout the paragraph im just so usto texting
Old Aug 29, 2008 | 05:51 PM
space-junk's Avatar
i think that spelling was the big problem... remember, it only takes 2 seconds more to type out every word, and it is a lot easier for everyone else to read it and help you out...
Old Aug 29, 2008 | 06:13 PM
PISTOL1000's Avatar
lol
dude thats so FR@#$% funny OMG! i cant spell for i could understand perfectly!!!lol
Old Aug 29, 2008 | 06:21 PM
thook's Avatar
I was cheating and used my "Hooked On Phonetics" guide to interwebz lingo..
6th Gear
19
Dec 10, 2019 07:31 AM
voiddweller
19
May 2, 2016 09:10 PM
layifioren
10
Jul 6, 2015 02:26 PM
saphirekosmos
Jun 22, 2015 10:26 AM
