Another Problem!!!
Old Aug 24, 2008 | 05:11 PM
NorCrawler's Avatar
Another Problem!!!
my blinker is eff'd.
my left turn signal works in the dash and front and rear 100%.
But my right blinker, when i click it up it just stays on in the dash and buzzes non stop. and it doesnt blink in the front or the rear. wtf?
i dont think the fuse is blown because if it was, wouldn't the left blinker not work either?
and when i put my hazard lights on only the left side lights work. but in the dash it shows both blinking.
this all started happening after i went wheeling and my taillight got crushed. but i replaced everything, including the wiring, housing, lens, and new bulbs.
Old Aug 24, 2008 | 05:13 PM
abecedarian's Avatar
likely it's the combination switch on the column
Old Aug 24, 2008 | 08:21 PM
just a 22re's Avatar
did you cross any wires out back??? and check your blinker relay dohicky thingy might be bad or better yet when you broke your light you might have leaked all your blinker fluid out check that to
Old Aug 24, 2008 | 08:31 PM
NorCrawler's Avatar
combination switch?... the blinker stick?
i i didnt cross any wires all matched up. where is the blinker relay?
Old Jan 23, 2009 | 09:09 AM
NorCrawler's Avatar
still broken need some help ive been driving around without a blinker for a couple months now! hahahah help!!!
Old Jan 23, 2009 | 10:02 AM
Koko4's Avatar
It's the blinker switch...mine has been doing the same thing for forever, the buzzing sound. I can still get it to work if I push it very gently towards the steering column. I think it's a bad connection in the switch, but I bought another one off of a junk truck at Pull-A-Part. To fix it you have to take off your steering wheel, though, which would be a pain in the ass.
Try this: try putting on the right turn signal, and then when it buzzes, push it slightly towards the steering column--not so much that it clicks off to the middle, but just enough to reconnect the connection. Let me know if this helps.
Old Jan 25, 2009 | 01:32 PM
NorCrawler's Avatar
nope still not working, i dont know whats going on, its really annoying. im just gonna go buy a buncha new bulbs at kragens today and see if that solves anything. and look over my wiring.
Old Feb 16, 2009 | 10:18 PM
NorCrawler's Avatar
Fixed
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
