anyone have a starter
Old Aug 19, 2008 | 10:33 AM
galloway's Avatar
i need a starter for a 89 v6 im tryin to get my truck working and this is the only thing i haves left. thanks
Old Aug 19, 2008 | 10:50 AM
apalmer1's Avatar
ive got a couple starters but they are from an 85 with a W56. im pretty sure that a W56 starter will bolt into an R150 trany as we swapped tranys on my friends 87 and were able to use the same starter, however i don't know if the flywheel tooth count is the same on the 3VZ as the 22RE.
you should run down to an auto parts store and check ask them what the tooth count is on each of the flywheels for your year and if its the same part number for starters then PM me if you think it will work. im in Bend Oregon so not too far.
Old Aug 20, 2008 | 11:58 AM
galloway's Avatar
ok thanks but i got it working already. thanks alot for the help
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
