PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Shifter Boot & Clutch
  2. Engine surges when foot is on brake pedal and is warm
  3. Ac idle up valve
  4. Engine surge when foot on brak and warm
  5. Heater hose size at water valve
  6. Help: 1990 Truck 3vz Headers
  7. 88 4runner First Toyota
  8. 1991 4runner with 00 3.4 swapped into it bogging down.
  9. El Jibarito 87 22R “Amor en el Tiempo de Oxidación”
  10. 3.0 Distributor, buy new or repair?
  11. Transfer case, where's this spring go?
  12. Help- 92 4Runner V8 Conversion
  13. 93 pickup rear bumper w/ integrated hitch?
  14. 22RE Rattling Noise
  15. Is a16 p compatible with a 18 p on the 1989 pickup ECU
  16. 86 22REC swap into 94 DLX with 3.0
  17. 1992 Pickup - 3vze - lost acceleration
  18. 1988 4runner SAS shocks
  19. 87 PU Brake lights don't work
  20. Solved: Hesitation til ~4k RPM 91 3VZE
  21. Banjo washer dropped in intake
  22. 95 4R stripped interior, engine dies
  23. Stumped-No power
  24. Front 3rd member slop please help!
  25. 22RE Gauge Comparison: 180F Vs. 190F Thermostat
  26. 94 Pickup Rostra Issues
  27. 93 Toyota Pickup 22re almost stalls when the clutch is pushed in
  28. OEM wheel clean-up
  29. Running 3.0 valves over spec.
  30. 22re diagnostic jumpers at the ECU?
  31. 1986 Pickup SR5? Or not...
  32. ARB Products for 90-95
  33. Priming 3VZE with Starter
  34. '91 4Runner Steering Box ID Help
  35. rough idle code 25 and 26
  36. 86 4x4 carb flooding out
  37. 3VZE Timing Mark Constantly Drifts Counter Clockwise
  38. A340H to A340F behind 22RE
  39. toyota pickup help finding wiring diagram 1991
  40. Clutch fork clips missing
  41. Steering Pump HELP!
  42. Advice on next mods
  43. 1992 Pickup 3VZE Delayed Coolant Leak
  44. Aftermarket Steering Wheel
  45. New to Yota
  46. 4RUNNER no start but cranks new spark plugs and strong odor of gas
  47. 22R truck oil pick up tube bolt size
  48. 22re hard warm start
  49. Thermo Time Switch Part Numbers - 87 22RE - Need Help
  50. extra power outlets
  51. 1991 Toyota pickup a/c fan speed
  52. 1992 22R Vacuum Sticker
  53. 87 22re Emissions Fail and High Oil Consumption
  54. window runner lining - what to use as a replacement?
  55. IACV or Head Gasket?
  56. '89 4runner project
  57. leftover bracket
  58. Dif mount broke..
  59. Identify Door Panels
  60. HELP! Check engine light does not work.
  61. Won't go into park!
  62. 1991 4RUNNER SR5 Clutch Bleeding
  63. ‘87 Pickup vacuum diagram
  64. Horn Upgrade
  65. need air intake for 86 22r pickup
  66. Center-to-center bolt hole distance on 2nd gen 4Runner door panel armrest
  67. 1994 Toyota pickup
  68. 1990 toyota 4runner Fuel pressure damper
  69. Can bad brake booster cause soft / spongy pedal?
  70. help - shock hitting suspension
  71. Question regarding leaks
  72. 25/26 code for 3 years
  73. New to me 94 4Runner almost starts
  74. Leftover bolt from clutch replacement
  75. 1993 transmission clutch and flywheel overhaul
  76. Suspected no third gear
  77. 3.0 Low power then jolts up at around 3,000 RPM
  78. Does anyone know the limits of the 22re's factory internals?
  79. Having an idle issue with stock 22r
  80. radiator hose markings
  81. Rear sliding window parts
  82. Brakes Not Working
  83. Vent issues with 88 pickup
  84. 3VZE Rough Idle When Warm
  85. Power Steering Bleeding and FSM
  86. Block type 22R
  87. 87 22r 4x4 idle and over heading
  88. Leaking from side of power steering pump. Reman PUMP
  89. Restoration parts catalog
  90. Cluck when I turn the wheel (pic)
  91. Fuel pump harness/pigtail
  92. Rough idle & overheating
  93. 1990 22re overheating
  94. Lost Compression in 3 Cylinders, 90PSI in 1 22r
  95. 1992 4x4 Pickup Poping Out of First Gear
  96. Anyone running this Prerunner front bar on a 1984-1989?
  97. extra wires after 22re swap
  98. Front valance brackets
  99. LCE temp sensor manifold
  100. 4Runner at the 1987 NYC Auto Show
  101. 89 Pickup XCab Fuel Sending Unit
  102. 89 DLX 3vze Hard Starting Issue
  103. 22RE Injector Pulse width?
  104. 4runner tailgate 87 DLX window scissors lube
  105. Rear leafspring bushing frustration
  106. Shorted out my starter, what did I fry?
  107. Can thermostat cause running issues?
  108. '90 Toy Pickup 4x4 V6
  109. 1992 Toyota pickup manual swap problems
  110. 86 Timing problem SUCKS
  111. Complete rebuild... Same sound/problem
  112. Failed emissions, how much vacuum?
  113. 1987 22RE Short Bed Pick up.. Will Long Bed Fuel Tank Fit
  114. AC Blower fan blowing Gauge Cluster fuse?
  115. 2nd gen 4R seats into 88 SR5 pickup
  116. 92 22re no fuel from pump 1992 truck
  117. 90 4 Runner won't start
  118. 1993 Toyota 3vze hardline delete
  119. Ac vsv hissing when on normal?
  120. 22re Injector Ticking
  121. Broken 90 3vze crankshaft cap
  122. Exhaust studs
  123. 3vze spark plug wires: different generations/versions?
  124. Identify if these are for my 88 4x4
  125. 22RE Code 71 EGR Delete - resistor fix
  126. 1990 22re trouble starting after sitting fir 3 to 4 hours
  127. Engine stumbles and bogs
  128. Am I missing something? Ebrake
  129. Advance Timing for Better MPGs?
  130. factory bumper ? part #
  131. '91 4Runner starts fine but dies when warm
  132. 88 pickup 4x4 3vze diff leak help
  133. 87 4Runner 22RE ATM Check engine Light Only above 45 mph
  134. Random Spliced in Vacuum Line?
  135. Mechanic replaced timing belt/water pump, now power steering doesn't work
  136. 88 4Runner v6 auto trans , trucks stalls when put into drive or reverse
  137. Headlights
  138. 1987 Carb 22r 4x4 Manual Ca.- Fix it sharing
  139. E1 TE1 Jumpering with no effect. 3.0
  140. engine swap, need wiring diagrams
  141. 22re won’t warm up completely
  142. Aisan 2 Barrel Carb Rebuild Issues
  143. Need advice on replacing 3.0 valve shims
  144. 95 2wd rotors and calipers on 88 runner
  145. 95 2wd 3.0 rotors on 88 1st gen?
  146. Help with gastket kit for steering gear box
  147. Fuel leak
  148. No start when warm or hot ‘86 pickup
  149. Identify plug on passenger side of engine block
  150. Manual trans only 2.5 quarts????
  151. Can I swap a 1985 22re into a 1987?
  152. 22RE Turbo - Hard start after replacing bad charcoal canister
  153. Need help identifying wires and connections
  154. A/C actuator/diaphragm adjuster vs A/C amplifier adjuster
  155. Typo in 93 FSM for A/C VSV?
  156. 92 pickup no crank
  157. 92 pickup no crank
  158. Help identify this new squeal/rattle on my 92 pickup.
  159. What is this part called
  160. Rough start/low idle only after heat soak - need help!!
  161. Broken EGR Valve
  162. Transmission slips and howls between 2nd and 3rd gear...do i need a rebuild???
  163. Rods
  164. Fuel line to charcoal canister replacement
  165. 22RE Engine wont turn over by hand
  166. 86 Pickup Interior restoration questions
  167. Engine swap with a 2jz into a 1993 truck
  168. 22re -- correct timing at altitude
  169. What is this noise? ‘87 22RTE
  170. Hazzard lights and horn not working.
  171. Which rust paint closest to code 138?
  172. when to replace ecm?
  173. Coil questions... 22re
  174. 1987 Toyota Pickup Base 4 Cyl 2.4L Parts
  175. 3vze code 71
  176. 1992 3.0 V6 pick up dies while driving
  177. 91 pickup, 3vze, m/t 4x4 no start just click
  178. 1988 2wd longbed project truck for sale
  179. 88 Toyota headgasker
  180. 1988 Pickup Project?
  181. Fuel Issue
  182. 22RE Head gasket failure CONFIRMATION (?)
  183. 1988 Extd Cab Pickup Question
  184. Overheated, fixed that, now runs badly.. damage?
  185. Light bulb for a/c indicator button?
  186. Steering rebuild
  187. 2nd Gen 4runner Ditch Lights
  188. There was an ACCIDENT!!
  189. 3VZE Front pulley/ballancer
  190. 22re to 22r mas issue
  191. How do these camber settings look? What do yours look like?
  192. Best compression tester for under $25?
  193. 1993/1995ish 3vze overheating... yes, I know. :(
  194. 86 pickup fuel back flow problem
  195. Need Help Checking Timing!
  196. 95 Tacoma Ex Cab Rear mounts
  197. Front brake line, flexible - extended
  198. 86 toyota pickup, No power!
  199. Fluid Seeping Out of Rear of Exhaust Manifold
  200. What the heck is this thing???
  201. 86 22R Timing
  202. 89' V6 exhaust system interchangeable with 89 models built after April?
  203. 1986 Toyota Pickup--where to buy a fuel filler neck hose?
  204. Radiator and exhaust???s
  205. 1986 Toyota Pickup
  206. EGR And Air Injection
  207. HELP! seaching for 1986 toyota turbo pickup
  208. 94-95 evaporator housing
  209. Brake System Question
  210. Need help with Oil leak
  211. Gasoline Smell
  212. How low is your oil pressure at idle when hot (pic of my gauge attached)
  213. 89 Pickup (Pictures heavy)
  214. W56-C Parts
  215. 1987 Pickup 4x4 Transmisson Removal Question
  216. 86 pickup can’t find parts
  217. Failed aftermarket valve spring
  218. How to rebuild a W58 5 speed transmission Part 1(GearBoxVideo)
  219. 1989 3vze California o2 sensor? Truck smells under load.
  220. Fender-bender fan issues- Please, help.
  221. Deciding on 4x4 based on mpg
  222. Denso Platinum TT Spark Plug PK16TT
  223. 86 22r wont start when warm
  224. A/C Drier Help
  225. Milky trans fluid?
  226. What new fuel injectors to buy???
  227. Craigslist listing - Not so cheap 2nd gen diesel
  228. Brake issues
  229. Bed rust options
  230. 92' Yota back brakes work, front don't
  231. 22RE RV (Recreational Vehicle) Engine Question
  232. 91 Pickup No Dash Light Illumination, other lights working fine
  233. Extremely hard to get out of low range
  234. Trailer wiring
  235. 93 Toyota Pickup ac
  236. Instrument Panel Fuse blowing
  237. Building my first engine, have a couple of questions
  238. R151f turbo transfer case mated to V6 R150
  239. Safe coolant temp for 22rte?
  240. Cig lighter/ashtray illumination
  241. Fuel issues
  242. Wiring assistance needed
  243. 87 4Runner, 22RE, lack of power, popping from exhaust, misfiring?
  244. !986 4runner 22re Random Misfire Short E2/FC/FP
  245. Cracked head 3vze
  246. Confirm my suspisions
  247. headliner matting
  248. 3vze timing belt/intake-water pulley
  249. How to tighten crankshaft bolt while on engine stand?
  250. Rod knock from the brass connecting rod bushings?
