Banjo washer dropped in intake
Wow. Probably one of my most embarrassing and depressing moments of my automotive life.
Was putting my rig back together after draining the tank via fuel pump and as I was putting the fuel pressure regulator one of the banjo washers (copper) fell on in the hole closest to the firewall.
Anybody experienced dropping something in there? I've tried a claw and vacuum. Is my only option to take off fuel rails and intake and see if it can be retrieved from there? Is it even retrievable??
Thanks for any input or help
you either need to keep fishing for it or start taking things apart until you find it.
Like Melrose said, duct tape and a coat hanger, or anything sticky that will come back out with your "fishing pole" and not end up stuck to the inside of the intake. if you have access to a bore scope (maybe a loner or rental from a parts place) it could help.
The vacuum was a good idea, maybe if you duct tape some smaller hose to the vacuum you can snake it down in there and get it.
The lower intake is fairly flat, not angled down much so it's unlikely that the washer would have made it that far. Also, there is only a 25% chance the intake valve was open which would be necessary for the washer to make it all the way onto the piston. I'd try the tape on a stick for a long time before removing the intake manifold. Getting that all off and sealed back up is a lot of work. Can you see the washer with a mirror?
Couldn't see it with a mirror or a vacuum it out. I took off the intake and still don't see it where the valve is. The valve was open so it's gotta be on the piston.
This seems like a worse case scenario situation. I suppose the only course of action is to take off the head so I can take it off the piston huh?
If you don't see it anywhere in the intake or cylinder with a bore scope then it didn't go into the intake like you thought.
If it IS in there you don't want it chewed up and ran through any valves, that would be even more costly!
A picture of where you dropped it would be helpful so we can tell what the "hole closest to the firewall" really is.
Yeah, everyone says they're cheap, but no one says where to get 'em! https://www.aliexpress.com/item/32872559409.html (figure 6 weeks shipping, or even more, so if you're in a hurry pay some more and get it locally).
Do you have a compressor? tape up a piece of 1/4" (or so) vacuum hose and shoot air into the suspect cylinder. A crush washer is probably too big to just "blow out" past your vacuum hose, but at least you'll be able to hear it rattling around! Then you know where to go.
If you can confirm the washer is in the cylinder, you can gently turn the crank to move the piston up and down. You might get a better angle to catch it with your sticky chopstick.
FWIW, OEM crush washers are aluminum, not copper. Copper crush washers ARE used on brake lines, possibly because of the much high pressures.
(I wouldn't rule out the possibility that it fell somewhere, but not into the intake as Ralphthe thinks. The air test I suggested has a good chance of "proving" where it went. Imagine what would go through your mind if you removed the head and saw nothing!)
FirstGenRunner
Jun 30, 2012 02:28 PM
