Intake mods and fuel pressure
Old Mar 21, 2007 | 05:23 PM
rbh261's Avatar
Just curious about something and maybe someone here has experience or data to answer this.
I understand the importance of getting more air into the engine with the least amount of restriction. I also know that the fuel pressure regulator gets its reference vacuum from the silencer box on the intake tube. With that noted, wouldn't the vacuum be lower in a less restrictive intake setup (K&N filter and elbow mod) ? If so, wouldnt the fuel pressure regulator see a lower demand for fuel due to this? So, are we hurting the fuel/air ratio by doing these mods? Is the air intake gain countered be the loss of fuel pressure? Am I over thinking things?
Old Mar 21, 2007 | 06:09 PM
marko3xl3's Avatar
Actually your fuel pressure regulator is connected after the throttle body, and the less vacuum you have, the more fuel it'll 'allow'. With an aftermarket intake, the only thing that could happen AFTER the throttle body is lower vacuum = more fuel, no problem.
That's why us S/C guys connect the FPR to a boosted "vacuum" line, so we can get even more fuel
Old Mar 22, 2007 | 08:00 AM
rbh261's Avatar
I may be missing something, but tracing my vac lines my fuel pressure regulator is connected in front of the throttle body. It's even shown that way on the vacuum diagram. I'm confused.
Old Mar 24, 2007 | 05:48 PM
marko3xl3's Avatar
Either way, the lower the vacuum/higher the boost, you'll get more fuel pressure, no matter before or after the TB.
But anyway, an aftermarket intake will not change anything drastically enough to cause fuel pressure problems.
The only problems that could arise are not enough fuel and too much air, but that doesn't usually happen with an intake upgrade only and if you have that problem, it wouldn't be because your new intake increased vacuum.
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
Poppie51
Jul 23, 2015 05:03 PM
v_man
Jul 23, 2015 04:01 PM
Poppie51
Jul 16, 2015 06:16 PM
