Question about FPR Blocking
Old Apr 14, 2010 | 04:55 PM
Guardian_Saint's Avatar
Have anyone attemp or done this before by blocking their fuel pressure regulator off? I have treid it once and it still run but scared that the fuel pump may die out of that. So have anyone done this w/o any problem?
Blocking the fuel line to the FPR. Attemp to block.
Old Apr 14, 2010 | 05:28 PM
myyota's Avatar
You need the vacuum hose connected to the fuel presure regulator for it to operate properly, so leave it hooked up. You will gain nothing by unhooking the vacuum hose from it.
Old Apr 14, 2010 | 10:37 PM
I want to see if this will help to save gas cause fuel are giong back to the tank.
Old Apr 14, 2010 | 10:45 PM
milehigheric's Avatar
Are you kidding? Are you trying to break something?
The fuel pressure regulator is there for a reason. Once the fuel pump is on, its on...it keeps pumping away and doesnt stop until you turn off the key. Some vehicles have two stage pumps, but on the good old yotas there just on or there off. Now if the pump was just let to run by itself without regulation it would just keep building pressure in the lines and the fuel rail. Eventually something will give, either the fuel pump will die, a line will burst etc etc - my guess is the pump, but prove me wrong lol.
The regulators only job is to keep the fuel rail pressure within range, it has no effect on fuel economy. If there is to much pressure it opens and the excess fuel is just returned to the tank to be used again later.
Old Apr 15, 2010 | 04:25 AM
scope103's Avatar
If you disconnect the vacuum line to the fuel pressure regulator it will run rich all the time. The computer sets the mixture by the amount of time the injectors are open, on the "assumption" that the pressure differential across the injector is held constant by the regulator. Remove vacuum: pressure on injector rail too high: too much fuel used on each injection.
If you disconnect and block the return line, not only will the injector rail pressure go through the roof, well, the pump will eventually blow up
bigjstang
Jun 2, 2025 03:56 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
thefishguy77
Jul 30, 2015 10:59 AM
jon.r
Jul 11, 2015 03:34 PM
Coreyr384
Jul 10, 2015 11:13 AM
