wont run after intake manifold removal
Old 07-12-2009, 03:04 PM
91YotaExcab's Avatar
the truck is a 91 v6, with an auto trans, had to replace the coolant bypass hose that runs under the intake manifold. after i put everything back together and went to turn it over it just cranked for about 10 seconds. I expected this because of the removal of the fuel rail and all. After another 10 seconds it finally started but just sputtered and died. The one thing i noticed is the fuel line that goes into the top front right hand side of the fuel pressure regulator was about to burst from all the fuel pressure built up inside it. I took the hose off and fuel sprayed everywhere. I have no idea what could cause this, anyone have this happen before?
Old 07-12-2009, 03:17 PM
yoterr's Avatar
try spaying either in the intake and see if it starts, if it does you have a fuel prob
Old 07-12-2009, 03:50 PM
cant everythings closed right now. i still dont understand the pressure build up tho
icentropy
09-16-2020 02:47 PM
steve miller
10-10-2015 01:40 AM
ItsJustD
07-07-2015 07:49 AM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: wont run after intake manifold removal
