- 94 4runner fsm help please
- mightymouse asked what part of 94 motor was made HELP
- I think my coil is bad
- Help with 22-re head shim???
- 1993 bad transmission or shift solenoids?
- 94 3.0 not running need for work
- Bouncing Battery (Voltage) Indicator
- 3.slow Fuel Injector Wiring Module Fix
- 22RE odd idle characteristics
- Starter spins but no crank...
- witch hood should i run.... opinions please...
- My runner quit 3.0 after head gasket replace
- 87 22r pickup timing chain replacing to cylinder head replacing
- 94 22re into a 91 pickup 22re 4x4
- Rocky Road Outfitters rock sliders on '87 4Runner?
- Bad Plugs + Wires?
- 1987 4runner knocking/tapping noise replaced main and rod bearings and timing chain
- 89 4runner sr5 4x4 automatic transmission/power issue
- trd supercharged 3.4?
- Truck Accident - Alignment Issues (ADVICE)
- Initial start up problem
- serious problem helppp ! 91 4x4 22re
- 1 gen 4runner help needed.
- 88 22 re
- 4Runner Rear door/tail gate external handle
- what gear ratio should i go with for my 22re?
- Can I Get a Lock Cylinder Keyed To Match?
- 1988 22re Flamethrower Injector Review
- Advice on Mods
- 1st gen noise during acceleration
- Third gen pickup 4runner leaf spring swap?
- 1986 4runner 22re replaced tps crazy rough idle
- W56 oil change help.
- Truck pulls to right... even after alignment and new brakes.
- way to fix plug ins on wiring harness
- Looking for a Nut.
- Looking for the right truck rims.
- advise on putting another wiring harness on 91 22re pickup
- code 21 on 22re
- Rock assault assembly issues
- what does ground behind grille on driver side go to 91 22re 4x4 pickup
- benefit by seafoaming 1991 pickup 22re
- 2nd gen front swap question
- Strange A/C issues
- Rusted shock mount
- Grinding noise when in gear and off gas
- oil cooler removal
- Torquing Question ?
- 92 pickup 22RE fuel pumps
- Temp guage in truck is not working - 22re
- What caused my Hydrolock?
- Warrior Products Tube Bumper
- Rebuild advice
- Rear power window Relay Beeping
- TPS setting help I have #'s and I have read
- Conversion Kit
- new owner with Poor Throttle response: 1992 22RE pickup
- 1994 pickup 22re minimal power till 3300 rpm
- 93 4runner door handle repair
- 88' 3VZE Trigger Angle?
- Broken leaf spring advice?
- 89 p/u w/ 22re has no acceleration, won't go over 45mph
- 91 toyota pickup wiring harness helpppp!!!
- bad MAF sensor? or VAFM rather?
- Where to buy FJ80 coils?
- Locker or not?
- 87 pickup, parts help.
- headlights, pull back on the lever?
- No rear block suspension...
- 1993 Pickup Braking noises
- 3.0 intake manifold port/polish?
- Electrical stupidity - need help.
- 1994 4x4 Truck: How do you get non-re-usable Parts?
- 89 Oil Sending Unit
- 3.0 right bank not firing
- Turbo question
- why 91 22re pickup idle runs low after i turn lights on
- Smoke from exhaust?
- 3.0L V6 Head Gasket Recall Update
- MLS vs. Traditional Head Gaskets
- 89 sr5 v6 ujoint/drive shaft ?
- 22r vs. v6
- knock sensor change or leave
- 1991 4runner 3vze engine code 12 will not start
- 1993 Pickup rear lift springs
- 7mgte swap
- 15x7 Split 4-spoke wheel differences
- Rebuld or engine swap
- 88 toyota 4runner 3.0 v6 hesitation when accelerating
- 89 22re Delayed engine turn over need help please!
- injector service?
- OM617 with auto trans....
- am i the only one that feels like this isnt right?
- Someone explain the witchcraft in re-seating torque converters (A340H)
- Finishing touches on new install of weber 32/36
- 22re 4runner help!
- New to Yotas, and need some help
- 91 IFS Front End Rebuild
- Wheeling the automaic
- need.some help
- Replace Broken Harness Connector?
- 88 pick up. Need some help
- big trouble think I blew head gasket
- No Crank , No Start
- Easier and faster removal of Fuel Pulsation Damper
- Anyone bought a engine from Oregon Engine Rebuilders Inc
- 88 4x4 Shock Replacement
- 89 p/u 3.0 wont start again.
- 3VZ-E Hesitation/misfire after sensor replacement
- 22re stalls then runs OK??
- Lost Track of P/S vacuum hose Location
- Rear window no switch or relays
- Cylinder Head Replacement
- Alternator slightly worn out of spec. Ever seen this?
- need help ... 94 4wd reg cab
- what is this on my factory bronze tint? 94 SR5 4x4
- can someone explain how to unhook the vamf?
- Vacuum test procedure?
- just finished rebuilding engine - now the real problems begin
- 22re annoying water issue!
- Shock Absorber sizing with lift
- Metal vs Aluminum radiator
- Fuel pump n69487 sucks
- 3rd gen hood on a 2nd gen?
- Help identify this hose!
- Seasonal Idle Issues
- Bumps just dont feel right
- 22re 89 pickup wont rev
- bumper fitment
- Engine harness 90' 3vze.
- vibration when moving
- Starting problem!
- will a 93 4 runner hood fit on a 93 pickup
- Throwing error codes.. 3rd time getting this one
- Low idle web warm need help
- 3VZ-E updated valve cover?
- Aftermarket Ignition Coil
- Mystery vacuum hose
- Knock sensor wire queston
- 4xInnovatons Rear Bumper....Anyone Got One?
- Front Plate Bumper......Any Others Out There?
- 2004 rear disc swap on a 1998?
- 22RE smog And Vacuum deletion
- Flame Thrower 3.0 injector review
- whats this part and how to fix
- A/C amplfier after diesel swap ?
- 1991 pickup starting problem
- Flamethrowers 1986 22re Injectors
- weird idling
- SR5 Tach not working
- looking for crankshaft in MD area
- Checking for Bent Valves
- complete newb.. replacing pitman arm idler arm
- Transfer Case Indentification Help
- Completed timing kit, now have green oil..
- 1st Gen 4runner AC Compressor
- 89 sr5 v6 5spd starting issue
- New spark plugs and...
- where to find ecm ground?
- First Time Truck Owner
- Wire going into rear 3rd on 1991
- new truck, what to fix before cross country trip??
- 1986 automactic slipping
- bed swap. measurements needed
- 22re Ignition Control Module Swap - 94 <==> 92
- 22re egr delete, vac line removal.
- WTB[Canada] LH Lower Control arm
- 1989 v6 pickup manual
- no power in a gear
- 22re clutch problems.
- How To Keep Your Toyota Alive 1975-1987 Repair Manual PDF
- Cab Corner Collapse
- humming/buzzing noise on idle
- SAS frame jigs measurements
- steering wheel at 45 degree angle when driving
- Flamethrower fuel injector review, v6
- Should I use anything on Timing Cover gasket??
- Help!! water in oil/dipstick/oil cap
- 22r rebuild myself, buy rebuilt, or have mine rebuilt at the shop
- What bucket seats are you using??
- Vibration issues
- Clogged Catalytic Converter
- 91' 3VZE build and troubleshoot
- New ride......confusing abnormalities
- choke replacement?
- (Newbie) 87 22r HG leak or water pump ?
- V6 3.0 No Power
- 3vze air conditioner leak
- fuel pump bracket
- Distributor hookup 91 4runner
- 94 4Runner 3VZ EGR exhaust to valve pipe (Denver, CO)
- 4.88 gear swap pattern second opinion please!
- Oil Leak After Timing Belt Change Has Me Wondering
- ECT Mod?
- No blinkers
- 87 replacement bed
- Front wheel bearing q
- Need serious help. 1994 Toyota Truck will not start
- Oil leak can't find rebuild 89 Toyota with 86 mortor
- need help (ive searched for the last 8 hours)
- 22r carb knocking under load and accleration help?
- 1992 Pickup gas tank
- Need help with vacuum lines!
- 86 a/c rebuild
- 86 4runner tailgate plastic bracket broken?
- 3VZE won't start
- Truck has to be held into first gear
- Lurching, poor driveability, 3vze
- toyota pick rough start and idle
- Mpg gain?
- motor blow by help
- 87 4Runner hitch receiver on a 87 Pickup?
- I've got the bug... any sub $100 Mods/Upgrades Recommended?
- 22RTE failed smog high nox
- Timing Issues
- Grinding from flexplate
- Help!! 1991 4runner alternator
- Stiff shifting through 3rd
- Definitive Temp Gauge Fix!
- Zuk Installing and Fine Tuning Questions using 98 runner coils
- 95' dash removal
- 92 3.0 oil leak
- Plugging a splitter into the cigarette lighter......... Continued use?
- help answer a few questions on newly acquired 94 4runner 4x4 auto
- 90 v6 3.0 harmonic balancer bolt
- 94 4runner strange grinding sound from intake
- who might have a Marlin 1600# clutch in stock?
- body lift modifications?
- Bent knuckle arm (pic) - can someone verify?
- 4runner mirrors on pickup
- Newbie 1987 22RE 'Runner power loss
- Question about idle up vsv wiring
- CV axle or front diff?
- New 4Runner = Need help identifying questions under the hood
- My experience replacing W56-B input shaft bearing this weekend.....
- Another cold start issue
- 91 pickup bracket lift removal and truck camper prep
- 22re vs 3.0 oil sender connector the same?
- 89 door panels on 86
- Free injectors from flame thrower (3VZE)Review
- 1992 4runner 4wd wont engage
- numbers stamped on surface of 22re block on right side of each cylinder
- I want to turbo my 22re
- Safe Engine Temp Range 22re
- 1991 pickup with 22re misfire? Flashes CEL but no codes stored
- Bolt in bucket affair?
- Bolt in affair?
- 1991 22re engine coolant sensor problem helppppp
- Worst thing imaginable ..
- Where can I buy seats for a '92 pickup
