3zve knocking with video
Old Apr 30, 2013 | 07:30 PM
FlamingToast's Avatar
Anyone want to take a guess at what the noise/noises are in this video before i pull the oil pan to check the rod bearings? And yes. It sounds exactly as bad in person as it does in the video.
http://www.youtube.com/watch?v=NJeEJ...ature=youtu.be
Old Apr 30, 2013 | 07:48 PM
jreyes94's Avatar
sounds very much like rod knock. but then again the intermittent knock seems like it has very recently started knocking?
you're going to have a fun time pulling the pan if your rig is 4wd
Old Apr 30, 2013 | 08:24 PM
scope103's Avatar
I can't tell much from the video, but you have a lot of high-frequency noise (clicks) that could easily be something else. Did you try a "stethoscope" (I recommend the inside of a roll of paper towels) to try to localize (locate) the sound?
Old Apr 30, 2013 | 08:30 PM
codyarmbrust's Avatar
I am sorry for jumping into this thread but new to site and wont ˟˟˟˟ing let me sdtart my own anyways complete rebuild on 89 toyota pickup 3.0 now it just idles and when you give it gas it just wants to die fir a second than idles up this truck starts good and idles good just wont rev timing is exactly 12 degrees btdc using timing light tried ten and does the same thing i used the vacum diagram and everything is right new cap and plugs and wires please help
Old May 9, 2013 | 08:52 PM
Just an update for anyone who may be curious. I pulled the pan on my 1990 v6 4wd runner today, and I found this.
Looks like I found the source of at least some of the noise. I'm still pretty sure something else is causing the higher frequency tapping sound though.
ashamsuddin
17
Jul 22, 2024 03:59 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
Davebarbier
Nov 3, 2015 03:28 PM
moparbay
Oct 6, 2015 09:24 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
